[PATCH libbsd 09/11] ehci_imx.c: Port to RTEMS
Christian Mauderer christian.mauderer at embedded-brains.de
Thu Apr 2 14:47:38 UTC 2020
Hello,
just noted: This patch now contains more from my code than from
Sebastian. I'll discuss with him whether we change the author before
commiting it.
Best regards
Christian
On 02/04/2020 16:42, Christian Mauderer wrote:
> From: Sebastian Huber <sebastian.huber at embedded-brains.de>
> Update #3869.
>  freebsd/sys/arm/freescale/imx/imx6_usbphy.c | 11 ++++++
>  freebsd/sys/dev/usb/controller/ehci_imx.c   | 12 +++++++
>  freebsd/sys/dev/usb/usb_busdma.c            | 54 +++++++++++++++++++++++++++++
>  libbsd.py                                   |  4 +++
>  rtemsbsd/include/bsp/nexus-devices.h        |  5 +++
>  5 files changed, 86 insertions(+)
> diff --git a/freebsd/sys/arm/freescale/imx/imx6_usbphy.c b/freebsd/sys/arm/freescale/imx/imx6_usbphy.c
> index 8f47507b..ad545601 100644
> --- a/freebsd/sys/arm/freescale/imx/imx6_usbphy.c
> +++ b/freebsd/sys/arm/freescale/imx/imx6_usbphy.c
> @@ -91,6 +91,17 @@ usbphy_detach(device_t dev)
>  	return (0);
> +#ifdef __rtems__
> +#define BUS_SPACE_PHYSADDR(res, offs) \
> +	((u_int)(rman_get_start(res)+(offs)))
> +void
> +imx6_anatop_write_4(bus_size_t offset, uint32_t value)
> +	bus_space_write_4(0, 0x20c8000, offset, value);
> +#endif /* __rtems__ */
>  static int
>  usbphy_attach(device_t dev)
> diff --git a/freebsd/sys/dev/usb/controller/ehci_imx.c b/freebsd/sys/dev/usb/controller/ehci_imx.c
> index a872fb62..d158df1d 100644
> --- a/freebsd/sys/dev/usb/controller/ehci_imx.c
> +++ b/freebsd/sys/dev/usb/controller/ehci_imx.c
> @@ -303,6 +303,16 @@ imx_ehci_probe(device_t dev)
>  		return (ENXIO);
>  	if (ofw_bus_search_compatible(dev, compat_data)->ocd_data != 0) {
> +#ifdef __rtems__
> +		char dr_mode[24];
> +		if (OF_getprop(ofw_bus_get_node(dev), "dr_mode",
> +		    &dr_mode, sizeof(dr_mode)) > 0 &&
> +		    strcasecmp(dr_mode, "host") != 0) {
> +			return (ENXIO);
>  		device_set_desc(dev, "Freescale i.MX integrated USB controller");
>  		return (BUS_PROBE_DEFAULT);
> @@ -437,8 +447,10 @@ imx_ehci_attach(device_t dev)
>  		goto out;
> +#ifndef __rtems__
>  	/* Turn on clocks. */
>  	imx_ccm_usb_enable(dev);
>  	/* Disable overcurrent detection, if configured to do so. */
>  	if (OF_hasprop(ofw_bus_get_node(sc->dev), "disable-over-current"))
> diff --git a/freebsd/sys/dev/usb/usb_busdma.c b/freebsd/sys/dev/usb/usb_busdma.c
> index 9a70c687..c8000170 100644
> --- a/freebsd/sys/dev/usb/usb_busdma.c
> +++ b/freebsd/sys/dev/usb/usb_busdma.c
> @@ -78,6 +78,52 @@ static void	usb_pc_common_mem_cb(void *, bus_dma_segment_t *, int, int,
>  		    uint8_t);
>  #endif
> +#ifdef __rtems__
> +#include <bsp.h>
> +#if defined(LIBBSP_ARM_IMX_BSP_H)
> +#define NEED_MISSALIGNED_COPY
> +#endif
> +#ifdef NEED_MISSALIGNED_COPY
> + * Note: This functions are used instead of memcpy for regions where a
> + * misaligned access is not allowed (e.g. peripheral memory).
> +static void misaligned_do_copy(
> +  uint8_t *dst,
> +  const uint8_t *src,
> +  size_t n,
> +  bool aligned
> +  if (aligned) {
> +    while (n > 3) {
> +      *(uint32_t *)dst = *(uint32_t *)src;
> +      dst += 4;
> +      src += 4;
> +      n -= 4;
> +  while (n > 0) {
> +    *dst = *src;
> +    ++dst;
> +    ++src;
> +    --n;
> +void misaligned_copy_to_io(void *dst, const void *src, size_t n)
> +  misaligned_do_copy(dst, src, n, ((uintptr_t)dst) % 4 == 0);
> +void misaligned_copy_from_io(void *dst, const void *src, size_t n)
> +  misaligned_do_copy(dst, src, n, ((uintptr_t)src) % 4 == 0);
> +#endif
>   *  usbd_get_page - lookup DMA-able memory for the given offset
> @@ -182,7 +228,11 @@ usbd_copy_in(struct usb_page_cache *cache, usb_frlength_t offset,
>  		if (buf_res.length > len) {
>  			buf_res.length = len;
> +#if defined(__rtems__) && defined(NEED_MISSALIGNED_COPY)
> +		misaligned_copy_to_io(buf_res.buffer, ptr, buf_res.length);
> +#else /* __rtems__ */
>  		memcpy(buf_res.buffer, ptr, buf_res.length);
>  		offset += buf_res.length;
>  		len -= buf_res.length;
> @@ -302,7 +352,11 @@ usbd_copy_out(struct usb_page_cache *cache, usb_frlength_t offset,
>  		if (res.length > len) {
>  			res.length = len;
> +		misaligned_copy_from_io(ptr, res.buffer, res.length);
>  		memcpy(ptr, res.buffer, res.length);
>  		offset += res.length;
>  		len -= res.length;
> diff --git a/libbsd.py b/libbsd.py
> index 6eaca5ad..ed6493b2 100644
> --- a/libbsd.py
> +++ b/libbsd.py
> @@ -5018,6 +5018,8 @@ class imx(builder.Module):
>          mm = self.manager
>          self.addKernelSpaceHeaderFiles(
> +                'sys/arm/freescale/imx/imx6_anatopreg.h',
> +                'sys/arm/freescale/imx/imx6_anatopvar.h',
>                  'sys/arm/freescale/imx/imx6_ccmreg.h',
>                  'sys/arm/freescale/imx/imx6_machdep.h',
>                  'sys/arm/freescale/imx/imx_machdep.h',
> @@ -5026,6 +5028,8 @@ class imx(builder.Module):
>          self.addKernelSpaceSourceFiles(
>                  'sys/arm/freescale/imx/imx6_ccm.c',
> +                'sys/arm/freescale/imx/imx6_usbphy.c',
> +                'sys/dev/usb/controller/ehci_imx.c',
>              mm.generator['source']()
> diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
> index 0a210bd9..d2ceab8e 100644
> --- a/rtemsbsd/include/bsp/nexus-devices.h
> +++ b/rtemsbsd/include/bsp/nexus-devices.h
> @@ -128,6 +128,11 @@ RTEMS_BSD_DEFINE_NEXUS_DEVICE(ofwbus, 0, 0, NULL);
>  SYSINIT_DRIVER_REFERENCE(simplebus, ofwbus);
>  SYSINIT_DRIVER_REFERENCE(ccm, simplebus);
> +SYSINIT_DRIVER_REFERENCE(ehci, simplebus);
> +SYSINIT_DRIVER_REFERENCE(usbphy, simplebus);
> +SYSINIT_DRIVER_REFERENCE(usbus, ehci);
> +RTEMS_BSD_DRIVER_USB;
> +RTEMS_BSD_DRIVER_USB_MASS;
>  SYSINIT_DRIVER_REFERENCE(ffec, simplebus);
>  SYSINIT_DRIVER_REFERENCE(ukphy, miibus);
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
