[PATCH] CTF TSDL
Ravindra Meena rmeena840 at gmail.com
Fri Jun 14 11:21:26 UTC 2019
 misc/CTF/record-ctf.ref | 54 +++++++++++++++++++++++++++++++++++++++++++++++++
 1 file changed, 54 insertions(+)
 create mode 100644 misc/CTF/record-ctf.ref
diff --git a/misc/CTF/record-ctf.ref b/misc/CTF/record-ctf.ref
new file mode 100644
index 0000000..a27757c
--- /dev/null
+++ b/misc/CTF/record-ctf.ref
@@ -0,0 +1,54 @@
+/* CTF 1.8 */
+typealias integer { size = 8; align = 8; signed = false; } := uint8_t;
+typealias integer { size = 16; align = 8; signed = false; } := uint16_t;
+typealias integer { size = 32; align = 8; signed = false; } := uint32_t;
+typealias integer { size = 64; align = 8; signed = false; } := uint64_t;
+typealias integer { size = 5; align = 1; signed = false; } := uint5_t;
+typealias integer { size = 27; align = 1; signed = false; } := uint27_t;
+trace {
+    major = 1;
+    minor = 8;
+    byte_order = le;
+    packet.header := struct {
+        uint32_t magic;
+        uint32_t stream_id;
+clock {
+    name = ctf_clock;
+    freq = 1000;
+    offset_s = 1421703448;
+    size = 64;
+    map = clock.ctf_clock.value;
+} := ctf_clock_int_t;
+stream {
+    id = 0;
+    packet.context := struct {
+		ctf_clock_int_t timestamp;
+		uint32_t cpu;
+		uint32_t event;
+		uint64_t data;
+    event.header := struct {
+        uint32_t id;
+event {
+    id = 0;
+    name = "ctf_event";
+    stream_id = 0;
+    fields := struct {
+        uint32_t a;
+        uint16_t b;
+        string c;
2.7.4
