[PATCH libbsd 01/11] imx6_ccm: Import from FreeBSD
Christian Mauderer christian.mauderer at embedded-brains.de
Thu Apr 2 14:42:35 UTC 2020
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
Update #3869.
 freebsd/sys/arm/freescale/imx/imx6_ccm.c     | 468 +++++++++++++++++++++++++++
 freebsd/sys/arm/freescale/imx/imx6_ccmreg.h  | 149 +++++++++
 freebsd/sys/arm/freescale/imx/imx6_machdep.h |  38 +++
 freebsd/sys/arm/freescale/imx/imx_machdep.h  |  72 +++++
 4 files changed, 727 insertions(+)
 create mode 100644 freebsd/sys/arm/freescale/imx/imx6_ccm.c
 create mode 100644 freebsd/sys/arm/freescale/imx/imx6_ccmreg.h
 create mode 100644 freebsd/sys/arm/freescale/imx/imx6_machdep.h
 create mode 100644 freebsd/sys/arm/freescale/imx/imx_machdep.h
diff --git a/freebsd/sys/arm/freescale/imx/imx6_ccm.c b/freebsd/sys/arm/freescale/imx/imx6_ccm.c
new file mode 100644
index 00000000..2993f1d6
--- /dev/null
+++ b/freebsd/sys/arm/freescale/imx/imx6_ccm.c
@@ -0,0 +1,468 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
+ * Copyright (c) 2013 Ian Lepore <ian at freebsd.org>
+ * All rights reserved.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+ * Clocks and power control driver for Freescale i.MX6 family of SoCs.
+#include <sys/param.h>
+#include <sys/systm.h>
+#include <sys/kernel.h>
+#include <sys/module.h>
+#include <sys/bus.h>
+#include <sys/rman.h>
+#include <dev/ofw/ofw_bus.h>
+#include <dev/ofw/ofw_bus_subr.h>
+#include <machine/bus.h>
+#include <arm/freescale/imx/imx6_anatopreg.h>
+#include <arm/freescale/imx/imx6_anatopvar.h>
+#include <arm/freescale/imx/imx6_ccmreg.h>
+#include <arm/freescale/imx/imx_machdep.h>
+#include <arm/freescale/imx/imx_ccmvar.h>
+#ifndef CCGR_CLK_MODE_ALWAYS
+#define	CCGR_CLK_MODE_OFF		0
+#define	CCGR_CLK_MODE_RUNMODE		1
+#define	CCGR_CLK_MODE_ALWAYS		3
+#endif
+struct ccm_softc {
+	device_t	dev;
+	struct resource	*mem_res;
+static struct ccm_softc *ccm_sc;
+static inline uint32_t
+RD4(struct ccm_softc *sc, bus_size_t off)
+	return (bus_read_4(sc->mem_res, off));
+static inline void
+WR4(struct ccm_softc *sc, bus_size_t off, uint32_t val)
+	bus_write_4(sc->mem_res, off, val);
+ * Until we have a fully functional ccm driver which implements the fdt_clock
+ * interface, use the age-old workaround of unconditionally enabling the clocks
+ * for devices we might need to use.  The SoC defaults to most clocks enabled,
+ * but the rom boot code and u-boot disable a few of them.  We turn on only
+ * what's needed to run the chip plus devices we have drivers for, and turn off
+ * devices we don't yet have drivers for.  (Note that USB is not turned on here
+ * because that is one we do when the driver asks for it.)
+static void
+ccm_init_gates(struct ccm_softc *sc)
+	uint32_t reg;
+ 	/* ahpbdma, aipstz 1 & 2 buses */
+	reg = CCGR0_AIPS_TZ1 | CCGR0_AIPS_TZ2 | CCGR0_ABPHDMA;
+	WR4(sc, CCM_CCGR0, reg);
+	/* enet, epit, gpt, spi */
+	reg = CCGR1_ENET | CCGR1_EPIT1 | CCGR1_GPT | CCGR1_ECSPI1 |
+	    CCGR1_ECSPI2 | CCGR1_ECSPI3 | CCGR1_ECSPI4 | CCGR1_ECSPI5;
+	WR4(sc, CCM_CCGR1, reg);
+	/* ipmux & ipsync (bridges), iomux, i2c */
+	reg = CCGR2_I2C1 | CCGR2_I2C2 | CCGR2_I2C3 | CCGR2_IIM |
+	    CCGR2_IOMUX_IPT | CCGR2_IPMUX1 | CCGR2_IPMUX2 | CCGR2_IPMUX3 |
+	    CCGR2_IPSYNC_IP2APB_TZASC1 | CCGR2_IPSYNC_IP2APB_TZASC2 |
+	    CCGR2_IPSYNC_VDOA;
+	WR4(sc, CCM_CCGR2, reg);
+	/* DDR memory controller */
+	reg = CCGR3_OCRAM | CCGR3_MMDC_CORE_IPG |
+	    CCGR3_MMDC_CORE_ACLK_FAST | CCGR3_CG11 | CCGR3_CG13;
+	WR4(sc, CCM_CCGR3, reg);
+	/* pl301 bus crossbar */
+	reg = CCGR4_PL301_MX6QFAST1_S133 |
+	    CCGR4_PL301_MX6QPER1_BCH | CCGR4_PL301_MX6QPER2_MAIN;
+	WR4(sc, CCM_CCGR4, reg);
+	/* uarts, ssi, sdma */
+	reg = CCGR5_SDMA | CCGR5_SSI1 | CCGR5_SSI2 | CCGR5_SSI3 |
+	    CCGR5_UART | CCGR5_UART_SERIAL;
+	WR4(sc, CCM_CCGR5, reg);
+	/* usdhc 1-4, usboh3 */
+	reg = CCGR6_USBOH3 | CCGR6_USDHC1 | CCGR6_USDHC2 |
+	    CCGR6_USDHC3 | CCGR6_USDHC4;
+	WR4(sc, CCM_CCGR6, reg);
+static int
+ccm_detach(device_t dev)
+	struct ccm_softc *sc;
+	sc = device_get_softc(dev);
+	if (sc->mem_res != NULL)
+		bus_release_resource(dev, SYS_RES_MEMORY, 0, sc->mem_res);
+	return (0);
+static int
+ccm_attach(device_t dev)
+	int err, rid;
+	uint32_t reg;
+	err = 0;
+	/* Allocate bus_space resources. */
+	rid = 0;
+	sc->mem_res = bus_alloc_resource_any(dev, SYS_RES_MEMORY, &rid,
+	    RF_ACTIVE);
+	if (sc->mem_res == NULL) {
+		device_printf(dev, "Cannot allocate memory resources\n");
+		err = ENXIO;
+		goto out;
+	ccm_sc = sc;
+	 * Configure the Low Power Mode setting to leave the ARM core power on
+	 * when a WFI instruction is executed.  This lets the MPCore timers and
+	 * GIC continue to run, which is helpful when the only thing that can
+	 * wake you up is an MPCore Private Timer interrupt delivered via GIC.
+	 * XXX Based on the docs, setting CCM_CGPR_INT_MEM_CLK_LPM shouldn't be
+	 * required when the LPM bits are set to LPM_RUN.  But experimentally
+	 * I've experienced a fairly rare lockup when not setting it.  I was
+	 * unable to prove conclusively that the lockup was related to power
+	 * management or that this definitively fixes it.  Revisit this.
+	reg = RD4(sc, CCM_CGPR);
+	reg |= CCM_CGPR_INT_MEM_CLK_LPM;
+	WR4(sc, CCM_CGPR, reg);
+	reg = RD4(sc, CCM_CLPCR);
+	reg = (reg & ~CCM_CLPCR_LPM_MASK) | CCM_CLPCR_LPM_RUN;
+	WR4(sc, CCM_CLPCR, reg);
+	ccm_init_gates(sc);
+	err = 0;
+out:
+	if (err != 0)
+		ccm_detach(dev);
+	return (err);
+static int
+ccm_probe(device_t dev)
+	if (!ofw_bus_status_okay(dev))
+		return (ENXIO);
+        if (ofw_bus_is_compatible(dev, "fsl,imx6q-ccm") == 0)
+		return (ENXIO);
+	device_set_desc(dev, "Freescale i.MX6 Clock Control Module");
+	return (BUS_PROBE_DEFAULT);
+void
+imx_ccm_ssi_configure(device_t _ssidev)
+	uint32_t reg;
+	sc = ccm_sc;
+	 * Select PLL4 (Audio PLL) clock multiplexer as source.
+	 * PLL output frequency = Fref * (DIV_SELECT + NUM/DENOM).
+	reg = RD4(sc, CCM_CSCMR1);
+	reg &= ~(SSI_CLK_SEL_M << SSI1_CLK_SEL_S);
+	reg |= (SSI_CLK_SEL_PLL4 << SSI1_CLK_SEL_S);
+	reg &= ~(SSI_CLK_SEL_M << SSI2_CLK_SEL_S);
+	reg |= (SSI_CLK_SEL_PLL4 << SSI2_CLK_SEL_S);
+	reg &= ~(SSI_CLK_SEL_M << SSI3_CLK_SEL_S);
+	reg |= (SSI_CLK_SEL_PLL4 << SSI3_CLK_SEL_S);
+	WR4(sc, CCM_CSCMR1, reg);
+	 * Ensure we have set hardware-default values
+	 * for pre and post dividers.
+	/* SSI1 and SSI3 */
+	reg = RD4(sc, CCM_CS1CDR);
+	/* Divide by 2 */
+	reg &= ~(SSI_CLK_PODF_MASK << SSI1_CLK_PODF_SHIFT);
+	reg &= ~(SSI_CLK_PODF_MASK << SSI3_CLK_PODF_SHIFT);
+	reg |= (0x1 << SSI1_CLK_PODF_SHIFT);
+	reg |= (0x1 << SSI3_CLK_PODF_SHIFT);
+	/* Divide by 4 */
+	reg &= ~(SSI_CLK_PRED_MASK << SSI1_CLK_PRED_SHIFT);
+	reg &= ~(SSI_CLK_PRED_MASK << SSI3_CLK_PRED_SHIFT);
+	reg |= (0x3 << SSI1_CLK_PRED_SHIFT);
+	reg |= (0x3 << SSI3_CLK_PRED_SHIFT);
+	WR4(sc, CCM_CS1CDR, reg);
+	/* SSI2 */
+	reg = RD4(sc, CCM_CS2CDR);
+	/* Divide by 2 */
+	reg &= ~(SSI_CLK_PODF_MASK << SSI2_CLK_PODF_SHIFT);
+	reg |= (0x1 << SSI2_CLK_PODF_SHIFT);
+	/* Divide by 4 */
+	reg &= ~(SSI_CLK_PRED_MASK << SSI2_CLK_PRED_SHIFT);
+	reg |= (0x3 << SSI2_CLK_PRED_SHIFT);
+	WR4(sc, CCM_CS2CDR, reg);
+void
+imx_ccm_usb_enable(device_t _usbdev)
+	 * For imx6, the USBOH3 clock gate is bits 0-1 of CCGR6, so no need for
+	 * shifting and masking here, just set the low-order two bits to ALWAYS.
+	WR4(ccm_sc, CCM_CCGR6, RD4(ccm_sc, CCM_CCGR6) | CCGR_CLK_MODE_ALWAYS);
+void
+imx_ccm_usbphy_enable(device_t _phydev)
+         * XXX Which unit?
+         * Right now it's not clear how to figure from fdt data which phy unit
+         * we're supposed to operate on.  Until this is worked out, just enable
+         * both PHYs.
+#if 0
+	int phy_num, regoff;
+	phy_num = 0; /* XXX */
+	switch (phy_num) {
+	case 0:
+		regoff = 0;
+		break;
+	case 1:
+		regoff = 0x10;
+		break;
+	default:
+		device_printf(ccm_sc->dev, "Bad PHY number %u,\n",
+		    phy_num);
+		return;
+	imx6_anatop_write_4(IMX6_ANALOG_CCM_PLL_USB1 + regoff,
+	    IMX6_ANALOG_CCM_PLL_USB_ENABLE |
+	    IMX6_ANALOG_CCM_PLL_USB_POWER |
+	    IMX6_ANALOG_CCM_PLL_USB_EN_USB_CLKS);
+#else
+	imx6_anatop_write_4(IMX6_ANALOG_CCM_PLL_USB1 + 0,
+	imx6_anatop_write_4(IMX6_ANALOG_CCM_PLL_USB1 + 0x10,
+#endif
+int
+imx6_ccm_sata_enable(void)
+	uint32_t v;
+	int timeout;
+	/* Un-gate the sata controller. */
+	WR4(ccm_sc, CCM_CCGR5, RD4(ccm_sc, CCM_CCGR5) | CCGR5_SATA);
+	/* Power up the PLL that feeds ENET/SATA/PCI phys, wait for lock. */
+	v = RD4(ccm_sc, CCM_ANALOG_PLL_ENET);
+	v &= ~CCM_ANALOG_PLL_ENET_POWERDOWN;
+	WR4(ccm_sc, CCM_ANALOG_PLL_ENET, v);
+	for (timeout = 100000; timeout > 0; timeout--) {
+		if (RD4(ccm_sc, CCM_ANALOG_PLL_ENET) &
+		   CCM_ANALOG_PLL_ENET_LOCK) {
+			break;
+	if (timeout <= 0) {
+		return ETIMEDOUT;
+	/* Enable the PLL, and enable its 100mhz output. */
+	v |= CCM_ANALOG_PLL_ENET_ENABLE;
+	v &= ~CCM_ANALOG_PLL_ENET_BYPASS;
+	v |= CCM_ANALOG_PLL_ENET_ENABLE_100M;
+	return 0;
+uint32_t
+imx_ccm_ecspi_hz(void)
+	return (60000000);
+uint32_t
+imx_ccm_ipg_hz(void)
+	return (66000000);
+uint32_t
+imx_ccm_perclk_hz(void)
+uint32_t
+imx_ccm_sdhci_hz(void)
+	return (200000000);
+uint32_t
+imx_ccm_uart_hz(void)
+	return (80000000);
+uint32_t
+imx_ccm_ahb_hz(void)
+	return (132000000);
+void
+imx_ccm_ipu_enable(int ipu)
+	uint32_t reg;
+	sc = ccm_sc;
+	reg = RD4(sc, CCM_CCGR3);
+	if (ipu == 1)
+		reg |= CCGR3_IPU1_IPU | CCGR3_IPU1_DI0;
+	else
+		reg |= CCGR3_IPU2_IPU | CCGR3_IPU2_DI0;
+void
+imx_ccm_hdmi_enable(void)
+	uint32_t reg;
+	sc = ccm_sc;
+	reg = RD4(sc, CCM_CCGR2);
+	reg |= CCGR2_HDMI_TX | CCGR2_HDMI_TX_ISFR;
+	/* Set HDMI clock to 280MHz */
+	reg = RD4(sc, CCM_CHSCCDR);
+	reg &= ~(CHSCCDR_IPU1_DI0_PRE_CLK_SEL_MASK |
+	    CHSCCDR_IPU1_DI0_PODF_MASK | CHSCCDR_IPU1_DI0_CLK_SEL_MASK);
+	reg |= (CHSCCDR_PODF_DIVIDE_BY_3 << CHSCCDR_IPU1_DI0_PODF_SHIFT);
+	reg |= (CHSCCDR_IPU_PRE_CLK_540M_PFD << CHSCCDR_IPU1_DI0_PRE_CLK_SEL_SHIFT);
+	WR4(sc, CCM_CHSCCDR, reg);
+	reg |= (CHSCCDR_CLK_SEL_LDB_DI0 << CHSCCDR_IPU1_DI0_CLK_SEL_SHIFT);
+uint32_t
+imx_ccm_get_cacrr(void)
+	return (RD4(ccm_sc, CCM_CACCR));
+void
+imx_ccm_set_cacrr(uint32_t divisor)
+	WR4(ccm_sc, CCM_CACCR, divisor);
+static device_method_t ccm_methods[] = {
+	/* Device interface */
+	DEVMETHOD(device_probe,  ccm_probe),
+	DEVMETHOD(device_attach, ccm_attach),
+	DEVMETHOD(device_detach, ccm_detach),
+	DEVMETHOD_END
+static driver_t ccm_driver = {
+	"ccm",
+	ccm_methods,
+	sizeof(struct ccm_softc)
+static devclass_t ccm_devclass;
+EARLY_DRIVER_MODULE(ccm, simplebus, ccm_driver, ccm_devclass, 0, 0,
+    BUS_PASS_CPU + BUS_PASS_ORDER_EARLY);
diff --git a/freebsd/sys/arm/freescale/imx/imx6_ccmreg.h b/freebsd/sys/arm/freescale/imx/imx6_ccmreg.h
index 00000000..69e028de
--- /dev/null
+++ b/freebsd/sys/arm/freescale/imx/imx6_ccmreg.h
@@ -0,0 +1,149 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef	IMX6_CCMREG_H
+#define	IMX6_CCMREG_H
+#define	CCM_CACCR				0x010
+#define	CCM_CBCDR				0x014
+#define	  CBCDR_MMDC_CH1_AXI_PODF_SHIFT		  3
+#define	  CBCDR_MMDC_CH1_AXI_PODF_MASK		  (7 << 3)
+#define	CCM_CSCMR1				0x01C
+#define	  SSI1_CLK_SEL_S			  10
+#define	  SSI2_CLK_SEL_S			  12
+#define	  SSI3_CLK_SEL_S			  14
+#define	  SSI_CLK_SEL_M				  0x3
+#define	  SSI_CLK_SEL_508_PFD			  0
+#define	  SSI_CLK_SEL_454_PFD			  1
+#define	  SSI_CLK_SEL_PLL4			  2
+#define	CCM_CSCMR2				0x020
+#define	  CSCMR2_LDB_DI0_IPU_DIV_SHIFT		  10
+#define	CCM_CS1CDR				0x028
+#define	  SSI1_CLK_PODF_SHIFT			  0
+#define	  SSI1_CLK_PRED_SHIFT			  6
+#define	  SSI3_CLK_PODF_SHIFT			  16
+#define	  SSI3_CLK_PRED_SHIFT			  22
+#define	  SSI_CLK_PODF_MASK			  0x3f
+#define	  SSI_CLK_PRED_MASK			  0x7
+#define	CCM_CS2CDR				0x02C
+#define	  SSI2_CLK_PODF_SHIFT			  0
+#define	  SSI2_CLK_PRED_SHIFT			  6
+#define	  LDB_DI0_CLK_SEL_SHIFT			  9
+#define	  LDB_DI0_CLK_SEL_MASK			  (3 << LDB_DI0_CLK_SEL_SHIFT)
+#define	CCM_CHSCCDR				0x034
+#define	  CHSCCDR_IPU1_DI0_PRE_CLK_SEL_MASK	  (0x7 << 6)
+#define	  CHSCCDR_IPU1_DI0_PRE_CLK_SEL_SHIFT	  6
+#define	  CHSCCDR_IPU1_DI0_PODF_MASK		  (0x7 << 3)
+#define	  CHSCCDR_IPU1_DI0_PODF_SHIFT		  3
+#define	  CHSCCDR_IPU1_DI0_CLK_SEL_MASK		  (0x7)
+#define	  CHSCCDR_IPU1_DI0_CLK_SEL_SHIFT	  0
+#define	  CHSCCDR_CLK_SEL_LDB_DI0		  3
+#define	  CHSCCDR_PODF_DIVIDE_BY_3		  2
+#define	  CHSCCDR_IPU_PRE_CLK_540M_PFD		  5
+#define	CCM_CSCDR2				0x038
+#define	CCM_CLPCR				0x054
+#define	  CCM_CLPCR_LPM_MASK			  0x03
+#define	  CCM_CLPCR_LPM_RUN			  0x00
+#define	  CCM_CLPCR_LPM_WAIT			  0x01
+#define	  CCM_CLPCR_LPM_STOP			  0x02
+#define	CCM_CGPR				0x064
+#define	  CCM_CGPR_INT_MEM_CLK_LPM		  (1 << 17)
+#define	CCM_CCGR0				0x068
+#define	  CCGR0_AIPS_TZ1			  (0x3 << 0)
+#define	  CCGR0_AIPS_TZ2			  (0x3 << 2)
+#define	  CCGR0_ABPHDMA				  (0x3 << 4)
+#define	CCM_CCGR1				0x06C
+#define	  CCGR1_ECSPI1				  (0x3 <<  0)
+#define	  CCGR1_ECSPI2				  (0x3 <<  2)
+#define	  CCGR1_ECSPI3				  (0x3 <<  4)
+#define	  CCGR1_ECSPI4				  (0x3 <<  6)
+#define	  CCGR1_ECSPI5				  (0x3 <<  8)
+#define	  CCGR1_ENET				  (0x3 << 10)
+#define	  CCGR1_EPIT1				  (0x3 << 12)
+#define	  CCGR1_EPIT2				  (0x3 << 14)
+#define	  CCGR1_ESAI				  (0x3 << 16)
+#define	  CCGR1_GPT				  (0x3 << 20)
+#define	  CCGR1_GPT_SERIAL			  (0x3 << 22)
+#define	CCM_CCGR2				0x070
+#define	  CCGR2_HDMI_TX				  (0x3 << 0)
+#define	  CCGR2_HDMI_TX_ISFR			  (0x3 << 4)
+#define	  CCGR2_I2C1				  (0x3 << 6)
+#define	  CCGR2_I2C2				  (0x3 << 8)
+#define	  CCGR2_I2C3				  (0x3 << 10)
+#define	  CCGR2_IIM				  (0x3 << 12)
+#define	  CCGR2_IOMUX_IPT			  (0x3 << 14)
+#define	  CCGR2_IPMUX1				  (0x3 << 16)
+#define	  CCGR2_IPMUX2				  (0x3 << 18)
+#define	  CCGR2_IPMUX3				  (0x3 << 20)
+#define	  CCGR2_IPSYNC_IP2APB_TZASC1		  (0x3 << 22)
+#define	  CCGR2_IPSYNC_IP2APB_TZASC2		  (0x3 << 24)
+#define	  CCGR2_IPSYNC_VDOA			  (0x3 << 26)
+#define	CCM_CCGR3				0x074
+#define	  CCGR3_IPU1_IPU			  (0x3 << 0)
+#define	  CCGR3_IPU1_DI0			  (0x3 << 2)
+#define	  CCGR3_IPU1_DI1			  (0x3 << 4)
+#define	  CCGR3_IPU2_IPU			  (0x3 << 6)
+#define	  CCGR3_IPU2_DI0			  (0x3 << 8)
+#define	  CCGR3_IPU2_DI1			  (0x3 << 10)
+#define	  CCGR3_LDB_DI0				  (0x3 << 12)
+#define	  CCGR3_LDB_DI1				  (0x3 << 14)
+#define	  CCGR3_MMDC_CORE_ACLK_FAST		  (0x3 << 20)
+#define	  CCGR3_CG11				  (0x3 << 22)
+#define	  CCGR3_MMDC_CORE_IPG			  (0x3 << 24)
+#define	  CCGR3_CG13				  (0x3 << 26)
+#define	  CCGR3_OCRAM				  (0x3 << 28)
+#define	CCM_CCGR4				0x078
+#define	  CCGR4_PL301_MX6QFAST1_S133		  (0x3 << 8)
+#define	  CCGR4_PL301_MX6QPER1_BCH		  (0x3 << 12)
+#define	  CCGR4_PL301_MX6QPER2_MAIN		  (0x3 << 14)
+#define	CCM_CCGR5				0x07C
+#define	  CCGR5_SATA        			  (0x3 << 4)
+#define	  CCGR5_SDMA				  (0x3 << 6)
+#define	  CCGR5_SSI1				  (0x3 << 18)
+#define	  CCGR5_SSI2				  (0x3 << 20)
+#define	  CCGR5_SSI3				  (0x3 << 22)
+#define	  CCGR5_UART				  (0x3 << 24)
+#define	  CCGR5_UART_SERIAL			  (0x3 << 26)
+#define	CCM_CCGR6				0x080
+#define	  CCGR6_USBOH3				  (0x3 << 0)
+#define	  CCGR6_USDHC1				  (0x3 << 2)
+#define	  CCGR6_USDHC2				  (0x3 << 4)
+#define	  CCGR6_USDHC3				  (0x3 << 6)
+#define	  CCGR6_USDHC4				  (0x3 << 8)
+#define	CCM_CMEOR				0x088
+#define	CCM_ANALOG_PLL_ENET			0x000040e0
+#define	  CCM_ANALOG_PLL_ENET_LOCK		  (1u << 31)
+#define	  CCM_ANALOG_PLL_ENET_ENABLE_100M	  (1u << 20)  /* SATA */
+#define	  CCM_ANALOG_PLL_ENET_BYPASS		  (1u << 16)
+#define	  CCM_ANALOG_PLL_ENET_ENABLE		  (1u << 13)  /* Ether */
+#define	  CCM_ANALOG_PLL_ENET_POWERDOWN		  (1u << 12)
+#endif
diff --git a/freebsd/sys/arm/freescale/imx/imx6_machdep.h b/freebsd/sys/arm/freescale/imx/imx6_machdep.h
index 00000000..4db1bb35
--- /dev/null
+++ b/freebsd/sys/arm/freescale/imx/imx6_machdep.h
@@ -0,0 +1,38 @@
+ * Copyright (c) 2017 Andrew Turner
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef IMX6_MACHDEP_H
+#define	IMX6_MACHDEP_H
+struct pl310_softc;
+void imx6_mp_start_ap(platform_t);
+void imx6_mp_setmaxid(platform_t);
+void imx6_pl310_init(platform_t, struct pl310_softc *);
+#endif /* IMX6_MACHDEP_H */
diff --git a/freebsd/sys/arm/freescale/imx/imx_machdep.h b/freebsd/sys/arm/freescale/imx/imx_machdep.h
index 00000000..07172464
--- /dev/null
+++ b/freebsd/sys/arm/freescale/imx/imx_machdep.h
@@ -0,0 +1,72 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef	IMX_MACHDEP_H
+#define	IMX_MACHDEP_H
+#include <sys/types.h>
+#include <sys/sysctl.h>
+SYSCTL_DECL(_hw_imx);
+/* Common functions, implemented in imx_machdep.c. */
+void imx_wdog_cpu_reset(vm_offset_t _wdcr_phys)  __attribute__((__noreturn__));
+void imx_wdog_init_last_reset(vm_offset_t _wdsr_phys);
+/* From here down, routines are implemented in imxNN_machdep.c. */
+ * SoC identity.
+ * According to the documentation, there is such a thing as an i.MX6 Dual
+ * (non-lite flavor).  However, Freescale doesn't seem to have assigned it a
+ * number in their code for determining the SoC type in u-boot.
+ * To-do: put silicon revision numbers into the low-order bits somewhere.
+#define	IMXSOC_51	0x51000000
+#define	IMXSOC_53	0x53000000
+#define	IMXSOC_6SL	0x60000000
+#define	IMXSOC_6DL	0x61000000
+#define	IMXSOC_6S	0x62000000
+#define	IMXSOC_6Q	0x63000000
+#define	IMXSOC_6UL	0x64000000
+#define	IMXSOC_FAMSHIFT	28
+u_int imx_soc_type(void);
+static inline u_int
+imx_soc_family(void)
+	return (imx_soc_type() >> IMXSOC_FAMSHIFT);
+#endif
2.16.4
