Need help in figuring out how a node gets its afffinity when it is created
Richi Dubey richidubey at gmail.com
Fri Aug 14 09:56:22 UTC 2020
Hi,
My code is failing because its logic assumed (code here
<https://github.com/richidubey/rtems/blob/03650c47c537c1acd584c5a9c3db588ab49634ef/cpukit/score/src/schedulerstrongapa.c#L315>)
that it would never get a node with an empty affinity (i.e. no affinity to
any processor or a 0 affinity). This assumption proved wrong as I can see
from the gdb and the current flow of code observed is:
_Scheduler_strong_APA_Get_lowest_scheduled
_Scheduler_SMP_Enqueue
_Scheduler_strong_APA_Enqueue
_Scheduler_SMP_Unblock
_Scheduler_strong_APA_Unblock
_Scheduler_Unblock
_Thread_Clear_state_locked
_Thread_Start
rtems_task_start
_RTEMS_tasks_Initialize_user_task
rtems_initialize_executive
boot_card
bsp_start_hook_0_done
Why is this happening? The Affinity variable (defined here
<https://github.com/richidubey/rtems/blob/03650c47c537c1acd584c5a9c3db588ab49634ef/cpukit/include/rtems/score/schedulerstrongapa.h#L75>)
gets set whenever the Set affinity operation corresponding to Strong_APA
scheduler (defined here
<https://github.com/richidubey/rtems/blob/03650c47c537c1acd584c5a9c3db588ab49634ef/cpukit/score/src/schedulerstrongapa.c#L770>)
gets called. So, why wasn't this function called before this happened? Any
help would be appreciated.
Thanks,
Richi.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200814/935f3401/attachment.html>
