[PATCH] Test for clock_nanosleep() with CLOCK_MONOTONIC option.
Tue Apr 21 17:13:55 UTC 2020
On Tue, Apr 21, 2020 at 4:33 AM Utkarsh Rai <utkarsh.rai60 at gmail.com> wrote:
> Rationale for a new test-
> >Although most of the test cases for this test have been taken from clockrealtime,
> adding it to the current test with CLOCK_MONOTONIC may break the existing cases.
> >This test has a new case which tests for no change of delay with monotonic clock when
> the realtime clock has been modified, this is easier to add in a new test.
>  testsuites/psxtests/Makefile.am               |  10 +
>  testsuites/psxtests/configure.ac              |   1 +
>  testsuites/psxtests/psxclocknanosleep/init.c  | 182 ++++++++++++++++++
>  .../psxclocknanosleep/psxclocknanosleep.doc   |  15 ++
>  .../psxclocknanosleep/psxclocknanosleep.scn   |  14 ++
>  5 files changed, 222 insertions(+)
>  create mode 100644 testsuites/psxtests/psxclocknanosleep/init.c
>  create mode 100644 testsuites/psxtests/psxclocknanosleep/psxclocknanosleep.doc
>  create mode 100644 testsuites/psxtests/psxclocknanosleep/psxclocknanosleep.scn
> diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
> index 1f9e4233ec..ad6e41b400 100755
> --- a/testsuites/psxtests/Makefile.am
> +++ b/testsuites/psxtests/Makefile.am
> @@ -312,6 +312,16 @@ psxclock01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxclock01) \
>         $(support_includes) -I$(top_srcdir)/include
>  endif
> +if TEST_psxclocknanosleep
please append 01 to the name.
> +psx_tests += psxclocknanosleep
> +psx_screens += psxclocknanosleep/psxclocknanosleep.scn
> +psx_docs += psxclockrealtime01/psxclocknanosleep.doc
realtime01
> +psxclocknanosleep_SOURCES = psxclocknanosleep/init.c
> +psxclocknanosleep_CPPFLAGS = $(AM_CPPFLAGS) \
> +       $(TEST_FLAGS_psxclocknanosleep) $(support_includes)
> +endif
>  if TEST_psxclockrealtime01
>  psx_tests += psxclockrealtime01
>  psx_screens += psxclockrealtime01/psxclockrealtime01.scn
> diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
> index 139787cccb..52b5e1624b 100644
> --- a/testsuites/psxtests/configure.ac
> +++ b/testsuites/psxtests/configure.ac
> @@ -75,6 +75,7 @@ RTEMS_TEST_CHECK([psxcleanup01])
>  RTEMS_TEST_CHECK([psxcleanup02])
>  RTEMS_TEST_CHECK([psxclock])
>  RTEMS_TEST_CHECK([psxclock01])
> +RTEMS_TEST_CHECK([psxclocknanosleep])
>  RTEMS_TEST_CHECK([psxclockrealtime01])
>  RTEMS_TEST_CHECK([psxconcurrency01])
>  RTEMS_TEST_CHECK([psxcond01])
> diff --git a/testsuites/psxtests/psxclocknanosleep/init.c b/testsuites/psxtests/psxclocknanosleep/init.c
> new file mode 100644
> index 0000000000..15e3ff396a
> --- /dev/null
> +++ b/testsuites/psxtests/psxclocknanosleep/init.c
> @@ -0,0 +1,182 @@
> + *  Copyright (c) 2020 Utkarsh Rai.
> + *  The license and distribution terms for this file may be
> + *  found in the file LICENSE in this distribution or at
> + *  http://www.rtems.org/license/LICENSE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <errno.h>
> +#include <limits.h>
> +#include <rtems.h>
> +#include <time.h>
> +#include <tmacros.h>
> +static void assert_eno(const char *hint, int eno, int expected_eno)
> +  const char *warn;
> +  if (eno != expected_eno) {
> +    warn = "WARNING: ";
> +  } else {
> +    warn = "";
minor nit, you can save some SLOC and conditional branches by
initializing one state, and switching to other. Putting the most
expected state as default/initial is good practice.
So maybe
const char *warn = "";
if ( eno != expected_eno ) {
  warn = "WARNING: ";
Also note the spacing inside the conditional expression.
> +  printf(
> +    "%s%s: actual '%s', expected '%s'\n",
> +    warn,
> +    hint,
> +    strerror(eno),
> +    strerror(expected_eno)
> +  rtems_test_assert( eno == expected_eno );
> +static void assert_rv(const char *hint, int rv, int expected_eno)
> +  int eno;
> +  if (rv != 0) {
> +    eno = EINVAL;
> +  } else {
> +    eno = 0;
ditto
> +  assert_eno(hint, eno, expected_eno);
spacing inside parens (But for function/macro, not before ( or after ).
> +typedef enum {
> +  MODE_TIMEOUT_FINITE,
> +  MODE_TIMEOUT_NEGATIVE_SEC,
> +  MODE_TIMEOUT_NEGATIVE_NSEC,
> +  MODE_TIMEOUT_NEGATIVE_SEC_NSEC,
> +  MODE_TIMEOUT_HUGE_NSEC,
> +  MODE_TIMEOUT_CLOCK_MODIFY
> +} test_mode;
I don't know if it is a rule, but I would put all type declarations
(and global decls) before functions. It helps readability.
> +static void run(test_mode mode, const char* test_name)
> + struct timespec  delay_time;
> + struct timespec  configure_time;
> + int     rv;
> + int     expected_eno;
> + switch (mode) {
> + case MODE_TIMEOUT_FINITE:
I think we indent the case statement. Check for examples in current
code base, and update rules if it is not present in
https://docs.rtems.org/branches/master/eng/coding-conventions.html
> +   rv = clock_gettime( CLOCK_MONOTONIC, &delay_time );
> +   rtems_test_assert( rv == 0 );
> +   delay_time.tv_sec += 1;
> +   delay_time.tv_nsec += 1;
> +   expected_eno = ETIMEDOUT;
> +   break;
Nice to add a blank line after break. Again not sure if it is a rule,
or should be one or not.
> + case MODE_TIMEOUT_HUGE_NSEC:
> +   delay_time.tv_sec = 1;
> +   delay_time.tv_nsec = LONG_MAX;
> +   expected_eno = EINVAL;
> +   break;
> + case MODE_TIMEOUT_NEGATIVE_NSEC:
> +   delay_time.tv_nsec = -1;
> +   break;
> + case MODE_TIMEOUT_NEGATIVE_SEC_NSEC:
> +   delay_time.tv_sec = -1;
> +   break;
> + case MODE_TIMEOUT_NEGATIVE_SEC:
> +   delay_time.tv_nsec = 1;
> +   break;
> + case MODE_TIMEOUT_CLOCK_MODIFY:
> +   rv = clock_gettime( CLOCK_REALTIME, &configure_time );
> +   configure_time.tv_sec += INT64_MAX;
I'd remove this blank line, it interrupts the readability flow here.
> +   rv = clock_settime( CLOCK_REALTIME, &configure_time );
> +   break;
> + default:
> +   rtems_test_assert(0);
> +   break;
> + printf("*******%s*********\n", test_name);
I think it should be printed at the start of the test, not after
already performing some logic checks?
> + rv = clock_nanosleep( CLOCK_MONOTONIC, TIMER_ABSTIME, &delay_time, NULL );
> + if (expected_eno == ETIMEDOUT) {
> +          assert_rv( "clock_nanosleep(clock monotonic)", rv, 0 );
> +        } else {
> +          assert_rv( "clock_nanosleep(clock monotonic)", rv, expected_eno );
alignment problem, too many spaces in this block.
> +static void timeout_finite(void)
> +    run ( MODE_TIMEOUT_FINITE, "timeout finite" );
no space between function/macro name and opening parens. (This is
because function-like macros break with a space.) Repeated below
> +static void timeout_huge_nsec(void)
> +    run( MODE_TIMEOUT_HUGE_NSEC, "timeout huge nsec" );
> +static void timeout_negative_nsec(void)
> +    run( MODE_TIMEOUT_NEGATIVE_NSEC, "timeout negative nsec" );
> +static void timeout_negative_sec_nsec(void)
> +    run( MODE_TIMEOUT_NEGATIVE_SEC_NSEC, "timeout negative sec nsec" );
> +static void timeout_negative_sec(void)
> +    run( MODE_TIMEOUT_NEGATIVE_SEC, "timeout negative sec" );
> +static void timeout_clock_modify(void)
> +    run( MODE_TIMEOUT_CLOCK_MODIFY, "timeout clock modify" );
> +const char rtems_test_name[] = "PSXCLOCKNANOSLEEP";
01
> +static rtems_task Init(rtems_task_argument ignored)
> +  TEST_BEGIN();
> +  timeout_finite();
> +  timeout_huge_nsec();
> +  timeout_negative_sec_nsec();
> +  timeout_negative_nsec();
> +  timeout_negative_sec();
> +  timeout_clock_modify();
This could be done simpler, but it seems OK. The functions are
superfluous when you could just do
  run( MODE_TIMEOUT_FINITE, "timeout finite")
etcetera, directly here.
> +  TEST_END();
> +  rtems_test_exit(0);
> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#define CONFIGURE_MAXIMUM_TASKS  1
> +#define CONFIGURE_INIT
> +#include <rtems/confdefs.h>
> \ No newline at end of file
> diff --git a/testsuites/psxtests/psxclocknanosleep/psxclocknanosleep.doc b/testsuites/psxtests/psxclocknanosleep/psxclocknanosleep.doc
> index 0000000000..a87874c627
> --- /dev/null
> +++ b/testsuites/psxtests/psxclocknanosleep/psxclocknanosleep.doc
> @@ -0,0 +1,15 @@
> +This file describes the directives and concepts tested by this test set.
> +test set name: psxclocknanosleep
01
> +directives:
> +  - clock_nanosleep()
> +concepts:
> +  - Test some invalid and extreme timeout values.
> +  - Ensure that the CLOCK_MONOTONIC based delay is not effected by changes to
s/effected/affected
Effect is a noun, Affect is a verb.
> +    CLOCK_REALTIME
> diff --git a/testsuites/psxtests/psxclocknanosleep/psxclocknanosleep.scn b/testsuites/psxtests/psxclocknanosleep/psxclocknanosleep.scn
> index 0000000000..af803c8b14
> --- /dev/null
> +++ b/testsuites/psxtests/psxclocknanosleep/psxclocknanosleep.scn
> @@ -0,0 +1,14 @@
> +*** BEGIN OF TEST PSXCLOCKNANOSLEEP ***
> +*******timeout finite*********
> +clock_nanosleep(clock monotonic): actual 'Success', expected 'Success'
> +*******timeout huge nsec*********
> +clock_nanosleep(clock monotonic): actual 'Invalid argument', expected 'Invalid argument'
> +*******timeout negative sec nsec*********
> +*******timeout negative nsec*********
> +*******timeout negative sec*********
> +*******timeout clock modify*********
> +*** END OF TEST PSXCLOCKNANOSLEEP ***
> 2.17.1
> devel mailing list
> devel at rtems.org
