[PATCH v3 1/2] Add Testsuite for PSXINTTYPES01
Vaibhav Gupta vaibhavgupta40 at gmail.com
Thu Jun 13 17:50:29 UTC 2019
 testsuites/psxtests/Makefile.am               |   7 +
 testsuites/psxtests/configure.ac              |   1 +
 testsuites/psxtests/psxinttypes01/init.c      | 233 ++++++++++++++++++
 .../psxtests/psxinttypes01/psxinttypes01.doc  |  70 ++++++
 .../psxtests/psxinttypes01/psxinttypes01.scn  |  44 ++++
 5 files changed, 355 insertions(+)
 create mode 100644 testsuites/psxtests/psxinttypes01/init.c
 create mode 100644 testsuites/psxtests/psxinttypes01/psxinttypes01.doc
 create mode 100644 testsuites/psxtests/psxinttypes01/psxinttypes01.scn
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index 1e354c0df7..59c9f2085b 100755
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -523,6 +523,13 @@ psxintrcritical01_CPPFLAGS = $(AM_CPPFLAGS) \
 endif
 endif
+if TEST_psxinttypes01
+psx_tests += psxinttypes01
+psxinttypes01_SOURCES = psxinttypes01/init.c
+psxinttypes01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxinttypes01) \
+       $(support_includes)
+endif
 if HAS_POSIX
 if TEST_psxitimer
 psx_tests += psxitimer
diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
index cdd6ee7e4e..85559e4aa5 100644
--- a/testsuites/psxtests/configure.ac
+++ b/testsuites/psxtests/configure.ac
@@ -91,6 +91,7 @@ RTEMS_TEST_CHECK([psxid01])
 RTEMS_TEST_CHECK([psximfs01])
 RTEMS_TEST_CHECK([psximfs02])
 RTEMS_TEST_CHECK([psxintrcritical01])
+RTEMS_TEST_CHECK([psxinttypes01])
 RTEMS_TEST_CHECK([psxitimer])
 RTEMS_TEST_CHECK([psxkey01])
 RTEMS_TEST_CHECK([psxkey02])
diff --git a/testsuites/psxtests/psxinttypes01/init.c b/testsuites/psxtests/psxinttypes01/init.c
new file mode 100644
index 0000000000..8eafae11ac
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes01/init.c
@@ -0,0 +1,233 @@
+ *  @file
+ *  @brief Test suite for inttypes.h methods
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2019, Aditya Upadhyay and Vaibhav Gupta
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/test.h>
+#include <inttypes.h>
+#include <stdio.h>
+#include <errno.h>
+#include <tmacros.h>
+#include <stdint.h>
+#include <stddef.h>
+const char rtems_test_name[] = "PSXINTTYPE 01";
+/* forward declarations to avoid warnings */
+rtems_task Init(rtems_task_argument ignored);
+  int       base            = 10;
+  int       invalid_base    = 40;
+  char     *nptr1_p         = "123abc";				//char* pointing to string with positive number
+  char 	   *nptr1_p_errange = "9999999999999999999999";         //char* pointing to string with positive number that is out of range
+  char     *nptr1_n         = "-123abc";			//char* pointing to string with negative number
+  char 	   *nptr1_n_errange = "-9999999999999999999999";	//char* pointing to string with negative number that is out of range
+  char     *endptr1         = NULL;
+  wchar_t  *nptr2_p         = L"123junk";			//wchar_t* pointing to string with positive number
+  wchar_t  *nptr2_p_errange = L"9999999999999999999999";	//wchar_t* pointing to string with positive number that is out of range
+  wchar_t  *nptr2_n         = L"-123junk";			//wchar_t* pointing to string with negative number
+  wchar_t  *nptr2_n_errange = L"-9999999999999999999999";	//wchar_t* pointing to string with negative number that is out of range
+  wchar_t  *endptr2         = NULL;
+  intmax_t  result_strtoimax;
+  uintmax_t result_strtoumax;
+  TEST_BEGIN();
+  /*Test for strtoimax  */
+  puts( "\nstrtoimax Testcases...." );
+  puts( "Valid Inputs - Positive Number" );
+  result_strtoimax = strtoimax( nptr1_p, &endptr1, base );
+  rtems_test_assert( result_strtoimax == 123 );
+  puts( "Final string pointed by endptr" );
+  rtems_test_assert( endptr1 == ( nptr1_p + 3 ) );
+  puts( "Valid Inputs - Negative Number" );
+  result_strtoimax = strtoimax( nptr1_n, &endptr1, base );
+  rtems_test_assert( result_strtoimax == -123 );
+  rtems_test_assert( endptr1 == ( nptr1_n + 4 ) );
+  puts( "Valid Input - Positive Number - Number out of Range" );
+  result_strtoimax = strtoimax( nptr1_p_errange, &endptr1, base );
+  rtems_test_assert( result_strtoimax == INTMAX_MAX );
+  rtems_test_assert( errno == ERANGE );
+  puts( "Valid Input - Negative Number - Number out of Range" );
+  result_strtoimax = strtoimax( nptr1_n_errange, &endptr1, base );
+  rtems_test_assert( result_strtoimax == INTMAX_MIN );
+  puts( "Invalid Input - Send NULL Pointer" );
+  result_strtoimax = strtoimax( NULL, &endptr1, base );
+  rtems_test_assert( result_strtoimax == 0 );
+  rtems_test_assert( errno == EINVAL );
+  puts( "Invalid Input - Invalid base - Use base = 40" );
+  result_strtoimax = strtoimax( nptr1_p, &endptr1, invalid_base );
+  /*Test for strtoumax  */
+  puts( "\nstrtoumax Testcases...." );
+  result_strtoumax = strtoumax( nptr1_p, &endptr1, base );
+  rtems_test_assert( result_strtoumax ==123 );
+  result_strtoumax = strtoumax( nptr1_n, &endptr1, base );
+  rtems_test_assert( result_strtoumax != 0 );
+  result_strtoumax = strtoumax( nptr1_p_errange, &endptr1, base );
+  rtems_test_assert( result_strtoumax == UINTMAX_MAX );
+  result_strtoumax = strtoumax( nptr1_n_errange, &endptr1, base );
+  result_strtoumax = strtoumax( NULL, &endptr1, base );
+  rtems_test_assert( result_strtoumax == 0 );
+  result_strtoumax = strtoumax( nptr1_p, &endptr1, invalid_base );
+  /*Test for wcstoimax  */
+  puts( "\nwcstoimax Testcases...." );
+  result_strtoimax = wcstoimax( nptr2_p, &endptr2, base );
+  rtems_test_assert( endptr2 == ( nptr2_p + 3 ) );
+  result_strtoimax = wcstoimax( nptr2_n, &endptr2, base );
+  rtems_test_assert( endptr2 == ( nptr2_n + 4 ) );
+  result_strtoimax = wcstoimax( nptr2_p_errange, &endptr2, base );
+  result_strtoimax = wcstoimax( nptr2_n_errange, &endptr2, base );
+  rtems_test_assert( result_strtoimax != 0 );
+  result_strtoimax = wcstoimax( NULL, &endptr2, base );
+  result_strtoimax = wcstoimax( nptr2_p, &endptr2, invalid_base );
+  /*Test for wcstoumax  */
+  puts( "\nwcstoumax Testcases...." );
+  result_strtoumax = wcstoumax( nptr2_p, &endptr2, base );
+  rtems_test_assert( result_strtoumax == 123 );
+  result_strtoumax = wcstoumax( nptr2_n, &endptr2, base );
+  result_strtoumax = wcstoumax( nptr2_p_errange, &endptr2, base );
+  result_strtoumax = wcstoumax( nptr2_n_errange, &endptr2, base );
+  result_strtoumax = wcstoumax( NULL, &endptr2, base );
+  result_strtoumax = wcstoumax( nptr2_p, &endptr2, invalid_base );
+  TEST_END();
+  rtems_test_exit(0);
+/* NOTICE: the clock driver is explicitly disabled */
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS            1
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#include <rtems/confdefs.h>
diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.doc b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
index 0000000000..b5fd8e6d0e
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
@@ -0,0 +1,70 @@
+ * Copyright (C) 2019, Vaibhav Gupta
+ * are met:
+This File describes the concepts tested by this test suite.
+inttypes.h - fixed size integer types
+test suite name: PSXINTTYPE 01
+- Checks for invalid base value
+- Checks for Strtoimax Testcases
+	- checks for output for string having a positive number
+	- checks for output for string having a negative number
+	- checks for output for string having a positive number - Number Out of Range
+	- checks for output for string having a negative number - Number Out of Range
+	- checks for final string pointed by endptr
+	- checks for output for invalid argument - NULL Pointer
+	- checks for output for invalid argument - Invalid Base
+- Checks for Strtoumax Test Cases
+- Checks for Wcstoimax Testcases
+- Checks for Wcstoumax Testcases
diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.scn b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
index 0000000000..33e82428f1
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
@@ -0,0 +1,44 @@
+*** PSXINTTYPE 01 TEST ***
+strtoimax Testcases....
+Valid Inputs - Positive Number
+Final string pointed by endptr
+Valid Inputs - Negative Number
+Valid Input - Positive Number - Number out of Range
+Valid Input - Negative Number - Number out of Range
+Invalid Input - Send NULL Pointer
+Invalid Input - Invalid base - Use base = 40
+strtoumax Testcases....
+wcstoimax Testcases....
+wcstoumax Testcases....
+*** END OF PSXINTTYPE 01 TEST ***
2.21.0
