[PATCH] libtest: Change expected fail state string
Mon Dec 2 22:32:11 UTC 2019
On 2/12/19 6:24 pm, Sebastian Huber wrote:
> Use the value expected by the RTEMS Tester.  There are two separator
> characters used ('-' and '_') for the states.  This is a bit
> inconsistent.
Sorry about this. I had not noticed.
>  cpukit/libtest/testbeginend.c | 2 +-
>  1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/cpukit/libtest/testbeginend.c b/cpukit/libtest/testbeginend.c
> index b739e47b2e..9bdc86780c 100644
> --- a/cpukit/libtest/testbeginend.c
> +++ b/cpukit/libtest/testbeginend.c
> @@ -29,7 +29,7 @@ rtems_printer rtems_test_printer = {
>  static const char* const test_state_strings[] =
>    "EXPECTED-PASS",
Should this change or should `USER_INPUT` be changed and we update ...
https://git.rtems.org/rtems-tools/tree/tester/rt/report.py#n159
https://git.rtems.org/rtems-tools/tree/tester/rt/report.py#n161
It would be a simpler change because this change means we move to having 2 with
`_` and a bunch with `-`. There are internal states in the tester such as
`WRONG-VERSION` and changing all of those is a bigger change in the tester.
> -  "EXPECTED-FAIL",
> +  "EXPECTED_FAIL",
>    "USER_INPUT",
>    "INDETERMINATE",
>    "BENCHMARK"
