[PATCH] bsp/lpc1768_mbed: Disable unsupported tests
Mon Feb 25 23:03:38 UTC 2019
On Mon, Feb 25, 2019 at 4:58 PM Chris Johns <chrisj at rtems.org> wrote:
> On 26/2/19 9:07 am, Joel Sherrill wrote:
> > On Mon, Feb 25, 2019 at 3:31 PM Chris Johns <chrisj at rtems.org
> > <mailto:chrisj at rtems.org>> wrote:
> >     On 26/2/19 4:52 am, Joel Sherrill wrote:
> >     > To follow up, I built lm4f120 with OPERATION_COUNT=10 and the
> failure set
> >     > dropped to these:
> >     > gmake[5]: *** [capture.exe] Error 1
> >     > gmake[5]: *** [loopback.exe] Error 1
> >     > gmake[5]: *** [block08.exe] Error 1
> >     > gmake[5]: *** [top.exe] Error 1
> >     > gmake[5]: *** [sp47.exe] Error 1
> >     > gmake[5]: *** [sp71.exe] Error 1
> >     > gmake[5]: *** [sptimecounter02.exe] Error 1
> >     > gmake[5]: *** [sptimecounter03.exe] Error 1
> >     > gmake[5]: *** [psxconfig01.exe] Error 1
> >     > gmake[5]: *** [tm21.exe] Error 1
> >     > gmake[5]: *** [tmcontext01.exe] Error 1
> >     This looks better. What does the `OPERATION_COUNT` do to effect the
> link size?
> > It used to do nothing to impact the link size. :)
> >     I am wondering how a change to a statically initialised workspace
> Sebastian
> >     raised and the OPERATION_COUNT interact.
> > OPERATION_COUNT is usually the number of objects (e.g. tasks,
> semaphores,
> > etc) created so it is the maximum object count. For example, tm03 has
> this:
> > https://git.rtems.org/rtems/tree/testsuites/tmtests/tm03/system.h#n29
> > |#define CONFIGURE_MAXIMUM_TASKS (3 + OPERATION_COUNT) |
> > So when Sebastian changed this,  it went from a run-time to a link time
> failure.
> Ah ok, it is nice to see the error on these targets at link time.
> > The intent of OPERATION_COUNT was to be able to scale the timing tests
> down
> > to the hardware platform. Dropping OPERATION_COUNT to 10 for these BSPs
> > will resolve almost all of the tm and psxtm linking issues from what I
> can tell.
> What about a way to set this value in the `.tcfg` files and then provide
> it on
> the command line as a compile option?
This would be awesome! OPERATION_COUNT is an area where our old
build system person didn't want to tread. Much like the entire tcfg system.
--joel
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190225/c30c9b88/attachment-0002.html>
