[PATCH 03/13] psxtmtests: Avoid build system defined defines
Fri Nov 8 14:02:51 UTC 2019
Update #3818.
 testsuites/psxtmtests/Makefile.am                  |  12 +-
 testsuites/psxtmtests/psxtmcond08/init.c           | 184 +--------------------
 .../psxtmtests/psxtmcond08/psxtmcond08impl.h       | 182 ++++++++++++++++++++
 testsuites/psxtmtests/psxtmcond09/init.c           |   2 +
 testsuites/psxtmtests/psxtmcond10/init.c           |   2 +
 5 files changed, 193 insertions(+), 189 deletions(-)
 create mode 100644 testsuites/psxtmtests/psxtmcond08/psxtmcond08impl.h
 create mode 100644 testsuites/psxtmtests/psxtmcond09/init.c
 create mode 100644 testsuites/psxtmtests/psxtmcond10/init.c
diff --git a/testsuites/psxtmtests/Makefile.am b/testsuites/psxtmtests/Makefile.am
index 88ee7f2495..fea5836a7f 100644
--- a/testsuites/psxtmtests/Makefile.am
+++ b/testsuites/psxtmtests/Makefile.am
@@ -184,29 +184,27 @@ psxtmcond08_SOURCES = psxtmcond08/init.c ../tmtests/include/timesys.h \
 	../support/src/tmtests_empty_function.c \
 	../support/src/tmtests_support.c
 psxtmcond08_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxtmcond08) \
-	$(support_includes) -I$(top_srcdir)/../tmtests/include -DUSE_WAIT
+	$(support_includes) -I$(top_srcdir)/../tmtests/include
 endif
 if TEST_psxtmcond09
 psxtm_tests += psxtmcond09
 psxtm_docs += psxtmcond09/psxtmcond09.doc
-psxtmcond09_SOURCES = psxtmcond08/init.c ../tmtests/include/timesys.h \
+psxtmcond09_SOURCES = psxtmcond09/init.c ../tmtests/include/timesys.h \
 psxtmcond09_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxtmcond09) \
-	$(support_includes) -I$(top_srcdir)/../tmtests/include \
-	-DUSE_TIMEDWAIT_WITH_VALUE
 endif
 if TEST_psxtmcond10
 psxtm_tests += psxtmcond10
 psxtm_docs += psxtmcond10/psxtmcond10.doc
-psxtmcond10_SOURCES = psxtmcond08/init.c ../tmtests/include/timesys.h \
+psxtmcond10_SOURCES = psxtmcond10/init.c ../tmtests/include/timesys.h \
 psxtmcond10_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxtmcond10) \
-	-DUSE_TIMEDWAIT_WAIT_VALUE_IN_PAST
 endif
 if TEST_psxtmkey01
diff --git a/testsuites/psxtmtests/psxtmcond08/init.c b/testsuites/psxtmtests/psxtmcond08/init.c
index 7faffe1246..c4fa9146e3 100644
--- a/testsuites/psxtmtests/psxtmcond08/init.c
+++ b/testsuites/psxtmtests/psxtmcond08/init.c
@@ -1,182 +1,2 @@
- *  COPYRIGHT (c) 1989-2013.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#if !defined(OPERATION_COUNT)
-#define OPERATION_COUNT 100
-#endif
-#if   defined(USE_WAIT)
-  #define TEST_NUMBER "08"
-  #define TEST_CASE "pthread_cond_wait: blocking"
-#elif defined(USE_TIMEDWAIT_WITH_VALUE)
-  #define TEST_NUMBER "09"
-  #define TEST_CASE "pthread_cond_timedwait: blocking"
-#elif defined(USE_TIMEDWAIT_WAIT_VALUE_IN_PAST)
-  #define TEST_NUMBER "10"
-  #define TEST_CASE "pthread_cond_timedwait: time in past error"
-#else
-  #error "How am I being compiled?"
-#endif
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <sys/time.h>
-#include <stdio.h>
-#include <time.h>
-#include <errno.h>
-#include <sched.h>
-#include <timesys.h>
-#include <tmacros.h>
-#include <rtems/btimer.h>
-#include "test_support.h"
-#include <pthread.h>
-const char rtems_test_name[] = "PSXTMCOND 08";
-/* forward declarations to avoid warnings */
-void *POSIX_Init(void *argument);
-void *Middle(void *argument);
-void *Low(void *argument);
-pthread_cond_t  CondID;
-pthread_mutex_t MutexID;
-struct timespec sleepTime;
-void *Low(
-  void *argument
-  uint32_t end_time;
-  end_time = benchmark_timer_read();
-  put_time(
-    TEST_CASE,
-    end_time,
-    OPERATION_COUNT,
-    0,
-    0
-  TEST_END();
-  rtems_test_exit( 0 );
-  return NULL;
-void *Middle(
-  void *argument
-  int             rc;
-  rc = pthread_mutex_lock(&MutexID);
-  rtems_test_assert( rc == 0 );
-  /* block and switch to another task here */
-  #if   defined(USE_WAIT)
-    rc = pthread_cond_wait( &CondID, &MutexID );
-  #elif defined(USE_TIMEDWAIT_WITH_VALUE)
-    /* adjust sleepTime to get something obviously in the future */
-    ++sleepTime.tv_sec;
-    rc = pthread_cond_timedwait( &CondID, &MutexID, &sleepTime );
-  #elif defined(USE_TIMEDWAIT_WAIT_VALUE_IN_PAST)
-      /* override sleepTime with something obviously in the past */
-      sleepTime.tv_sec = 0;
-      sleepTime.tv_nsec = 5;
-      /* this does all the work of timedwait but immediately returns */
-      rtems_test_assert(rc == ETIMEDOUT);
-      benchmark_timer_read();
-  #endif
-  pthread_mutex_unlock(&MutexID);
-  #if defined(USE_TIMEDWAIT_WAIT_VALUE_IN_PAST)
-     * In this case, unlock does not switch to another thread. so we need
-     * to explicitly yield. If we do not yield, then we will measure the
-     * time required to do an implicit pthread_exit() which is undesirable
-     * from a measurement viewpoint.
-    sched_yield();
-  #endif
-  return NULL;
-void *POSIX_Init(
-  void *argument
-  int             i;
-  int             status;
-  pthread_t       threadId;
-  int             rc;
-  struct timeval  tp;
-  TEST_BEGIN();
-  rc =  gettimeofday(&tp, NULL);
-  /* Convert from timeval to timespec */
-  sleepTime.tv_sec  = tp.tv_sec;
-  sleepTime.tv_nsec = tp.tv_usec * 1000;
-  rc = pthread_cond_init(&CondID, NULL);
-  rc = pthread_mutex_init(&MutexID, NULL);
-  for ( i=0 ; i < OPERATION_COUNT - 1 ; i++ ) {
-    status = pthread_create( &threadId, NULL, Middle, NULL );
-    rtems_test_assert( !status );
-  status = pthread_create( &threadId, NULL, Low, NULL );
-  /* start the timer and switch through all the other tasks */
-  benchmark_timer_initialize();
-  rc = pthread_mutex_unlock(&MutexID);
-  /* Should never return. */
-  return NULL;
-/* configuration information */
-#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
-#define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
-#define CONFIGURE_MAXIMUM_POSIX_THREADS     OPERATION_COUNT + 2
-#define CONFIGURE_POSIX_INIT_THREAD_TABLE
-#define CONFIGURE_INIT
-#include <rtems/confdefs.h>
-  /* end of file */
+#define USE_WAIT
+#include "psxtmcond08impl.h"
diff --git a/testsuites/psxtmtests/psxtmcond08/psxtmcond08impl.h b/testsuites/psxtmtests/psxtmcond08/psxtmcond08impl.h
new file mode 100644
index 0000000000..7faffe1246
--- /dev/null
+++ b/testsuites/psxtmtests/psxtmcond08/psxtmcond08impl.h
@@ -0,0 +1,182 @@
+ *  COPYRIGHT (c) 1989-2013.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#if !defined(OPERATION_COUNT)
+#define OPERATION_COUNT 100
+#endif
+#if   defined(USE_WAIT)
+  #define TEST_NUMBER "08"
+  #define TEST_CASE "pthread_cond_wait: blocking"
+#elif defined(USE_TIMEDWAIT_WITH_VALUE)
+  #define TEST_NUMBER "09"
+  #define TEST_CASE "pthread_cond_timedwait: blocking"
+#elif defined(USE_TIMEDWAIT_WAIT_VALUE_IN_PAST)
+  #define TEST_NUMBER "10"
+  #define TEST_CASE "pthread_cond_timedwait: time in past error"
+#else
+  #error "How am I being compiled?"
+#endif
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <sys/time.h>
+#include <stdio.h>
+#include <time.h>
+#include <errno.h>
+#include <sched.h>
+#include <timesys.h>
+#include <tmacros.h>
+#include <rtems/btimer.h>
+#include "test_support.h"
+#include <pthread.h>
+const char rtems_test_name[] = "PSXTMCOND 08";
+/* forward declarations to avoid warnings */
+void *POSIX_Init(void *argument);
+void *Middle(void *argument);
+void *Low(void *argument);
+pthread_cond_t  CondID;
+pthread_mutex_t MutexID;
+struct timespec sleepTime;
+void *Low(
+  void *argument
+  uint32_t end_time;
+  end_time = benchmark_timer_read();
+  put_time(
+    TEST_CASE,
+    end_time,
+    OPERATION_COUNT,
+    0,
+    0
+  TEST_END();
+  rtems_test_exit( 0 );
+  return NULL;
+void *Middle(
+  void *argument
+  int             rc;
+  rc = pthread_mutex_lock(&MutexID);
+  rtems_test_assert( rc == 0 );
+  /* block and switch to another task here */
+  #if   defined(USE_WAIT)
+    rc = pthread_cond_wait( &CondID, &MutexID );
+  #elif defined(USE_TIMEDWAIT_WITH_VALUE)
+    /* adjust sleepTime to get something obviously in the future */
+    ++sleepTime.tv_sec;
+    rc = pthread_cond_timedwait( &CondID, &MutexID, &sleepTime );
+  #elif defined(USE_TIMEDWAIT_WAIT_VALUE_IN_PAST)
+      /* override sleepTime with something obviously in the past */
+      sleepTime.tv_sec = 0;
+      sleepTime.tv_nsec = 5;
+      /* this does all the work of timedwait but immediately returns */
+      rtems_test_assert(rc == ETIMEDOUT);
+      benchmark_timer_read();
+  #endif
+  pthread_mutex_unlock(&MutexID);
+  #if defined(USE_TIMEDWAIT_WAIT_VALUE_IN_PAST)
+     * In this case, unlock does not switch to another thread. so we need
+     * to explicitly yield. If we do not yield, then we will measure the
+     * time required to do an implicit pthread_exit() which is undesirable
+     * from a measurement viewpoint.
+    sched_yield();
+  #endif
+  return NULL;
+void *POSIX_Init(
+  void *argument
+  int             i;
+  int             status;
+  pthread_t       threadId;
+  int             rc;
+  struct timeval  tp;
+  TEST_BEGIN();
+  rc =  gettimeofday(&tp, NULL);
+  /* Convert from timeval to timespec */
+  sleepTime.tv_sec  = tp.tv_sec;
+  sleepTime.tv_nsec = tp.tv_usec * 1000;
+  rc = pthread_cond_init(&CondID, NULL);
+  rc = pthread_mutex_init(&MutexID, NULL);
+  for ( i=0 ; i < OPERATION_COUNT - 1 ; i++ ) {
+    status = pthread_create( &threadId, NULL, Middle, NULL );
+    rtems_test_assert( !status );
+  status = pthread_create( &threadId, NULL, Low, NULL );
+  /* start the timer and switch through all the other tasks */
+  benchmark_timer_initialize();
+  rc = pthread_mutex_unlock(&MutexID);
+  /* Should never return. */
+  return NULL;
+/* configuration information */
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
+#define CONFIGURE_MAXIMUM_POSIX_THREADS     OPERATION_COUNT + 2
+#define CONFIGURE_POSIX_INIT_THREAD_TABLE
+#define CONFIGURE_INIT
+#include <rtems/confdefs.h>
+  /* end of file */
diff --git a/testsuites/psxtmtests/psxtmcond09/init.c b/testsuites/psxtmtests/psxtmcond09/init.c
index 0000000000..d0b4f8b554
--- /dev/null
+++ b/testsuites/psxtmtests/psxtmcond09/init.c
@@ -0,0 +1,2 @@
+#define USE_TIMEDWAIT_WITH_VALUE
diff --git a/testsuites/psxtmtests/psxtmcond10/init.c b/testsuites/psxtmtests/psxtmcond10/init.c
index 0000000000..5e08e6e7eb
--- /dev/null
+++ b/testsuites/psxtmtests/psxtmcond10/init.c
@@ -0,0 +1,2 @@
+#define USE_TIMEDWAIT_WAIT_VALUE_IN_PAST
2.16.4
