[PATCH v5 6/7] i386: Delete old machine dependent files
Jan Sommer jan.sommer at dlr.de
Fri Apr 17 08:24:07 UTC 2020
- The files in the i386 directory have been moved to common x86 directories by FreeBSD:
  - freebsd/sys/x86/x86/legacy.c
  - freebsd/sys/x86/include/machine/legacyvar.h
  - freebsd/sys/x86/include/machine/specialreg.h
- Add header files in rtemsbsd directory to direct compiler to new files
 freebsd/sys/i386/i386/legacy.c                | 381 --------------------------
 freebsd/sys/i386/include/machine/legacyvar.h  |  63 -----
 freebsd/sys/i386/include/machine/specialreg.h |   6 -
 rtemsbsd/include/x86/legacyvar.h              |   1 +
 rtemsbsd/include/x86/x86_var.h                |   1 +
 5 files changed, 2 insertions(+), 450 deletions(-)
 delete mode 100644 freebsd/sys/i386/i386/legacy.c
 delete mode 100644 freebsd/sys/i386/include/machine/legacyvar.h
 delete mode 100644 freebsd/sys/i386/include/machine/specialreg.h
 create mode 100644 rtemsbsd/include/x86/legacyvar.h
 create mode 100644 rtemsbsd/include/x86/x86_var.h
diff --git a/freebsd/sys/i386/i386/legacy.c b/freebsd/sys/i386/i386/legacy.c
deleted file mode 100644
index 50fa9aa2..00000000
--- a/freebsd/sys/i386/i386/legacy.c
+++ /dev/null
@@ -1,381 +0,0 @@
-#include <machine/rtems-bsd-kernel-space.h>
- * Copyright 1998 Massachusetts Institute of Technology
- * Permission to use, copy, modify, and distribute this software and
- * its documentation for any purpose and without fee is hereby
- * granted, provided that both the above copyright notice and this
- * permission notice appear in all copies, that both the above
- * copyright notice and this permission notice appear in all
- * supporting documentation, and that the name of M.I.T. not be used
- * in advertising or publicity pertaining to distribution of the
- * software without specific, written prior permission.  M.I.T. makes
- * no representations about the suitability of this software for any
- * purpose.  It is provided "as is" without express or implied
- * warranty.
- * THIS SOFTWARE IS PROVIDED BY M.I.T. ``AS IS''.  M.I.T. DISCLAIMS
- * ALL EXPRESS OR IMPLIED WARRANTIES WITH REGARD TO THIS SOFTWARE,
- * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
- * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT
- * SHALL M.I.T. BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
- * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
- * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
- * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
- * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
- * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
- * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
-#include <sys/cdefs.h>
-__FBSDID("$FreeBSD$");
- * This code implements a system driver for legacy systems that do not
- * support ACPI or when ACPI support is not present in the kernel.
-#include <sys/param.h>
-#include <sys/systm.h>
-#include <sys/bus.h>
-#include <sys/cpu.h>
-#include <sys/kernel.h>
-#include <sys/malloc.h>
-#include <sys/module.h>
-#include <machine/bus.h>
-#include <sys/pcpu.h>
-#include <sys/rman.h>
-#include <sys/smp.h>
-#include <rtems/bsd/local/opt_mca.h>
-#ifdef DEV_MCA
-#include <i386/bios/mca_machdep.h>
-#endif
-#include <machine/clock.h>
-#include <machine/legacyvar.h>
-#include <machine/resource.h>
-static MALLOC_DEFINE(M_LEGACYDEV, "legacydrv", "legacy system device");
-struct legacy_device {
-	int	lg_pcibus;
-	int	lg_pcislot;
-	int	lg_pcifunc;
-#define DEVTOAT(dev)	((struct legacy_device *)device_get_ivars(dev))
-static	int legacy_probe(device_t);
-static	int legacy_attach(device_t);
-static	int legacy_print_child(device_t, device_t);
-static device_t legacy_add_child(device_t bus, u_int order, const char *name,
-				int unit);
-static	int legacy_read_ivar(device_t, device_t, int, uintptr_t *);
-static	int legacy_write_ivar(device_t, device_t, int, uintptr_t);
-static device_method_t legacy_methods[] = {
-	/* Device interface */
-	DEVMETHOD(device_probe,		legacy_probe),
-	DEVMETHOD(device_attach,	legacy_attach),
-	DEVMETHOD(device_detach,	bus_generic_detach),
-	DEVMETHOD(device_shutdown,	bus_generic_shutdown),
-	DEVMETHOD(device_suspend,	bus_generic_suspend),
-	DEVMETHOD(device_resume,	bus_generic_resume),
-	/* Bus interface */
-	DEVMETHOD(bus_print_child,	legacy_print_child),
-	DEVMETHOD(bus_add_child,	legacy_add_child),
-	DEVMETHOD(bus_read_ivar,	legacy_read_ivar),
-	DEVMETHOD(bus_write_ivar,	legacy_write_ivar),
-	DEVMETHOD(bus_alloc_resource,	bus_generic_alloc_resource),
-	DEVMETHOD(bus_adjust_resource,	bus_generic_adjust_resource),
-	DEVMETHOD(bus_release_resource,	bus_generic_release_resource),
-	DEVMETHOD(bus_activate_resource, bus_generic_activate_resource),
-	DEVMETHOD(bus_deactivate_resource, bus_generic_deactivate_resource),
-	DEVMETHOD(bus_setup_intr,	bus_generic_setup_intr),
-	DEVMETHOD(bus_teardown_intr,	bus_generic_teardown_intr),
-	{ 0, 0 }
-static driver_t legacy_driver = {
-	"legacy",
-	legacy_methods,
-	1,			/* no softc */
-static devclass_t legacy_devclass;
-DRIVER_MODULE(legacy, nexus, legacy_driver, legacy_devclass, 0, 0);
-static int
-legacy_probe(device_t dev)
-	device_set_desc(dev, "legacy system");
-	device_quiet(dev);
-	return (0);
-static int
-legacy_attach(device_t dev)
-	device_t child;
-	 * Let our child drivers identify any child devices that they
-	 * can find.  Once that is done attach any devices that we
-	 * found.
-	bus_generic_probe(dev);
-	bus_generic_attach(dev);
-#ifndef PC98
-	 * If we didn't see EISA or ISA on a pci bridge, create some
-	 * connection points now so they show up "on motherboard".
-	if (!devclass_get_device(devclass_find("eisa"), 0)) {
-		child = BUS_ADD_CHILD(dev, 0, "eisa", 0);
-		if (child == NULL)
-			panic("legacy_attach eisa");
-		device_probe_and_attach(child);
-#endif
-#ifdef DEV_MCA
-	if (MCA_system && !devclass_get_device(devclass_find("mca"), 0)) {
-        	child = BUS_ADD_CHILD(dev, 0, "mca", 0);
-        	if (child == 0)
-                	panic("legacy_probe mca");
-#endif
-	if (!devclass_get_device(devclass_find("isa"), 0)) {
-		child = BUS_ADD_CHILD(dev, 0, "isa", 0);
-			panic("legacy_attach isa");
-	return 0;
-static int
-legacy_print_child(device_t bus, device_t child)
-	struct legacy_device *atdev = DEVTOAT(child);
-	int retval = 0;
-	retval += bus_print_child_header(bus, child);
-	if (atdev->lg_pcibus != -1)
-		retval += printf(" pcibus %d", atdev->lg_pcibus);
-	retval += printf(" on motherboard\n");	/* XXX "motherboard", ick */
-	return (retval);
-static device_t
-legacy_add_child(device_t bus, u_int order, const char *name, int unit)
-	device_t child;
-	struct legacy_device *atdev;
-	atdev = malloc(sizeof(struct legacy_device), M_LEGACYDEV,
-	    M_NOWAIT | M_ZERO);
-	if (atdev == NULL)
-		return(NULL);
-	atdev->lg_pcibus = -1;
-	atdev->lg_pcislot = -1;
-	atdev->lg_pcifunc = -1;
-	child = device_add_child_ordered(bus, order, name, unit);
-		free(atdev, M_LEGACYDEV);
-	else
-		/* should we free this in legacy_child_detached? */
-		device_set_ivars(child, atdev);
-	return (child);
-static int
-legacy_read_ivar(device_t dev, device_t child, int which, uintptr_t *result)
-	switch (which) {
-	case LEGACY_IVAR_PCIDOMAIN:
-		*result = 0;
-		break;
-	case LEGACY_IVAR_PCIBUS:
-		*result = atdev->lg_pcibus;
-		break;
-	case LEGACY_IVAR_PCISLOT:
-		*result = atdev->lg_pcislot;
-		break;
-	case LEGACY_IVAR_PCIFUNC:
-		*result = atdev->lg_pcifunc;
-		break;
-	default:
-		return ENOENT;
-	return 0;
-static int
-legacy_write_ivar(device_t dev, device_t child, int which, uintptr_t value)
-	switch (which) {
-		return EINVAL;
-		atdev->lg_pcibus = value;
-		break;
-		atdev->lg_pcislot = value;
-		break;
-		atdev->lg_pcifunc = value;
-		break;
-	default:
-		return ENOENT;
-	return 0;
- * Legacy CPU attachment when ACPI is not available.  Drivers like
- * cpufreq(4) hang off this.
-static void	cpu_identify(driver_t *driver, device_t parent);
-static int	cpu_read_ivar(device_t dev, device_t child, int index,
-		    uintptr_t *result);
-static device_t cpu_add_child(device_t bus, u_int order, const char *name,
-		    int unit);
-static struct resource_list *cpu_get_rlist(device_t dev, device_t child);
-struct cpu_device {
-	struct resource_list cd_rl;
-#ifndef __rtems__
-	struct pcpu *cd_pcpu;
-#endif /* __rtems__ */
-static device_method_t cpu_methods[] = {
-	DEVMETHOD(device_identify,	cpu_identify),
-	DEVMETHOD(device_probe,		bus_generic_probe),
-	DEVMETHOD(device_attach,	bus_generic_attach),
-	DEVMETHOD(bus_add_child,	cpu_add_child),
-	DEVMETHOD(bus_read_ivar,	cpu_read_ivar),
-	DEVMETHOD(bus_get_resource_list, cpu_get_rlist),
-	DEVMETHOD(bus_get_resource,	bus_generic_rl_get_resource),
-	DEVMETHOD(bus_set_resource,	bus_generic_rl_set_resource),
-	DEVMETHOD(bus_alloc_resource,	bus_generic_rl_alloc_resource),
-	DEVMETHOD(bus_release_resource,	bus_generic_rl_release_resource),
-	DEVMETHOD_END
-static driver_t cpu_driver = {
-	"cpu",
-	cpu_methods,
-	1,		/* no softc */
-static devclass_t cpu_devclass;
-DRIVER_MODULE(cpu, legacy, cpu_driver, cpu_devclass, 0, 0);
-static void
-cpu_identify(driver_t *driver, device_t parent)
-	device_t child;
-	int i;
-	 * Attach a cpuX device for each CPU.  We use an order of 150
-	 * so that these devices are attached after the Host-PCI
-	 * bridges (which are added at order 100).
-	CPU_FOREACH(i) {
-		child = BUS_ADD_CHILD(parent, 150, "cpu", i);
-			panic("legacy_attach cpu");
-static device_t
-cpu_add_child(device_t bus, u_int order, const char *name, int unit)
-	struct cpu_device *cd;
-	device_t child;
-#ifndef __rtems__
-	struct pcpu *pc;
-	if ((cd = malloc(sizeof(*cd), M_DEVBUF, M_NOWAIT | M_ZERO)) == NULL)
-		return (NULL);
-	resource_list_init(&cd->cd_rl);
-#ifndef __rtems__
-	pc = pcpu_find(device_get_unit(bus));
-	cd->cd_pcpu = pc;
-	if (child != NULL) {
-#ifndef __rtems__
-		pc->pc_device = child;
-		device_set_ivars(child, cd);
-	} else
-		free(cd, M_DEVBUF);
-	return (child);
-cpu_get_rlist(device_t dev, device_t child)
-	struct cpu_device *cpdev;
-	cpdev = device_get_ivars(child);
-	return (&cpdev->cd_rl);
-static int
-cpu_read_ivar(device_t dev, device_t child, int index, uintptr_t *result)
-	switch (index) {
-#ifndef __rtems__
-	case CPU_IVAR_PCPU:
-		*result = (uintptr_t)cpdev->cd_pcpu;
-		break;
-	case CPU_IVAR_NOMINAL_MHZ:
-		if (tsc_is_invariant) {
-			*result = (uintptr_t)(atomic_load_acq_64(&tsc_freq) /
-			    1000000);
-			break;
-		/* FALLTHROUGH */
-	default:
-		return (ENOENT);
-	return (0);
diff --git a/freebsd/sys/i386/include/machine/legacyvar.h b/freebsd/sys/i386/include/machine/legacyvar.h
index 14dd9e03..00000000
--- a/freebsd/sys/i386/include/machine/legacyvar.h
+++ /dev/null
@@ -1,63 +0,0 @@
- * Copyright (c) 2000 Peter Wemm <peter at FreeBSD.org>
- * All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- *    notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- *    notice, this list of conditions and the following disclaimer in the
- *    documentation and/or other materials provided with the distribution.
- * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
- * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
- * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
- * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
- * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
- * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
- * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
- * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
- * $FreeBSD$
-#ifndef _MACHINE_LEGACYVAR_H_
-#define	_MACHINE_LEGACYVAR_H_
-enum legacy_device_ivars {
-	LEGACY_IVAR_PCIDOMAIN,
-	LEGACY_IVAR_PCIBUS,
-	LEGACY_IVAR_PCISLOT,
-	LEGACY_IVAR_PCIFUNC
-#define LEGACY_ACCESSOR(var, ivar, type)				\
-    __BUS_ACCESSOR(legacy, var, LEGACY, ivar, type)
-LEGACY_ACCESSOR(pcidomain,		PCIDOMAIN,	uint32_t)
-LEGACY_ACCESSOR(pcibus,			PCIBUS,		uint32_t)
-LEGACY_ACCESSOR(pcislot,		PCISLOT,	int)
-LEGACY_ACCESSOR(pcifunc,		PCIFUNC,	int)
-#undef LEGACY_ACCESSOR
-int	legacy_pcib_maxslots(device_t dev);
-uint32_t legacy_pcib_read_config(device_t dev, u_int bus, u_int slot, u_int func,
-    u_int reg, int bytes);
-int	legacy_pcib_read_ivar(device_t dev, device_t child, int which,
-void	legacy_pcib_write_config(device_t dev, u_int bus, u_int slot, u_int func,
-    u_int reg, u_int32_t data, int bytes);
-int	legacy_pcib_write_ivar(device_t dev, device_t child, int which,
-    uintptr_t value);
-struct resource *legacy_pcib_alloc_resource(device_t dev, device_t child,
-    int type, int *rid, u_long start, u_long end, u_long count, u_int flags);
-int	legacy_pcib_map_msi(device_t pcib, device_t dev, int irq,
-    uint64_t *addr, uint32_t *data);
-#endif /* !_MACHINE_LEGACYVAR_H_ */
diff --git a/freebsd/sys/i386/include/machine/specialreg.h b/freebsd/sys/i386/include/machine/specialreg.h
index aace4bfd..00000000
--- a/freebsd/sys/i386/include/machine/specialreg.h
+++ /dev/null
@@ -1,6 +0,0 @@
- * This file is in the public domain.
-/* $FreeBSD$ */
-#include <x86/specialreg.h>
diff --git a/rtemsbsd/include/x86/legacyvar.h b/rtemsbsd/include/x86/legacyvar.h
new file mode 100644
index 00000000..6f8573bb
--- /dev/null
+++ b/rtemsbsd/include/x86/legacyvar.h
@@ -0,0 +1 @@
+#include <machine/legacyvar.h>
diff --git a/rtemsbsd/include/x86/x86_var.h b/rtemsbsd/include/x86/x86_var.h
index 00000000..5819205a
--- /dev/null
+++ b/rtemsbsd/include/x86/x86_var.h
@@ -0,0 +1 @@
+#include <machine/x86_var.h>
2.12.3
