Not able to run riscv-rv32imac testsuites
Vaibhav Gupta vaibhavgupta40 at gmail.com
Tue Aug 6 08:54:27 UTC 2019
Getting this error:
$ rtems-test --rtems-bsp=rv32imac --rtems-tools=$HOME/development/rtems/5
~/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples
RTEMS Testing - Tester, 5.0.not_released
 Command Line: /home/varodek/development/rtems/5/bin/rtems-test
--rtems-bsp=rv32imac --rtems-tools=/home/varodek/development/rtems/5
/home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples
 Host: Linux varodek 5.0.9-arch1-1-ARCH #1 SMP PREEMPT Sat Apr 20 15:00:46
UTC 2019 x86_64
 Python: 3.7.3 (default, Mar 26 2019, 21:43:19) [GCC 8.2.1 20181127]
Host: Linux-5.0.9-arch1-1-ARCH-x86_64-with-arch (Linux varodek
5.0.9-arch1-1-ARCH #1 SMP PREEMPT Sat Apr 20 15:00:46 UTC 2019 x86_64 )
error: cannot find bsp configuration file: rv32imac.ini
I mentioned "--enable-tests " while configuration.
Moreover, I wanted to run a specific test like hello.exe, like
i do for sparc:
$ sparc-rtems-run ./hello.exe
Because i need to test my testsuite.
Vaibhav Gupta
On Tue, Aug 6, 2019 at 2:10 PM Sebastian Huber <
> On 06/08/2019 10:33, Vaibhav Gupta wrote:
> > But when I am trying to run hello world testsuite:
> > $ riscv-rtems5-run ./hello.exe
> You have to use the RTEMS Tester, e.g.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190806/abcd992e/attachment-0002.html>
