Doxygen @return vs. @retval
Thu Feb 28 15:03:08 UTC 2019
Hello,
we agreed to use @retval instead of @return:
https://docs.rtems.org/branches/master/eng/coding-doxygen.html#doxygen-best-practices
How should we indicate that not a particular value is returned, but
instead an element of a set. For example:
  * @brief Performs something and returns the operation status.
  * @retval 0 Successful operation.
  * @retval EIO Input/output error.
  * @retval <otherwise> Any other value will not be returned.
int f(void);
  * @brief Creates an object.
  * @retval NULL Not enough resources to create an object.
  * @retval <object> Pointer to created object.
T *create(void);
We may also use "[object]" or "{object}" or "object" or whatever.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
