[PATCH 1/5] rtems: Add and use rtems_object_get_local_node()
Thu Dec 12 08:43:03 UTC 2019
Update #3841.
 bsps/include/shm_driver.h               |  2 +-
 bsps/shared/shmdr/shmdr-dump.c          |  2 +-
 bsps/shared/shmdr/shmdr-init.c          |  2 +-
 bsps/shared/shmdr/shmdr-send.c          |  2 +-
 cpukit/include/rtems/rtems/object.h     | 10 ++++++++++
 cpukit/include/rtems/score/object.h     |  9 +++++++++
 cpukit/include/rtems/score/objectimpl.h |  9 ---------
 cpukit/libcsupport/src/error.c          |  2 +-
 cpukit/libcsupport/src/getpgrp.c        |  4 ++--
 cpukit/libcsupport/src/getpid.c         |  4 ++--
 cpukit/libcsupport/src/utsname.c        |  8 ++++++--
 testsuites/ada/support/initimpl.h       |  3 +--
 testsuites/mptests/mp01/initimpl.h      |  4 ++--
 testsuites/mptests/mp03/initimpl.h      |  4 ++--
 testsuites/mptests/mp03/task1.c         |  6 +++---
 testsuites/mptests/mp04/initimpl.h      |  6 +++---
 testsuites/mptests/mp04/task1.c         |  6 ++----
 testsuites/mptests/mp05/initimpl.h      |  4 ++--
 testsuites/mptests/mp05/task1.c         |  4 ++--
 testsuites/mptests/mp06/initimpl.h      |  4 ++--
 testsuites/mptests/mp06/task1.c         | 10 +++++-----
 testsuites/mptests/mp07/initimpl.h      |  4 ++--
 testsuites/mptests/mp07/task1.c         |  4 ++--
 testsuites/mptests/mp08/initimpl.h      |  6 +++---
 testsuites/mptests/mp08/task1.c         |  4 ++--
 testsuites/mptests/mp09/initimpl.h      |  6 +++---
 testsuites/mptests/mp09/task1.c         |  2 +-
 testsuites/mptests/mp10/initimpl.h      |  4 ++--
 testsuites/mptests/mp11/initimpl.h      |  4 ++--
 testsuites/mptests/mp12/initimpl.h      |  4 ++--
 testsuites/mptests/mp13/initimpl.h      |  6 +++---
 testsuites/mptests/mp13/task1.c         |  2 +-
 testsuites/mptests/mp13/task2.c         |  2 +-
 testsuites/mptests/mp14/evtask1.c       |  6 ++----
 testsuites/mptests/mp14/initimpl.h      | 12 ++++++------
 testsuites/mptests/mp14/msgtask1.c      |  4 ++--
 testsuites/mptests/mp14/pttask1.c       |  4 +---
 testsuites/mptests/mp14/smtask1.c       |  4 +---
 testsuites/mptests/mp14/system.h        |  2 --
 testsuites/samples/base_mp/initimpl.h   |  2 +-
 40 files changed, 95 insertions(+), 92 deletions(-)
diff --git a/bsps/include/shm_driver.h b/bsps/include/shm_driver.h
index e357b46e5e..3dca866aa1 100644
--- a/bsps/include/shm_driver.h
+++ b/bsps/include/shm_driver.h
@@ -239,7 +239,7 @@ extern "C" {
 /* macros */
 #define Shm_Is_master_node()  \
-  ( SHM_MASTER ==_Configuration_MP_table-> node )
+  ( SHM_MASTER == rtems_object_get_local_node() )
 #define Shm_Free_envelope( ecb ) \
   Shm_Locked_queue_Add( FREE_ENV_CB, (ecb) )
diff --git a/bsps/shared/shmdr/shmdr-dump.c b/bsps/shared/shmdr/shmdr-dump.c
index f1be932467..4195f914f1 100644
--- a/bsps/shared/shmdr/shmdr-dump.c
+++ b/bsps/shared/shmdr/shmdr-dump.c
@@ -41,7 +41,7 @@ Shm_Print_statistics(void)
     packets_per_second++;
   printk( "\n\nSHMDR STATISTICS (NODE %" PRId32 ")\n",
-    Multiprocessing_configuration.node );
+    rtems_object_get_local_node() );
   printk( "TICKS SINCE BOOT = %" PRId32 "\n", ticks );
   printk( "TICKS PER SECOND = %" PRId32 "\n", ticks_per_second );
   printk( "ISRs=%" PRId32 "\n",     Shm_Interrupt_count );
diff --git a/bsps/shared/shmdr/shmdr-init.c b/bsps/shared/shmdr/shmdr-init.c
index 0cf51172ce..c119145191 100644
--- a/bsps/shared/shmdr/shmdr-init.c
+++ b/bsps/shared/shmdr/shmdr-init.c
@@ -46,7 +46,7 @@ rtems_mpci_entry Shm_Initialization( void )
   uint32_t                 remaining_memory;
   uint32_t                 local_node;
-  local_node = _Configuration_MP_table->node;
+  local_node = rtems_object_get_local_node();
   Shm_Get_configuration( local_node, &Shm_Configuration );
diff --git a/bsps/shared/shmdr/shmdr-send.c b/bsps/shared/shmdr/shmdr-send.c
index c3ac7d51c2..b8ee2d4da4 100644
--- a/bsps/shared/shmdr/shmdr-send.c
+++ b/bsps/shared/shmdr/shmdr-send.c
@@ -46,7 +46,7 @@ rtems_mpci_entry Shm_Send_packet(
   else {
     for( nnum = SHM_FIRST_NODE ; nnum <= SHM_MAXIMUM_NODES ; nnum++ )
-      if ( _Configuration_MP_table->node != nnum ) {
+      if ( rtems_object_get_local_node() != nnum ) {
         struct pkt_cpy *pkt;
         tmp_ecb = Shm_Allocate_envelope();
diff --git a/cpukit/include/rtems/rtems/object.h b/cpukit/include/rtems/rtems/object.h
index 3f70fc3f1c..d6ae058425 100644
--- a/cpukit/include/rtems/rtems/object.h
+++ b/cpukit/include/rtems/rtems/object.h
@@ -357,6 +357,16 @@ rtems_status_code rtems_object_get_class_information(
   rtems_object_api_class_information *info
+ * @brief Get the local MPCI node number.
+ * @return The local MPCI node number.
+RTEMS_INLINE_ROUTINE uint16_t rtems_object_get_local_node( void )
+  return _Objects_Local_node;
 #ifdef __cplusplus
 #endif
diff --git a/cpukit/include/rtems/score/object.h b/cpukit/include/rtems/score/object.h
index 6f4bea95ae..6c39af6749 100644
--- a/cpukit/include/rtems/score/object.h
+++ b/cpukit/include/rtems/score/object.h
@@ -338,6 +338,15 @@ RTEMS_INLINE_ROUTINE Objects_Maximum _Objects_Get_index(
 #define _Objects_Maximum_per_allocation( maximum ) \
   ((Objects_Maximum) ((maximum) & ~OBJECTS_UNLIMITED_OBJECTS))
+ * @brief The local MPCI node number.
+#if defined(RTEMS_MULTIPROCESSING)
+extern uint16_t _Objects_Local_node;
+#else
+#define _Objects_Local_node ((uint16_t) 1)
+#endif
diff --git a/cpukit/include/rtems/score/objectimpl.h b/cpukit/include/rtems/score/objectimpl.h
index 8aca6b794b..9becb33e7d 100644
--- a/cpukit/include/rtems/score/objectimpl.h
+++ b/cpukit/include/rtems/score/objectimpl.h
@@ -63,15 +63,6 @@ typedef enum {
   OBJECTS_FAKE_OBJECTS_SCHEDULERS = 1
 } Objects_Fake_objects_API;
- *  The following is referenced to the node number of the local node.
-#if defined(RTEMS_MULTIPROCESSING)
-extern uint16_t _Objects_Local_node;
-#else
-#define _Objects_Local_node ((uint16_t)1)
-#endif
  *  The following is referenced to the number of nodes in the system.
diff --git a/cpukit/libcsupport/src/error.c b/cpukit/libcsupport/src/error.c
index 0e65f8929b..7d76327f94 100644
--- a/cpukit/libcsupport/src/error.c
+++ b/cpukit/libcsupport/src/error.c
@@ -51,7 +51,7 @@ int rtems_verror(
     if (_System_state_Is_multiprocessing)
-      fprintf(stderr, "[%" PRIu32 "] ", _Configuration_MP_table->node);
+      fprintf(stderr, "[%" PRIu16 "] ", rtems_object_get_local_node());
   #endif
   chars_written += vfprintf(stderr, printf_format, arglist);
diff --git a/cpukit/libcsupport/src/getpgrp.c b/cpukit/libcsupport/src/getpgrp.c
index 208c7022f7..de372f3e8c 100644
--- a/cpukit/libcsupport/src/getpgrp.c
+++ b/cpukit/libcsupport/src/getpgrp.c
@@ -3,7 +3,7 @@
 #endif
 #include <unistd.h>
-#include <rtems/score/objectimpl.h>
+#include <rtems.h>
  *  4.3.1 Get Process Group IDs, P1003.1b-1993, p. 89
@@ -16,5 +16,5 @@ pid_t getpgrp( void )
    *  this will always be the local node;
-  return _Objects_Local_node;
+  return rtems_object_get_local_node();
diff --git a/cpukit/libcsupport/src/getpid.c b/cpukit/libcsupport/src/getpid.c
index 53ab2f4dc8..e17b1f2585 100644
--- a/cpukit/libcsupport/src/getpid.c
+++ b/cpukit/libcsupport/src/getpid.c
@@ -11,7 +11,7 @@
 #include <unistd.h>
+#include <rtems.h>
 #include <rtems/seterr.h>
@@ -19,7 +19,7 @@
 pid_t getpid( void )
 #if defined(RTEMS_NEWLIB) && !defined(HAVE__GETPID_R)
diff --git a/cpukit/libcsupport/src/utsname.c b/cpukit/libcsupport/src/utsname.c
index 8cdd4be536..57ed914aad 100644
--- a/cpukit/libcsupport/src/utsname.c
+++ b/cpukit/libcsupport/src/utsname.c
@@ -23,7 +23,7 @@
 #include <sys/utsname.h>
 #include <inttypes.h>
+#include <rtems.h>
@@ -47,7 +47,11 @@ int uname(
   strncpy( name->sysname, "RTEMS", sizeof(name->sysname) );
-  snprintf( name->nodename, sizeof(name->nodename), "Node %" PRId16, _Objects_Local_node );
+  snprintf(
+    name->nodename,
+    sizeof(name->nodename),
+    "Node %" PRId16, rtems_object_get_local_node()
   strncpy( name->release, RTEMS_VERSION, sizeof(name->release) );
diff --git a/testsuites/ada/support/initimpl.h b/testsuites/ada/support/initimpl.h
index 35739d8a4d..5e3457faf7 100644
--- a/testsuites/ada/support/initimpl.h
+++ b/testsuites/ada/support/initimpl.h
@@ -102,8 +102,7 @@ uint32_t is_configured_multiprocessing(void)
 uint32_t get_node(void)
-  /* XXX HACK -- use public API */
 typedef struct {
diff --git a/testsuites/mptests/mp01/initimpl.h b/testsuites/mptests/mp01/initimpl.h
index d5017af643..e9214c09c1 100644
--- a/testsuites/mptests/mp01/initimpl.h
+++ b/testsuites/mptests/mp01/initimpl.h
@@ -36,10 +36,10 @@ rtems_task Init(
   printf(
     "\n\n*** TEST 1 -- NODE %" PRIu32 " ***\n",
-  if ( Multiprocessing_configuration.node != 1 ) c = 'S';
+  if ( rtems_object_get_local_node() != 1 ) c = 'S';
   else                                           c = 'M';
   Task_name[ 1 ] = rtems_build_name( c, 'A', '1', ' ' );
diff --git a/testsuites/mptests/mp03/initimpl.h b/testsuites/mptests/mp03/initimpl.h
index 533d32175a..ef4879d09c 100644
--- a/testsuites/mptests/mp03/initimpl.h
+++ b/testsuites/mptests/mp03/initimpl.h
@@ -34,7 +34,7 @@ rtems_task Init(
   printf(
     "\n\n*** TEST 3 -- NODE %" PRIu32 " ***\n",
   Task_name[ 1 ] = rtems_build_name( '1', '1', '1', ' ' );
@@ -42,7 +42,7 @@ rtems_task Init(
   puts( "Creating Test_task (Global)" );
   status = rtems_task_create(
-    Task_name[ Multiprocessing_configuration.node ],
+    Task_name[ rtems_object_get_local_node() ],
     1,
     RTEMS_MINIMUM_STACK_SIZE,
     RTEMS_NO_PREEMPT,
diff --git a/testsuites/mptests/mp03/task1.c b/testsuites/mptests/mp03/task1.c
index 5fdda4d0f2..48682e032c 100644
--- a/testsuites/mptests/mp03/task1.c
+++ b/testsuites/mptests/mp03/task1.c
@@ -20,7 +20,7 @@ static void Test_Task_Support(
   rtems_event_set   events;
   rtems_status_code status;
-  if ( Multiprocessing_configuration.node == node ) {
+  if ( rtems_object_get_local_node() == node ) {
     for ( ; ; ) {
@@ -98,7 +98,7 @@ rtems_task Test_task(
   directive_failed( status, "rtems_task_ident" );
   puts( "Getting TID of remote task" );
-  remote_node = (Multiprocessing_configuration.node == 1) ? 2 : 1;
+  remote_node = (rtems_object_get_local_node() == 1) ? 2 : 1;
   printf( "Remote task's name is : " );
   put_name( Task_name[ remote_node ], TRUE );
@@ -130,7 +130,7 @@ rtems_task Test_task(
   directive_failed( status, "rtems_timer_fire_after" );
-  if ( Multiprocessing_configuration.node == 1 ) {
+  if ( rtems_object_get_local_node() == 1 ) {
     status = rtems_task_wake_after( 2 * rtems_clock_get_ticks_per_second() );
     directive_failed( status, "rtems_task_wake_after" );
diff --git a/testsuites/mptests/mp04/initimpl.h b/testsuites/mptests/mp04/initimpl.h
index 3e3d8cd32f..4598944e00 100644
--- a/testsuites/mptests/mp04/initimpl.h
+++ b/testsuites/mptests/mp04/initimpl.h
   printf(
     "\n\n*** TEST 4 -- NODE %" PRId32 " ***\n",
@@ -42,8 +42,8 @@ rtems_task Init(
-    Multiprocessing_configuration.node,
+    rtems_object_get_local_node(),
     RTEMS_DEFAULT_MODES,
     RTEMS_GLOBAL,
diff --git a/testsuites/mptests/mp04/task1.c b/testsuites/mptests/mp04/task1.c
index 242b98c6f9..878effd237 100644
--- a/testsuites/mptests/mp04/task1.c
+++ b/testsuites/mptests/mp04/task1.c
@@ -22,8 +22,6 @@
 #include "system.h"
 #include "tmacros.h"
-extern rtems_multiprocessing_table Multiprocessing_configuration;
   rtems_task_argument argument
@@ -39,7 +37,7 @@ rtems_task Test_task(
   puts_nocr( "Remote task's name is : " );
@@ -55,7 +53,7 @@ rtems_task Test_task(
   status = rtems_task_set_priority(
     remote_tid,
     &previous_priority
   directive_failed( status, "rtems_task_set_priority" );
diff --git a/testsuites/mptests/mp05/initimpl.h b/testsuites/mptests/mp05/initimpl.h
index a2d4002fde..40b1ea6d9e 100644
--- a/testsuites/mptests/mp05/initimpl.h
+++ b/testsuites/mptests/mp05/initimpl.h
   printf(
     "\n\n*** TEST 5 -- NODE %" PRIu32 " ***\n",
-    Task_name[Multiprocessing_configuration.node],
+    Task_name[rtems_object_get_local_node()],
     1,
     RTEMS_MINIMUM_STACK_SIZE * 2,
     RTEMS_TIMESLICE,
diff --git a/testsuites/mptests/mp05/task1.c b/testsuites/mptests/mp05/task1.c
index 171e9a2d21..17a72c4278 100644
--- a/testsuites/mptests/mp05/task1.c
+++ b/testsuites/mptests/mp05/task1.c
@@ -50,7 +50,7 @@ rtems_task Test_task(
   status = rtems_signal_catch( Process_asr, RTEMS_NO_ASR|RTEMS_NO_PREEMPT );
   directive_failed( status, "rtems_signal_catch" );
-  if (Multiprocessing_configuration.node == 1) {
+  if (rtems_object_get_local_node() == 1) {
      remote_node = 2;
      remote_signal  = RTEMS_SIGNAL_18;
      expected_signal = RTEMS_SIGNAL_17;
@@ -81,7 +81,7 @@ rtems_task Test_task(
     puts( "Sending signal to remote task" );
     do {
       status = rtems_signal_send( remote_tid, remote_signal );
diff --git a/testsuites/mptests/mp06/initimpl.h b/testsuites/mptests/mp06/initimpl.h
index 5598d328b0..1155e49f46 100644
--- a/testsuites/mptests/mp06/initimpl.h
+++ b/testsuites/mptests/mp06/initimpl.h
   printf(
     "\n\n*** TEST 6 -- NODE %" PRId32 " ***\n",
     1,
diff --git a/testsuites/mptests/mp06/task1.c b/testsuites/mptests/mp06/task1.c
index 3e8920f4c3..93b04924c6 100644
--- a/testsuites/mptests/mp06/task1.c
+++ b/testsuites/mptests/mp06/task1.c
@@ -80,7 +80,7 @@ rtems_task Test_task(
   Stop_Test = false;
@@ -94,7 +94,7 @@ rtems_task Test_task(
   } while ( status != RTEMS_SUCCESSFUL );
   directive_failed( status, "rtems_task_ident FAILED!!" );
     puts( "Sending events to remote task" );
   else
     puts( "Receiving events from remote task" );
@@ -115,7 +115,7 @@ rtems_task Test_task(
     event_for_this_iteration = Event_set_table[ count % 32 ];
       status = rtems_event_send( remote_tid, event_for_this_iteration );
       directive_failed( status, "rtems_event_send" );
@@ -129,7 +129,7 @@ rtems_task Test_task(
         &event_out
       if ( rtems_are_statuses_equal( status, RTEMS_TIMEOUT ) ) {
-        if ( Multiprocessing_configuration.node == 2 )
+        if ( rtems_object_get_local_node() == 2 )
           puts( "\nCorrect behavior if the other node exitted." );
         else
           puts( "\nERROR... node 1 died" );
@@ -146,7 +146,7 @@ rtems_task Test_task(
   putchar( '\n' );
-  if ( Multiprocessing_configuration.node == 2 ) {
+  if ( rtems_object_get_local_node() == 2 ) {
     /* Flush events */
     puts( "Flushing RTEMS_EVENT_16" );
     (void) rtems_event_receive(RTEMS_EVENT_16, RTEMS_NO_WAIT, 0, &event_out);
diff --git a/testsuites/mptests/mp07/initimpl.h b/testsuites/mptests/mp07/initimpl.h
index 1aa51a3d79..de54663773 100644
--- a/testsuites/mptests/mp07/initimpl.h
+++ b/testsuites/mptests/mp07/initimpl.h
   printf(
    "\n\n*** TEST 7 -- NODE %" PRId32 " ***\n",
     1,
     RTEMS_TIMESLICE,
diff --git a/testsuites/mptests/mp07/task1.c b/testsuites/mptests/mp07/task1.c
index 7902996835..64db8b05b9 100644
--- a/testsuites/mptests/mp07/task1.c
+++ b/testsuites/mptests/mp07/task1.c
@@ -45,7 +45,7 @@ rtems_task Test_task(
   Stop_Test = false;
@@ -58,7 +58,7 @@ rtems_task Test_task(
   } while ( !rtems_is_status_successful( status ) );
     puts( "Sending first event to remote task" );
     status = rtems_event_send( remote_tid, RTEMS_EVENT_16 );
diff --git a/testsuites/mptests/mp08/initimpl.h b/testsuites/mptests/mp08/initimpl.h
index 859b3114bf..6a131c9705 100644
--- a/testsuites/mptests/mp08/initimpl.h
+++ b/testsuites/mptests/mp08/initimpl.h
   printf(
     "\n\n*** TEST 8 -- NODE %" PRIu32 " ***\n",
   Semaphore_name[ 1 ] = rtems_build_name( 'S', 'E', 'M', '\0' );
     puts( "Creating Sempahore (Global)" );
     status = rtems_semaphore_create(
       Semaphore_name[ 1 ],
@@ -56,7 +56,7 @@ rtems_task Init(
     1,
     RTEMS_TIMESLICE,
diff --git a/testsuites/mptests/mp08/task1.c b/testsuites/mptests/mp08/task1.c
index 35d67e649a..3e914db227 100644
--- a/testsuites/mptests/mp08/task1.c
+++ b/testsuites/mptests/mp08/task1.c
@@ -39,7 +39,7 @@ rtems_task Test_task(
     status = rtems_semaphore_delete( Semaphore_id[ 1 ] );
     fatal_directive_status(
       status,
@@ -70,7 +70,7 @@ rtems_task Test_task(
       rtems_test_exit( 0 );
-    if ( Multiprocessing_configuration.node == 1 && ++count == 1000 ) {
+    if ( rtems_object_get_local_node() == 1 && ++count == 1000 ) {
       status = rtems_task_wake_after( rtems_clock_get_ticks_per_second() );
diff --git a/testsuites/mptests/mp09/initimpl.h b/testsuites/mptests/mp09/initimpl.h
index 97237c34f1..ff18c514a2 100644
--- a/testsuites/mptests/mp09/initimpl.h
+++ b/testsuites/mptests/mp09/initimpl.h
   printf(
     "\n\n*** TEST 9 -- NODE %" PRId32 " ***\n",
   Queue_name[ 1 ] = rtems_build_name( 'M', 'S', 'G', ' ' );
     puts( "Creating Message Queue (Global)" );
     status = rtems_message_queue_create(
       Queue_name[ 1 ],
   puts( "Creating Test_task (local)" );
     1,
     RTEMS_TIMESLICE,
diff --git a/testsuites/mptests/mp09/task1.c b/testsuites/mptests/mp09/task1.c
index d971f1b503..dc78552994 100644
--- a/testsuites/mptests/mp09/task1.c
+++ b/testsuites/mptests/mp09/task1.c
@@ -49,7 +49,7 @@ rtems_task Test_task(
     status = rtems_message_queue_delete( Queue_id[ 1 ] );
       status,
diff --git a/testsuites/mptests/mp10/initimpl.h b/testsuites/mptests/mp10/initimpl.h
index b5c5a200f4..5e09662119 100644
--- a/testsuites/mptests/mp10/initimpl.h
+++ b/testsuites/mptests/mp10/initimpl.h
@@ -40,7 +40,7 @@ rtems_task Init(
   printf(
    "\n\n*** TEST 10 -- NODE %" PRIu32 " ***\n",
   Task_name[ 1 ] =  rtems_build_name( 'T', 'A', '1', ' ' );
@@ -51,7 +51,7 @@ rtems_task Init(
   Semaphore_name[ 1 ] = rtems_build_name( 'S', 'E', 'M', ' ' );
       Queue_name[ 1 ],
diff --git a/testsuites/mptests/mp11/initimpl.h b/testsuites/mptests/mp11/initimpl.h
index e44b151597..2f0a97a700 100644
--- a/testsuites/mptests/mp11/initimpl.h
+++ b/testsuites/mptests/mp11/initimpl.h
   printf(
     "\n\n*** TEST 11 -- NODE %" PRIu32 " ***\n",
@@ -50,7 +50,7 @@ rtems_task Init(
     puts( "Attempting to create Test_task (Global)" );
       Task_name[ 1 ],
diff --git a/testsuites/mptests/mp12/initimpl.h b/testsuites/mptests/mp12/initimpl.h
index 7486e664c6..6eb38a904c 100644
--- a/testsuites/mptests/mp12/initimpl.h
+++ b/testsuites/mptests/mp12/initimpl.h
   printf(
     "\n\n*** TEST 12 -- NODE %" PRId32 " ***\n",
@@ -52,7 +52,7 @@ rtems_task Init(
   puts( "Got to initialization task" );
diff --git a/testsuites/mptests/mp13/initimpl.h b/testsuites/mptests/mp13/initimpl.h
index af5456919b..c6ac82ea9e 100644
--- a/testsuites/mptests/mp13/initimpl.h
+++ b/testsuites/mptests/mp13/initimpl.h
   printf(
     "\n\n*** TEST 13 -- NODE %" PRId32 " ***\n",
@@ -44,7 +44,7 @@ rtems_task Init(
       Queue_name[ 1 ],
@@ -103,7 +103,7 @@ rtems_task Init(
   status = rtems_task_start( Task_id[ 2 ], Test_task2, 0 );
   directive_failed( status, "rtems_task_start" );
     status = rtems_task_wake_after( 5 * rtems_clock_get_ticks_per_second() );
diff --git a/testsuites/mptests/mp13/task1.c b/testsuites/mptests/mp13/task1.c
index 563c9f5c17..127c4c8e86 100644
--- a/testsuites/mptests/mp13/task1.c
+++ b/testsuites/mptests/mp13/task1.c
@@ -41,7 +41,7 @@ rtems_task Test_task1(
     puts( "Receiving message ..." );
     status = rtems_message_queue_receive(
       Queue_id[ 1 ],
diff --git a/testsuites/mptests/mp13/task2.c b/testsuites/mptests/mp13/task2.c
index 30466c5265..0b7b5db71d 100644
--- a/testsuites/mptests/mp13/task2.c
+++ b/testsuites/mptests/mp13/task2.c
@@ -40,7 +40,7 @@ rtems_task Test_task2(
   directive_failed( status, "rtems_semaphore_ident" );
diff --git a/testsuites/mptests/mp14/evtask1.c b/testsuites/mptests/mp14/evtask1.c
index 871b0cc881..c65853967f 100644
--- a/testsuites/mptests/mp14/evtask1.c
+++ b/testsuites/mptests/mp14/evtask1.c
@@ -23,8 +23,6 @@
 #include "system.h"
@@ -35,7 +33,7 @@ rtems_task Test_task(
   rtems_id          remote_tid;
   rtems_event_set   event_out;
-  remote_node = ((Multiprocessing_configuration.node == 1) ? 2 : 1);
+  remote_node = ((rtems_object_get_local_node() == 1) ? 2 : 1);
   puts( "About to go to sleep!" );
@@ -59,7 +57,7 @@ rtems_task Test_task(
     rtems_task_wake_after(2);
     while ( Stop_Test == false ) {
       for ( count=EVENT_TASK_DOT_COUNT; Stop_Test == false && count; count-- ) {
diff --git a/testsuites/mptests/mp14/initimpl.h b/testsuites/mptests/mp14/initimpl.h
index 3591e271f8..1dbfb35c22 100644
--- a/testsuites/mptests/mp14/initimpl.h
+++ b/testsuites/mptests/mp14/initimpl.h
   printf(
     "\n\n*** TEST 14 -- NODE %" PRId32 " ***\n",
   Stop_Test = false;
@@ -90,7 +90,7 @@ rtems_task Init(
   Timer_name[ 1 ] = rtems_build_name( 'T', 'M', 'R', ' ' );
     puts( "Creating Semaphore (Global)" );
@@ -125,7 +125,7 @@ rtems_task Init(
   puts( "Creating Event task (Global)" );
     2,
     RTEMS_TIMESLICE,
@@ -140,7 +140,7 @@ rtems_task Init(
   puts( "Creating Semaphore task (Global)" );
-    Semaphore_task_name[ Multiprocessing_configuration.node ],
+    Semaphore_task_name[ rtems_object_get_local_node() ],
     2,
     RTEMS_TIMESLICE,
@@ -155,7 +155,7 @@ rtems_task Init(
   puts( "Creating Message Queue task (Global)" );
-    Queue_task_name[ Multiprocessing_configuration.node ],
+    Queue_task_name[ rtems_object_get_local_node() ],
     2,
     RTEMS_TIMESLICE,
@@ -171,7 +171,7 @@ rtems_task Init(
   puts( "Creating Partition task (Global)" );
-    Partition_task_name[ Multiprocessing_configuration.node ],
+    Partition_task_name[ rtems_object_get_local_node() ],
     2,
     RTEMS_TIMESLICE,
diff --git a/testsuites/mptests/mp14/msgtask1.c b/testsuites/mptests/mp14/msgtask1.c
index c7e3d13c40..3bbeb7ecc2 100644
--- a/testsuites/mptests/mp14/msgtask1.c
+++ b/testsuites/mptests/mp14/msgtask1.c
@@ -53,7 +53,7 @@ rtems_task Message_queue_task(
       status = rtems_message_queue_send(
         Queue_id[ 1 ],
         (long (*)[4])Msg_buffer[ index ],
@@ -94,7 +94,7 @@ rtems_task Message_queue_task(
       directive_failed( status, "rtems_message_queue_send" );
       if (Stop_Test == false)
-        if ( Multiprocessing_configuration.node == 1 && --yield_count == 0 ) {
+        if ( rtems_object_get_local_node() == 1 && --yield_count == 0 ) {
           status = rtems_task_wake_after( RTEMS_YIELD_PROCESSOR );
diff --git a/testsuites/mptests/mp14/pttask1.c b/testsuites/mptests/mp14/pttask1.c
index b93938df4f..409a3ff3ca 100644
--- a/testsuites/mptests/mp14/pttask1.c
+++ b/testsuites/mptests/mp14/pttask1.c
@@ -22,8 +22,6 @@
 #include "system.h"
 rtems_task Partition_task(
@@ -59,7 +57,7 @@ rtems_task Partition_task(
       directive_failed( status, "rtems_partition_return_buffer" );
           status = rtems_task_wake_after( 1 );
           yield_count = 100;
diff --git a/testsuites/mptests/mp14/smtask1.c b/testsuites/mptests/mp14/smtask1.c
index 454f30b450..e4126dbf8b 100644
--- a/testsuites/mptests/mp14/smtask1.c
+++ b/testsuites/mptests/mp14/smtask1.c
@@ -21,8 +21,6 @@
 #include "system.h"
 rtems_task Semaphore_task(
@@ -60,7 +58,7 @@ rtems_task Semaphore_task(
       directive_failed( status, "rtems_semaphore_release" );
       if ( Stop_Test == false )
diff --git a/testsuites/mptests/mp14/system.h b/testsuites/mptests/mp14/system.h
index 9f53601848..3797f0e559 100644
--- a/testsuites/mptests/mp14/system.h
+++ b/testsuites/mptests/mp14/system.h
@@ -104,8 +104,6 @@ TEST_EXTERN rtems_name Timer_name[ 4 ];       /* event timer names */
 TEST_EXTERN uint32_t   Msg_buffer[ 4 ][ 4 ];
 TEST_EXTERN volatile bool Stop_Test;
 TEST_EXTERN rtems_id timer_id;
diff --git a/testsuites/samples/base_mp/initimpl.h b/testsuites/samples/base_mp/initimpl.h
index 608b0dea51..f2bd12d0fc 100644
--- a/testsuites/samples/base_mp/initimpl.h
+++ b/testsuites/samples/base_mp/initimpl.h
     tid,
     Application_task,
   rtems_test_assert(status == RTEMS_SUCCESSFUL);
2.16.4
