GNU ld --wrap limitations
Mon Jan 14 09:22:44 UTC 2019
Hello,
while testing the event recording with the libbsd I noticed a GNU ld
--wrap limitation:
https://www.sourceware.org/ml/binutils/2018-12/msg00210.html
It turned out that the wrapping doesn't work for references internal to
a translation unit. My hope was that the RTEMS Trace Linker doesn't have
this limitation, but the documentation says (user manual):
"The trace linker’s major role is to wrap functions in the existing
executable with trace code. The
directions on how to wrap application functions is provided by the
generator configuration. The
wrapping function uses a GNU linker option called –wrap=symbol."
In the libbsd a lot of things are done through function pointer
assignments, e.g.
static struct netisr_handler ip_nh = {
     .nh_name = "ip",
     .nh_handler = ip_input,
     .nh_proto = NETISR_IP,
#ifdef    RSS
     .nh_m2cpuid = rss_soft_m2cpuid_v4,
     .nh_policy = NETISR_POLICY_CPU,
     .nh_dispatch = NETISR_DISPATCH_HYBRID,
#else
     .nh_policy = NETISR_POLICY_FLOW,
#endif
or
  * Perform common duties while attaching to interface list
void
ether_ifattach(struct ifnet *ifp, const u_int8_t *lla)
     int i;
     struct ifaddr *ifa;
     struct sockaddr_dl *sdl;
     ifp->if_addrlen = ETHER_ADDR_LEN;
     ifp->if_hdrlen = ETHER_HDR_LEN;
     if_attach(ifp);
     ifp->if_mtu = ETHERMTU;
     ifp->if_output = ether_output;
     ifp->if_input = ether_input;
This makes the tracing quite ineffective in this area.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
