[PATCH RSB] bare/glib-2.39.3-1: Add patches to suppress string literal warning
Tue Apr 7 21:15:48 UTC 2020
On Tue, Apr 7, 2020 at 2:06 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> On Wed, Apr 8, 2020 at 12:49 AM Gedare Bloom <gedare at rtems.org> wrote:
>> On Tue, Apr 7, 2020 at 12:03 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
>> > On Tue, Apr 7, 2020 at 11:12 PM Joel Sherrill <joel at rtems.org> wrote:
>> >> On Tue, Apr 7, 2020 at 12:35 PM Gedare Bloom <gedare at rtems.org> wrote:
>> >>> I'm not sure what error this is fixing, is there a ticket open for the warning?
>> >> No idea on this.
>> >>> Is there a fix for the warning besides squelching it?
>> >> I think these are the warnings that are build failures on some hosts. <I think>
>> > I get these errors on Fedora30:
>> > ../../glib-2.39.3/gio/gdbusauth.c: In function '_g_dbus_auth_run_server':
>> > ../../glib-2.39.3/gio/gdbusauth.c:1297:11: error: '%s' directive argument is null [-Werror=format-overflow=]
>> >  1297 |           debug_print ("SERVER: WaitingForBegin, read '%s'", line);
>> > The added patches fix this.
>> I see, this is a build error with newer gcc toolchains?
> Yes
>> Is this only
>> affecting qemu-couverture?
> yes, it's only affecting qemu-couverture
>> What version of gcc is your host using?
> $>gcc --version
> gcc (GCC) 9.2.1 20190827 (Red Hat 9.2.1-1)
>> Can
>> you try to find if there is a ticket open in glib or if this is fixed
>> in newer version, so we can track for the upstream fix?
> I found these patches from the bugzilla issue:
> https://bugzilla.gnome.org/show_bug.cgi?id=761550
OK go ahead and push this. It would be better if qemu was updated or
could use the new-enough version, but I understand.
>> If newer versions of glib fix it, consider bumping the version?
> I'm getting these errors from glib-2.48.2 as well.
>> Is
>> qemu-couverture up-to-date?
> No, and it fails to build. There are issues in qemu-couverture as well.
>> >>> How permanent is that gitlab? Should we just pluck these patches ourselves?
>> >> That's gnome.gitlab.org and per the link at https://www.gnome.org/gnome-3/source/,
>> >> it appears to be the official GNOME git repository. I think I would trust it.
>> >> --joel
>> >>> On Tue, Apr 7, 2020, 7:59 AM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
>> >>>>  bare/config/devel/glib-2.39.3-1.cfg | 4 ++++
>> >>>>  1 file changed, 4 insertions(+)
>> >>>> diff --git a/bare/config/devel/glib-2.39.3-1.cfg b/bare/config/devel/glib-2.39.3-1.cfg
>> >>>> index 9ff7af5..bd5770a 100644
>> >>>> --- a/bare/config/devel/glib-2.39.3-1.cfg
>> >>>> +++ b/bare/config/devel/glib-2.39.3-1.cfg
>> >>>> @@ -14,6 +14,10 @@
>> >>>>  %hash sha256 glib-%{glib_version}.tar.xz d9fa6c9aa645a5e688a3bb29013bb83801b19ee767d99e33ff52e004e1cc5fc8
>> >>>> +#Patch to supress string literal warning
>> >>>> +%patch add glib https://gitlab.gnome.org/GNOME/glib/commit/0817af40e8c74c721c30f6ef482b1f53d12044c7.patch
>> >>>> +%patch add glib https://gitlab.gnome.org/GNOME/glib/commit/566e1d61a500267c7849ad0b2552feec9c9a29a6.patch
>> >>>>  # The GLib build instructions. We use 2.x.x Release 1.
>> >>>> 2.21.1
>> >>>> _______________________________________________
>> >>>> devel mailing list
>> >>>> devel at rtems.org
>> >>>> http://lists.rtems.org/mailman/listinfo/devel
>> >>> devel mailing list
>> >>> devel at rtems.org
