'pax' is missing from list of required-packages, for host setup, for Arch Linux, in the documentation
Vaibhav Gupta vaibhavgupta40 at gmail.com
Fri Feb 22 08:30:05 UTC 2019
I will create patch and send it to mailing list.
On Fri, 22 Feb, 2019, 1:02 PM Sebastian Huber <
sebastian.huber at embedded-brains.de wrote:
> On 21/02/2019 22:01, Chris Johns wrote:
> > On 22/2/19 1:25 am, Vaibhav Gupta wrote:
> >> The *pax* package is not installed by default in Arch Linux. Moreover
> it is also
> >> not present in its official repository. We need to clone, build and
> install it
> >> from Arch User Repository (AUR).
> > That seems unusual because it is defined here ..
> > https://pubs.opengroup.org/onlinepubs/009695399/utilities/pax.html
> It is not installed by default on all Linux distributions I worked with.
> Maybe we should just check in the archive used by the test suite and not
> use pax at all. We want to test RTEMS and not the host pax program.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190222/231c5baf/attachment-0002.html>
