[PATCH 2/2] rcmd.c: Removed references to unsupported functions
Fri May 3 23:16:42 UTC 2019
On Fri, May 3, 2019, 6:04 PM Chris Johns <chrisj at rtems.org> wrote:
> On 4/5/19 7:44 am, Lou Woods wrote:
> > From: Lou Woods <Lou.Woods at OARCorp.com>
> > rcmdsh() and innetgr() are referenced by rcmd, but aren’t available
> > in libbsd and are unresolvable external symbols when libbsd.a is
> > processed by the RTL.
> Why does this not show up when we statically link?
> I wonder if this is related to separate sections where a function in a
> file is present but no used and it not linked but is with the RTL?
Statically linking an exe normally wouldn't have hit this unless you
referenced rcmd. Ld wouldn't have pulled it out of the library.
FWIW rcmdsh.* needs to be dropped out of the build. It requires fork/exec
so will never work.
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190503/96bbed70/attachment-0002.html>
