[PATCH 2/6] TDA19988 : Port to RTEMS
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Sun Jun 30 15:33:38 UTC 2019
The following patchset has only the port commits, the commits to import
are pushed to Github and the links are as follows:
[PATCH 1/6] :
https://github.com/thelunatic/rtems-libbsd/commit/fa8900b30f5b41611ddc16e5b386a6b8b443675a
[PATCH 3/6] :
https://github.com/thelunatic/rtems-libbsd/commit/4f1cde1ef64e4a401cf4acd71bc5e681628fb3ed
[PATCH 5/6] :
https://github.com/thelunatic/rtems-libbsd/commit/efe23128b1cf39bdd75040067c95d87c05ae7f00
On Sun, Jun 30, 2019 at 8:59 PM Vijay Kumar Banerjee <
vijaykumar9597 at gmail.com> wrote:
>  Makefile.todo                                 | 27 ++++++
>  buildset/default.ini                          |  1 +
>  libbsd.py                                     | 46 ++++++++++
>  rtemsbsd/include/bsp/nexus-devices.h          |  1 +
>  .../machine/rtems-bsd-kernel-namespace.h      | 65 +++++++++++++
>  rtemsbsd/include/rtems/bsd/local/clknode_if.h | 92 +++++++++++++++++++
>  rtemsbsd/include/rtems/bsd/local/hdmi_if.h    | 71 ++++++++++++++
>  .../include/rtems/bsd/local/opt_videomode.h   |  0
>  rtemsbsd/local/clknode_if.c                   | 40 ++++++++
>  rtemsbsd/local/hdmi_if.c                      | 35 +++++++
>  10 files changed, 378 insertions(+)
>  create mode 100644 rtemsbsd/include/rtems/bsd/local/clknode_if.h
>  create mode 100644 rtemsbsd/include/rtems/bsd/local/hdmi_if.h
>  create mode 100644 rtemsbsd/include/rtems/bsd/local/opt_videomode.h
>  create mode 100644 rtemsbsd/local/clknode_if.c
>  create mode 100644 rtemsbsd/local/hdmi_if.c
> diff --git a/Makefile.todo b/Makefile.todo
> index 42bedc15..358d6956 100644
> --- a/Makefile.todo
> +++ b/Makefile.todo
> @@ -47,6 +47,10 @@ GENERATED += $(LOCAL_INC)/gpiobus_if.h
>  GENERATED += $(LOCAL_SRC)/gpiobus_if.c
>  GENERATED += $(LOCAL_INC)/iicbus_if.h
>  GENERATED += $(LOCAL_SRC)/iicbus_if.c
> +GENERATED += $(LOCAL_INC)/clknode_if.h
> +GENERATED += $(LOCAL_SRC)/clknode_if.c
> +GENERATED += $(LOCAL_INC)/hdmi_if.h
> +GENERATED += $(LOCAL_SRC)/hdmi_if.c
>  GENERATED += rtemsbsd/include/machine/rtems-bsd-regdomain.h
>  GENERATED += rtemsbsd/rtems/rtems-bsd-regdomain.c
> @@ -239,6 +243,29 @@ $(LOCAL_SRC)/sdhci_if.c:
> $(FREEBSD_SRC)/sys/dev/sdhci/sdhci_if.m
>             -e 's|#include "sdhci_if.h"|#include
> <rtems/bsd/local/sdhci_if.h>|'
>         mv sdhci_if.c $@
> +$(LOCAL_INC)/clknode_if.h: $(FREEBSD_SRC)/sys/dev/extres/clk/clknode_if.m
> +       awk -f $(TOOLS)/makeobjops.awk $< -h
> +       mv clknode_if.h $@
> +$(LOCAL_SRC)/clknode_if.c: $(FREEBSD_SRC)/sys/dev/extres/clk/clknode_if.m
> +       awk -f $(TOOLS)/makeobjops.awk $< -c
> +       sed -i clknode_if.c \
> +           -e '1 i\#include <machine/rtems-bsd-kernel-space.h>\n' \
> +           -e 's|#include "clknode_if.h"|#include
> <rtems/bsd/local/clknode_if.h>|'
> +       mv clknode_if.c $@
> +$(LOCAL_INC)/hdmi_if.h: $(FREEBSD_SRC)/sys/dev/hdmi/hdmi_if.m
> +       mv hdmi_if.h $@
> +$(LOCAL_SRC)/hdmi_if.c: $(FREEBSD_SRC)/sys/dev/hdmi/hdmi_if.m
> +       sed -i hdmi_if.c \
> +           -e 's|#include "hdmi_if.h"|#include
> <rtems/bsd/local/hdmi_if.h>|'
> +       mv hdmi_if.c $@
>  $(LOCAL_SRC)/gpio_if.c: $(FREEBSD_SRC)/sys/dev/gpio/gpio_if.m
>         mv gpio_if.c $@
> diff --git a/buildset/default.ini b/buildset/default.ini
> index 4acb2368..1d052a48 100644
> --- a/buildset/default.ini
> +++ b/buildset/default.ini
> @@ -37,6 +37,7 @@ dev_usb_storage = on
>  dev_usb_wlan = off
>  dev_wlan_rtwn = off
>  iic = on
> +display = on
>  dhcpcd = on
>  dpaa = on
>  evdev = on
> diff --git a/libbsd.py b/libbsd.py
> index 12d4c2ed..b21ddccf 100644
> --- a/libbsd.py
> +++ b/libbsd.py
> @@ -777,6 +777,51 @@ class iic(builder.Module):
>              mm.generator['source']()
> +# DISPLAY
> +class display(builder.Module):
> +    def __init__(self, manager):
> +        super(display, self).__init__(manager, type(self).__name__)
> +    def generate(self):
> +        mm = self.manager
> +        self.addKernelSpaceHeaderFiles(
> +                'sys/dev/extres/clk/clk.h',
> +                'sys/dev/hdmi/dwc_hdmi.h',
> +                'sys/dev/hdmi/dwc_hdmireg.h',
> +                'sys/dev/videomode/videomode.h',
> +                'sys/dev/videomode/edidvar.h',
> +                'sys/dev/videomode/edidreg.h',
> +                'sys/dev/videomode/ediddevs.h',
> +                'sys/dev/videomode/ediddevs_data.h',
> +                'sys/dev/videomode/vesagtf.h',
> +        self.addKernelSpaceSourceFiles(
> +                'sys/arm/ti/am335x/tda19988.c',
> +                'sys/dev/hdmi/dwc_hdmi.c',
> +                'sys/dev/hdmi/dwc_hdmi_fdt.c',
> +                'sys/dev/extres/clk/clk.c',
> +                'sys/dev/videomode/pickmode.c',
> +                'sys/dev/videomode/edid.c',
> +                'sys/dev/videomode/vesagtf.c',
> +                'sys/dev/videomode/videomode.c',
> +            mm.generator['source']()
> +        self.addRTEMSSourceFiles(
> +                'local/clknode_if.c',
> +                'local/hdmi_if.c',
>  # USB
> @@ -5134,6 +5179,7 @@ def load(mm):
>      mm.addModule(dev_input(mm))
>      mm.addModule(evdev(mm))
>      mm.addModule(iic(mm))
> +    mm.addModule(display(mm))
>      mm.addModule(dev_usb(mm))
>      mm.addModule(dev_usb_controller(mm))
> diff --git a/rtemsbsd/include/bsp/nexus-devices.h
> b/rtemsbsd/include/bsp/nexus-devices.h
> index 97f6d2b2..3ec136ae 100644
> --- a/rtemsbsd/include/bsp/nexus-devices.h
> +++ b/rtemsbsd/include/bsp/nexus-devices.h
> @@ -64,6 +64,7 @@ SYSINIT_DRIVER_REFERENCE(ukphy, miibus);
>  SYSINIT_DRIVER_REFERENCE(rtems_i2c, simplebus);
>  SYSINIT_DRIVER_REFERENCE(ofw_iicbus, rtems_i2c);
>  SYSINIT_DRIVER_REFERENCE(iic, iicbus);
> +SYSINIT_DRIVER_REFERENCE(tda, iicbus);
>  SYSINIT_DRIVER_REFERENCE(iicbus, rtems_i2c);
>  #ifdef RTEMS_BSD_MODULE_NET80211
>  SYSINIT_DRIVER_REFERENCE(rtwn_usb, uhub);
> diff --git a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
> b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
> index 235c9886..bef9f411 100644
> --- a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
> +++ b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
> @@ -563,7 +563,53 @@
>  #define        clean_unrhdrl _bsd_clean_unrhdrl
>  #define        ClearCheckNewLink _bsd_ClearCheckNewLink
>  #define        clear_unrhdr _bsd_clear_unrhdr
> +#define        clk_disable _bsd_clk_disable
> +#define        clkdom_create _bsd_clkdom_create
> +#define        clkdom_dump _bsd_clkdom_dump
> +#define        clkdom_finit _bsd_clkdom_finit
> +#define        clkdom_get_by_dev _bsd_clkdom_get_by_dev
> +#define        clkdom_set_ofw_mapper _bsd_clkdom_set_ofw_mapper
> +#define        clkdom_unlock _bsd_clkdom_unlock
> +#define        clkdom_xlock _bsd_clkdom_xlock
> +#define        clk_enable _bsd_clk_enable
> +#define        clk_get_by_id _bsd_clk_get_by_id
> +#define        clk_get_by_name _bsd_clk_get_by_name
> +#define        clk_get_by_ofw_index _bsd_clk_get_by_ofw_index
> +#define        clk_get_by_ofw_index_prop _bsd_clk_get_by_ofw_index_prop
> +#define        clk_get_by_ofw_name _bsd_clk_get_by_ofw_name
> +#define        clk_get_freq _bsd_clk_get_freq
> +#define        clk_get_name _bsd_clk_get_name
> +#define        clk_get_parent _bsd_clk_get_parent
>  #define        clk_intr_event _bsd_clk_intr_event
> +#define        clknode_class _bsd_clknode_class
> +#define        clknode_create _bsd_clknode_create
> +#define        clknode_disable _bsd_clknode_disable
> +#define        clknode_enable _bsd_clknode_enable
> +#define        clknode_find_by_id _bsd_clknode_find_by_id
> +#define        clknode_find_by_name _bsd_clknode_find_by_name
> +#define        clknode_get_device _bsd_clknode_get_device
> +#define        clknode_get_flags _bsd_clknode_get_flags
> +#define        clknode_get_freq _bsd_clknode_get_freq
> +#define        clknode_get_name _bsd_clknode_get_name
> +#define        clknode_get_parent _bsd_clknode_get_parent
> +#define        clknode_get_parent_idx _bsd_clknode_get_parent_idx
> +#define        clknode_get_parent_names _bsd_clknode_get_parent_names
> +#define        clknode_get_parents_num _bsd_clknode_get_parents_num
> +#define        clknode_get_softc _bsd_clknode_get_softc
> +#define        clknode_init_parent_idx _bsd_clknode_init_parent_idx
> +#define        clknode_register _bsd_clknode_register
> +#define        clknode_set_freq _bsd_clknode_set_freq
> +#define        clknode_set_parent_by_idx _bsd_clknode_set_parent_by_idx
> +#define        clknode_set_parent_by_name _bsd_clknode_set_parent_by_name
> +#define        clknode_stop _bsd_clknode_stop
> +#define        clk_parse_ofw_clk_name _bsd_clk_parse_ofw_clk_name
> +#define        clk_parse_ofw_out_names _bsd_clk_parse_ofw_out_names
> +#define        clk_release _bsd_clk_release
> +#define        clk_set_assigned _bsd_clk_set_assigned
> +#define        clk_set_freq _bsd_clk_set_freq
> +#define        clk_set_parent_by_clk _bsd_clk_set_parent_by_clk
> +#define        clk_stop _bsd_clk_stop
> +#define        clk_test_freq _bsd_clk_test_freq
>  #define        comp_algo_deflate _bsd_comp_algo_deflate
>  #define        comp_algorithm_lookup _bsd_comp_algorithm_lookup
>  #define        config_intrhook_disestablish
> _bsd_config_intrhook_disestablish
> @@ -775,6 +821,9 @@
>  #define        drbr_needs_enqueue_drv _bsd_drbr_needs_enqueue_drv
>  #define        driver_module_handler _bsd_driver_module_handler
>  #define        dwc_driver _bsd_dwc_driver
> +#define        dwc_hdmi_get_edid _bsd_dwc_hdmi_get_edid
> +#define        dwc_hdmi_init _bsd_dwc_hdmi_init
> +#define        dwc_hdmi_set_videomode _bsd_dwc_hdmi_set_videomode
>  #define        dwc_otg_attach _bsd_dwc_otg_attach
>  #define        dwc_otg_detach _bsd_dwc_otg_detach
>  #define        dwc_otg_driver _bsd_dwc_otg_driver
> @@ -1087,6 +1136,13 @@
>  #define        e1000_write_vfta_generic _bsd_e1000_write_vfta_generic
>  #define        e1000_write_vfta_i350 _bsd_e1000_write_vfta_i350
>  #define        e1000_write_xmdio_reg _bsd_e1000_write_xmdio_reg
> +#define        edid_is_valid _bsd_edid_is_valid
> +#define        edid_nproducts _bsd_edid_nproducts
> +#define        edid_nvendors _bsd_edid_nvendors
> +#define        edid_parse _bsd_edid_parse
> +#define        edid_print _bsd_edid_print
> +#define        edid_products _bsd_edid_products
> +#define        edid_vendors _bsd_edid_vendors
>  #define        ehci_detach _bsd_ehci_detach
>  #define        ehci_get_port_speed_hostc _bsd_ehci_get_port_speed_hostc
>  #define        ehci_get_port_speed_portsc _bsd_ehci_get_port_speed_portsc
> @@ -2732,6 +2788,7 @@
>  #define        m_checkalignment _bsd_m_checkalignment
>  #define        m_clget _bsd_m_clget
>  #define        m_cljget _bsd_m_cljget
> +#define        M_CLOCK _bsd_M_CLOCK
>  #define        m_collapse _bsd_m_collapse
>  #define        m_copyback _bsd_m_copyback
>  #define        m_copydata _bsd_m_copydata
> @@ -3442,6 +3499,8 @@
>  #define        pgsigio _bsd_pgsigio
>  #define        phashinit _bsd_phashinit
>  #define        phashinit_flags _bsd_phashinit_flags
> +#define        pick_mode_by_dotclock _bsd_pick_mode_by_dotclock
> +#define        pick_mode_by_ref _bsd_pick_mode_by_ref
>  #define        pipe_dtor _bsd_pipe_dtor
>  #define        pipe_named_ctor _bsd_pipe_named_ctor
>  #define        pipeselwakeup _bsd_pipeselwakeup
> @@ -4614,6 +4673,7 @@
>  #define        soreceive_generic _bsd_soreceive_generic
>  #define        soreserve _bsd_soreserve
>  #define        sorflush _bsd_sorflush
> +#define        sort_modes _bsd_sort_modes
>  #define        sosend _bsd_sosend
>  #define        sosend_dgram _bsd_sosend_dgram
>  #define        sosend_generic _bsd_sosend_generic
> @@ -4722,6 +4782,7 @@
>  #define        sysctl_handle_uma_zone_max _bsd_sysctl_handle_uma_zone_max
>  #define        sysctl___hw _bsd_sysctl___hw
>  #define        sysctl___hw_bus _bsd_sysctl___hw_bus
> +#define        sysctl___hw_clock _bsd_sysctl___hw_clock
>  #define        sysctl___hw_fdt _bsd_sysctl___hw_fdt
>  #define        sysctl___hw_pci _bsd_sysctl___hw_pci
>  #define        sysctl___hw_sdhci _bsd_sysctl___hw_sdhci
> @@ -5450,6 +5511,10 @@
>  #define        uuid_ether_add _bsd_uuid_ether_add
>  #define        uuid_ether_del _bsd_uuid_ether_del
>  #define        vht80_chan_ranges _bsd_vht80_chan_ranges
> +#define        vesagtf_mode _bsd_vesagtf_mode
> +#define        vesagtf_mode_params _bsd_vesagtf_mode_params
> +#define        videomode_count _bsd_videomode_count
> +#define        videomode_list _bsd_videomode_list
>  #define        vlan_cookie_p _bsd_vlan_cookie_p
>  #define        vlan_devat_p _bsd_vlan_devat_p
>  #define        vlan_input_p _bsd_vlan_input_p
> diff --git a/rtemsbsd/include/rtems/bsd/local/clknode_if.h
> b/rtemsbsd/include/rtems/bsd/local/clknode_if.h
> new file mode 100644
> index 00000000..97f4c956
> --- /dev/null
> +++ b/rtemsbsd/include/rtems/bsd/local/clknode_if.h
> @@ -0,0 +1,92 @@
> + * This file is @generated automatically.
> + * Do not modify anything in here by hand.
> + * Created from source file
> + *   freebsd-org/sys/dev/extres/clk/clknode_if.m
> + * with
> + *   makeobjops.awk
> + * See the source file for legal information
> +#ifndef _clknode_if_h_
> +#define _clknode_if_h_
> +struct clknode;
> +/** @brief Unique descriptor for the CLKNODE_INIT() method */
> +extern struct kobjop_desc clknode_init_desc;
> +/** @brief A function implementing the CLKNODE_INIT() method */
> +typedef int clknode_init_t(struct clknode *clk, device_t dev);
> +static __inline int CLKNODE_INIT(struct clknode *clk, device_t dev)
> +       kobjop_t _m;
> +       int rc;
> +       KOBJOPLOOKUP(((kobj_t)clk)->ops,clknode_init);
> +       rc = ((clknode_init_t *) _m)(clk, dev);
> +       return (rc);
> +/** @brief Unique descriptor for the CLKNODE_RECALC_FREQ() method */
> +extern struct kobjop_desc clknode_recalc_freq_desc;
> +/** @brief A function implementing the CLKNODE_RECALC_FREQ() method */
> +typedef int clknode_recalc_freq_t(struct clknode *clk, uint64_t *freq);
> +static __inline int CLKNODE_RECALC_FREQ(struct clknode *clk, uint64_t
> *freq)
> +       kobjop_t _m;
> +       int rc;
> +       KOBJOPLOOKUP(((kobj_t)clk)->ops,clknode_recalc_freq);
> +       rc = ((clknode_recalc_freq_t *) _m)(clk, freq);
> +       return (rc);
> +/** @brief Unique descriptor for the CLKNODE_SET_FREQ() method */
> +extern struct kobjop_desc clknode_set_freq_desc;
> +/** @brief A function implementing the CLKNODE_SET_FREQ() method */
> +typedef int clknode_set_freq_t(struct clknode *clk, uint64_t fin,
> +                               uint64_t *fout, int flags, int *done);
> +static __inline int CLKNODE_SET_FREQ(struct clknode *clk, uint64_t fin,
> +       kobjop_t _m;
> +       int rc;
> +       KOBJOPLOOKUP(((kobj_t)clk)->ops,clknode_set_freq);
> +       rc = ((clknode_set_freq_t *) _m)(clk, fin, fout, flags, done);
> +       return (rc);
> +/** @brief Unique descriptor for the CLKNODE_SET_GATE() method */
> +extern struct kobjop_desc clknode_set_gate_desc;
> +/** @brief A function implementing the CLKNODE_SET_GATE() method */
> +typedef int clknode_set_gate_t(struct clknode *clk, bool enable);
> +static __inline int CLKNODE_SET_GATE(struct clknode *clk, bool enable)
> +       kobjop_t _m;
> +       int rc;
> +       KOBJOPLOOKUP(((kobj_t)clk)->ops,clknode_set_gate);
> +       rc = ((clknode_set_gate_t *) _m)(clk, enable);
> +       return (rc);
> +/** @brief Unique descriptor for the CLKNODE_SET_MUX() method */
> +extern struct kobjop_desc clknode_set_mux_desc;
> +/** @brief A function implementing the CLKNODE_SET_MUX() method */
> +typedef int clknode_set_mux_t(struct clknode *clk, int idx);
> +static __inline int CLKNODE_SET_MUX(struct clknode *clk, int idx)
> +       kobjop_t _m;
> +       int rc;
> +       KOBJOPLOOKUP(((kobj_t)clk)->ops,clknode_set_mux);
> +       rc = ((clknode_set_mux_t *) _m)(clk, idx);
> +       return (rc);
> +#endif /* _clknode_if_h_ */
> diff --git a/rtemsbsd/include/rtems/bsd/local/hdmi_if.h
> b/rtemsbsd/include/rtems/bsd/local/hdmi_if.h
> index 00000000..fc23c801
> --- /dev/null
> +++ b/rtemsbsd/include/rtems/bsd/local/hdmi_if.h
> @@ -0,0 +1,71 @@
> + *   freebsd-org/sys/dev/hdmi/hdmi_if.m
> + * with
> + *   makeobjops.awk
> +#ifndef _hdmi_if_h_
> +#define _hdmi_if_h_
> +#include <sys/eventhandler.h>
> +typedef void (*hdmi_event_hook)(void *, device_t, int);
> +EVENTHANDLER_DECLARE(hdmi_event, hdmi_event_hook);
> +#define HDMI_EVENT_CONNECTED   0
> +/** @brief Unique descriptor for the HDMI_GET_EDID() method */
> +extern struct kobjop_desc hdmi_get_edid_desc;
> +/** @brief A function implementing the HDMI_GET_EDID() method */
> +typedef int hdmi_get_edid_t(device_t dev, uint8_t **edid,
> +                            uint32_t *edid_length);
> +static __inline int HDMI_GET_EDID(device_t dev, uint8_t **edid,
> +       kobjop_t _m;
> +       int rc;
> +       KOBJOPLOOKUP(((kobj_t)dev)->ops,hdmi_get_edid);
> +       rc = ((hdmi_get_edid_t *) _m)(dev, edid, edid_length);
> +       return (rc);
> +/** @brief Unique descriptor for the HDMI_SET_VIDEOMODE() method */
> +extern struct kobjop_desc hdmi_set_videomode_desc;
> +/** @brief A function implementing the HDMI_SET_VIDEOMODE() method */
> +typedef int hdmi_set_videomode_t(device_t dev,
> +                                 const struct videomode *videomode);
> +static __inline int HDMI_SET_VIDEOMODE(device_t dev,
> +       kobjop_t _m;
> +       int rc;
> +       KOBJOPLOOKUP(((kobj_t)dev)->ops,hdmi_set_videomode);
> +       rc = ((hdmi_set_videomode_t *) _m)(dev, videomode);
> +       return (rc);
> +/** @brief Unique descriptor for the HDMI_ENABLE() method */
> +extern struct kobjop_desc hdmi_enable_desc;
> +/** @brief A function implementing the HDMI_ENABLE() method */
> +typedef int hdmi_enable_t(device_t dev, int onoff);
> +static __inline int HDMI_ENABLE(device_t dev, int onoff)
> +       kobjop_t _m;
> +       int rc;
> +       KOBJOPLOOKUP(((kobj_t)dev)->ops,hdmi_enable);
> +       rc = ((hdmi_enable_t *) _m)(dev, onoff);
> +       return (rc);
> +#endif /* _hdmi_if_h_ */
> diff --git a/rtemsbsd/include/rtems/bsd/local/opt_videomode.h
> b/rtemsbsd/include/rtems/bsd/local/opt_videomode.h
> index 00000000..e69de29b
> diff --git a/rtemsbsd/local/clknode_if.c b/rtemsbsd/local/clknode_if.c
> index 00000000..6f1c0ba3
> --- /dev/null
> +++ b/rtemsbsd/local/clknode_if.c
> @@ -0,0 +1,40 @@
> +#include <machine/rtems-bsd-kernel-space.h>
> + * with
> + *   makeobjops.awk
> +#include <sys/param.h>
> +#include <sys/queue.h>
> +#include <sys/kernel.h>
> +#include <sys/kobj.h>
> +#include <rtems/bsd/local/clknode_if.h>
> +struct kobjop_desc clknode_init_desc = {
> +       0, { &clknode_init_desc, (kobjop_t)kobj_error_method }
> +struct kobjop_desc clknode_recalc_freq_desc = {
> +       0, { &clknode_recalc_freq_desc, (kobjop_t)kobj_error_method }
> +struct kobjop_desc clknode_set_freq_desc = {
> +       0, { &clknode_set_freq_desc, (kobjop_t)kobj_error_method }
> +struct kobjop_desc clknode_set_gate_desc = {
> +       0, { &clknode_set_gate_desc, (kobjop_t)kobj_error_method }
> +struct kobjop_desc clknode_set_mux_desc = {
> +       0, { &clknode_set_mux_desc, (kobjop_t)kobj_error_method }
> diff --git a/rtemsbsd/local/hdmi_if.c b/rtemsbsd/local/hdmi_if.c
> index 00000000..847f7d4d
> --- /dev/null
> +++ b/rtemsbsd/local/hdmi_if.c
> @@ -0,0 +1,35 @@
> + * with
> + *   makeobjops.awk
> +#include <sys/bus.h>
> +#include <dev/videomode/videomode.h>
> +#include <dev/videomode/edidvar.h>
> +#include <rtems/bsd/local/hdmi_if.h>
> +struct kobjop_desc hdmi_get_edid_desc = {
> +       0, { &hdmi_get_edid_desc, (kobjop_t)kobj_error_method }
> +struct kobjop_desc hdmi_set_videomode_desc = {
> +       0, { &hdmi_set_videomode_desc, (kobjop_t)kobj_error_method }
> +struct kobjop_desc hdmi_enable_desc = {
> +       0, { &hdmi_enable_desc, (kobjop_t)kobj_error_method }
> 2.20.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190630/b585a823/attachment-0002.html>
