Use weak functions in the RTEMS core?
Wed Apr 8 17:43:50 UTC 2020
On 08/04/2020 19:34, Jonathan Brandmeyer wrote:
>     If you encounter problems like this, then
>     weak functions are used for the wrong thing.
> Exhibit A: zynq_setup_mmu_and_cache.  It is referred to only by the
> BSP's startup sequence.  So it is a reference from librtemsbsp to
> librtemsbsp by default.  I don't think it's being used for the wrong
> thing.
You could move zynq_setup_mmu_and_cache() to a separate file and remove
the weak. The weak function here just avoids an extra file.
>     I would like to use weak functions with one level of indirection. For
>     example an application can use two features A and B. Both use an
>     interface C. If only A is used, then C can be implemented via D or
>     E. If
>     B is used, then C must be implemented via E. For this you can use
>     a weak
>     implementation D of interface C in module of A and a strong
>     implementation E in module of B.
> In the proposed case of using weak references for the heap, which
> implementation gets pulled in depends on whether or not the object
> files listed on the command line reference the heap or not.  If the
> only references are within static archives, then the application will
> have difficulty choosing exactly which implementation of the heap gets
> pulled in.  librtemsbsp both depends-on and provides implementations
> of malloc and free.
> It's pretty easy to provide a definition of Init() or POSIX_Init()
> that doesn't directly call malloc or free, for example.
In my proposed use case:
We could use something like this in heapallocate.c:
RTEMS_WEAK void *_Heap_Allocate_impl(size) { /* Very simple */ }
void *_Heap_Allocate(size)
   return _Heap_Allocate_impl(size)
In heapfree.c:
void *_Heap_Allocate_impl(size) { /* Complex */ }
The application doesn't reference _Heap_Allocate_impl(). It references
_Heap_Allocate() or _Heap_Free() or both or none.
> Instead of treating weak references as a single level of indirection,
> I think you have to treat them as a single overridable interface.  In
> a dynamically-linked application, we might try to perform an override
> using the LD_PRELOAD feature. But in a statically-linked application
> we have to do it differently.  The overriding archive must be named in
> full, and it must be named as an object to be linked instead of a
> library to be searched.  Furthermore, an interface can have only one
> override that ends up in the linked application.
Yes, you can only have one strong implementation, otherwise you get
multiple definition errors.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200408/f0f5ac06/attachment.html>
