Testing the interrupt extension API?
Thu Oct 3 05:44:20 UTC 2019
On 2/10/19 5:28 pm, Sebastian Huber wrote:
> the interrupt extension API implementation is already quite complex and not
> covered by the test suite:
> https://git.rtems.org/rtems/tree/bsps/shared/irq
> In order to write generic tests for this we have to know which interrupt vector
> can be controlled by software.
Do I assume the testsuite's tests are for hard IP resources?
One approach would be to add an
> rtems_interrupt_get_capabilities() function:
It would be nice to be able to add and remove entries based on soft IP that can
be runtime loaded. :)
