psim tests timing out
Fri Dec 13 12:30:17 UTC 2019
On 13/12/19 11:05 pm, Sebastian Huber wrote:
> On 13/12/2019 13:03, Joel Sherrill wrote:
>> It appears based on testing with Chris that the gdb mi code from the tester
>> works with Python 3 and not 2. Would you happen to be using python 2?
> This seems to be the case:
> python --version
> Python 2.7.14
> I guess with the next OpenSUSE update Python 2 is history.
I think there is an issue with the locking in gdb.py or the locking and piped IO
in execute.py. I need to take a closer look when I get home.
