[PATCH] Be more resilient against $PATH errors
Mon Dec 2 22:32:45 UTC 2019
OK.
On 2/12/19 7:46 pm, Sebastian Huber wrote:
> Close #3781.
>  source-builder/sb/check.py | 30 +++++++++++++++++-------------
>  1 file changed, 17 insertions(+), 13 deletions(-)
> diff --git a/source-builder/sb/check.py b/source-builder/sb/check.py
> index 9e4e953..be808ea 100644
> --- a/source-builder/sb/check.py
> +++ b/source-builder/sb/check.py
> @@ -104,20 +104,24 @@ def path_check(opts, silent = False):
>      if 'PATH' in os.environ:
>          paths = os.environ['PATH'].split(os.pathsep)
>          for p in paths:
> -            if len(p.strip()) == 0:
> +            try:
> +                if len(p.strip()) == 0:
> +                    if not silent:
> +                        log.notice('error: environment PATH contains an empty path')
> +                    return False
> +                elif not options.host_windows and (p.strip() == '.' or p.strip() == '..'):
> +                    if not silent:
> +                        log.notice('error: environment PATH invalid path: %s' % (p))
> +                    return False
> +                elif not path.exists(p):
> +                    if not silent and opts.warn_all():
> +                        log.notice('warning: environment PATH not found: %s' % (p))
> +                elif not path.isdir(p):
> +                        log.notice('warning: environment PATH not a directory: %s' % (p))
> +            except Exception as e:
>                  if not silent:
> -                    log.notice('error: environment PATH contains an empty path')
> -                return False
> -            elif not options.host_windows and (p.strip() == '.' or p.strip() == '..'):
> -                if not silent:
> -                    log.notice('error: environment PATH invalid path: %s' % (p))
> -                return False
> -            elif not path.exists(p):
> -                if not silent and opts.warn_all():
> -                    log.notice('warning: environment PATH not found: %s' % (p))
> -            elif not path.isdir(p):
> -                    log.notice('warning: environment PATH not a directory: %s' % (p))
> +                    log.notice('warning: environment PATH suspicious path: %s' % (e))
>      return True
