Failures on Overnight build sweep
Sun Apr 5 19:31:34 UTC 2020
RTEMS is using this hash: 50782bc5cf00bbaa3ac5200009c6a901f7a52905
RSB is using this hash: 113c65cb56d04c59a0e145f85864fb431419dfa9
I can see a couple of fairly obvious odd issues beyond probably missing
the patches you mention:
+ dtc is older as an RSB recipe by itself than when built with Spike
+ spike doesn't build on FreeBSD
+ GDB build issue with iconv on FreeBSD 12.
+ Did the atsamv issue where it couldn't link all rtems-libbsd tests get
fixed?
It takes a while to dig through the failures. I trust the failures on
Centos and
Ubuntu to be RTEMS related while the FreeBSD ones tend to be in tools.
And that triggers more not working.
--joel
On Sun, Apr 5, 2020 at 2:04 PM Christian Mauderer <oss at c-mauderer.de> wrote:
> Hello Joel,
> libbsd on raspberry should work again since yesterday (if you refer to
> that ticket: https://devel.rtems.org/ticket/3903).
> Did your build already include the revert here:
> https://git.rtems.org/rtems/commit/?id=d582d0e130a463842e27070a2e85ebc1acc7b71f
> Sebastian reverted it after Chris said that it broke some builds:
> https://lists.rtems.org/pipermail/devel/2020-April/059014.html
> Best regards
> Christian
> On 05/04/2020 18:28, Joel Sherrill wrote:
> > Hi
> > It will take me some time to go through all the failures reported on my
> > overnight sweep (which isn't finished everywhere) for Centos 7, Ubuntu,
> > and FreeBSD.
> > Please try to look at the failure messages at
> > https://lists.rtems.org/pipermail/build/2020-April/date.html
> > And see if you can help identify the various root causes and fix them.
> > It appears that a number of the BSP bsets do not build to completion
> > on Centos, many things fail on FreeBSD 12, etc.  For example, this
> > for the PC BSP bset on CentOS:
> > https://lists.rtems.org/pipermail/build/2020-April/012862.html
> > The rasperrypi2 bset build failure is well-known and has a ticket.
> > Help is really appreciated triaging and fixing these.
> > --joel
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200405/dfa49dc7/attachment.html>
