[PATCH v5] Tests for inttype.h methods
Tue Apr 7 19:22:47 UTC 2020
It looks alright, I'm testing it now.
On Tue, Apr 7, 2020 at 1:13 PM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
> I sent this patch a few days ago.
> if anyone could look at it.
> the code was tested by dr joel.
> But had some style issues.
> I have covered all the suggestions.
> Do any more changes need to be made before it is merged?
> Thanks
> -Eshan
> On Sat, Apr 4, 2020 at 12:46 AM Eshan dhawan <eshandhawan51 at gmail.com> wrote:
>>  testsuites/psxtests/psxinttypes01/init.c      | 28 +++++++++++++++++--
>>  .../psxtests/psxinttypes01/psxinttypes01.doc  | 10 ++++++-
>>  2 files changed, 34 insertions(+), 4 deletions(-)
>> diff --git a/testsuites/psxtests/psxinttypes01/init.c b/testsuites/psxtests/psxinttypes01/init.c
>> index 030aa2aa57..28f7336fb8 100644
>> --- a/testsuites/psxtests/psxinttypes01/init.c
>> +++ b/testsuites/psxtests/psxinttypes01/init.c
>> @@ -6,6 +6,7 @@
>>   * SPDX-License-Identifier: BSD-2-Clause
>> + * Copyright (C) 2020, Eshan Dhawan
>>   * Copyright (C) 2019, Aditya Upadhyay and Vaibhav Gupta
>>   * Redistribution and use in source and binary forms, with or without
>> @@ -64,11 +65,32 @@ rtems_task Init(rtems_task_argument ignored)
>>    wchar_t  *nptr2_n_errange = L"-9999999999999999999999";
>>    wchar_t  *endptr2         = NULL;
>> -  intmax_t  result_strtoimax;
>> +  intmax_t  result_strtoimax, result_imaxabs, input_1, input_2;
>> +  imaxdiv_t result_exp, result_imaxdiv;
>>    uintmax_t result_strtoumax;
>>    TEST_BEGIN();
>> + /* Test for imaxabs */
>> +  input_1 = -10;
>> +  result_imaxabs = 10;
>> +  rtems_test_assert( imaxabs(input_1) == result_imaxabs );
>> +  input_1 = 10;
>> +  /* Test for imaxdiv */
>> +  input_1 = 10;
>> +  input_2 = 3;
>> +  result_exp.quot = input_1 / input_2;
>> +  result_exp.rem =  input_1 % input_2;
>> +  result_imaxdiv = imaxdiv( input_1, input_2 );
>> +    result_imaxdiv.quot == result_exp.quot &&
>> +    result_imaxdiv.rem == result_exp.rem
>>    /* Test for strtoimax  */
>>    puts( "\nstrtoimax Testcases...." );
>>    puts( "Valid Inputs - Positive Number" );
>> @@ -83,7 +105,7 @@ rtems_task Init(rtems_task_argument ignored)
>>    rtems_test_assert( result_strtoimax == -123 );
>>    puts( "Final string pointed by endptr" );
>> -  rtems_test_assert( endptr1 == ( nptr1_n + 4 ) );
>> +  rtems_test_assert( endptr1 == ( nptr1_n + 4 ) );
>>    puts( "Valid Input - Positive Number - Number out of Range" );
>>    result_strtoimax = strtoimax( nptr1_p_errange, &endptr1, base );
>> diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.doc b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
>> index 19f63af34b..59b76796e2 100644
>> --- a/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
>> +++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
>> @@ -1,4 +1,4 @@
>> -This File describes the concepts tested by this test suite.
>> +This File describes the concepts tested by this test suite.
>>  inttypes.h - fixed size integer types
>> @@ -37,3 +37,11 @@ test suite name: PSXINTTYPE 01
>>         - checks for output for string having a negative number - Number Out of Range
>>         - checks for final string pointed by endptr
>>         - checks for output for invalid argument - Invalid Base
>> +- Checks for imaxabs Testcases
>> +       - checks for output with an input with any negative number
>> +       - checks for output with an input with any positive number
>> +- Checks for imaxdiv Testcases
>> +       - checks for the output quotient and remainder with input with positive numbers
>> 2.17.1
