Problem with clang support in waf
Wed Nov 13 07:55:29 UTC 2019
Hello,
I made some preparations to support also clang in the new build system.
You can configure the compiler per BSP variant, e.g.
[riscv/rv32imac]
COMPILER = clang
# Flags passed to the library archiver
ARFLAGS = crD
# Warning flags passed to the C compiler
CC_WARNING_FLAGS = -Wmissing-prototypes -Wimplicit-function-declaration
-Wstrict-prototypes -Wnested-externs
I have now the following problem:
./waf configure --rtems-tools=/build/rtems/5,/usr
--rtems-options=rv32imac.ini
Setting top to                           : /home/EB/sebastian_h/git-rtems-5
Setting out to                           :
/home/EB/sebastian_h/git-rtems-5/build
Configure board support package (BSP)    : riscv/rv32imac
Checking for program 'clang'             : /usr/bin/clang
Checking for program 'riscv-rtems5-ar'   :
/build/rtems/5/bin/riscv-rtems5-ar
Checking for program 'ar'                :
Checking for program 'llvm-ar, ar'       :
Checking for c flags '-MMD'              : yes
'configure' finished successfully (0.988s)
~/git-rtems-5 (build) > ./waf
Waf: Entering directory `/home/EB/sebastian_h/git-rtems-5/build'
Waf: Leaving directory `/home/EB/sebastian_h/git-rtems-5/build'
'build' finished successfully (0.322s)
`/home/EB/sebastian_h/git-rtems-5/build/riscv/rv32imac'
File
/home/EB/sebastian_h/git-rtems-5/cpukit/score/cpu/riscv/riscv-exception-handler.S
has no mapping in ['.c', '.obj', '.o', '.pc.in'] (load a waf tool?)
Waf doesn't know how *.S files are turned into *.o files. What is the
clang assembler command? Is it missing in
https://gitlab.com/ita1024/waf/tree/master/waflib/Tools
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
