[PATCH] Strict thread-stack isolation and thread-stack sharing.
Sat Aug 15 05:00:57 UTC 2020
If it can be non POSIX threads sharing stacks, it needs to be a different
limit (CONFIGURE_MAXIMUM_TASKS may work, I forget if that combines classic
and pthreads
On Fri, Aug 14, 2020, 9:29 PM Utkarsh Rai <utkarsh.rai60 at gmail.com> wrote:
> On Sat, Aug 15, 2020 at 12:39 AM Gedare Bloom <gedare at rtems.org> wrote:
>> On Fri, Aug 14, 2020 at 9:25 AM Utkarsh Rai <utkarsh.rai60 at gmail.com>
>> wrote:
>> > Sorry for the late reply, I somehow missed the mail notification!
>> > On Thu, Aug 13, 2020 at 9:35 PM Gedare Bloom <gedare at rtems.org> wrote:
>> >> On Thu, Aug 13, 2020 at 9:06 AM Utkarsh Rai <utkarsh.rai60 at gmail.com>
>> wrote:
>> >> > -This patch provides thread-stack isolation and thread-stack sharing
>> >> >  mechanism for a POSIX thread.
>> >> Monster patch! think to yourself whether or not it makes sense to
>> >> split these up. The main constraint is that every patch in the series
>> >> should compile/run as they are applied.
>> > Maybe I can break this up into 3 separate patches, stack-isolation,
>> stack-sharing, and the configuration option?
>> >> > -The patches are based on sebastian's build-2 branch of sebastian's
>> repo https://git.rtems.org/sebh
>> >> > -Configurations options are provided by using the new-build system.
>> Refer to https://ftp.rtems.org/pub/rtems/people/sebh/user.pdf,
>> >> >  chapter 7,for basic setup and
>> https://ftp.rtems.org/pub/rtems/people/sebh/eng.pdf(chapter 9) for the
>> internals of the build system.
>> >> >  .../realview-pbx-a9/mmu/bsp-set-mmu-attr.c    |  75 ++++++++++
>> >> >  bsps/shared/start/stackalloc.c                |  12 +-
>> >> >  .../libbsp/arm/realview-pbx-a9/Makefile.am    |   3 +
>> >> >  cpukit/Makefile.am                            |   1 +
>> >> >  cpukit/headers.am                             |   2 +
>> >> >  cpukit/include/rtems/score/memoryprotection.h |  91 ++++++++++++
>> >> >  cpukit/include/rtems/score/stack.h            |  49 +++++++
>> >> >  cpukit/include/rtems/score/stackprotection.h  |  80 +++++++++++
>> >> >  cpukit/include/rtems/score/thread.h           |   1 +
>> >> >  cpukit/posix/src/mmap.c                       |  41 +++++-
>> >> >  cpukit/posix/src/shmwkspace.c                 |  46 +++++-
>> >> >  cpukit/score/cpu/arm/cpu_asm.S                |  94 ++++++++++++
>> >> >  cpukit/score/src/stackprotection.c            | 103 +++++++++++++
>> >> >  cpukit/score/src/threadhandler.c              |   6 +
>> >> >  cpukit/score/src/threadinitialize.c           |   9 ++
>> >> >  .../arm/realview-pbx-a9/bsprealviewpbxa9.yml  |   1 +
>> >> >  spec/build/cpukit/cpuopts.yml                 |   2 +
>> >> >  spec/build/cpukit/librtemscpu.yml             |   3 +
>> >> >  .../build/cpukit/optthreadstackprotection.yml |  16 +++
>> >> >  spec/build/testsuites/samples/grp.yml         |   4 +
>> >> >  .../samples/threadstackprotection.yml         |  19 +++
>> >> >  .../testsuites/samples/threadstacksharing.yml |  19 +++
>> >> >  testsuites/samples/Makefile.am                |  16 +++
>> >> >  testsuites/samples/configure.ac               |   2 +
>> >> >  .../samples/thread_stack_protection/init.c    | 112 +++++++++++++++
>> >> >  .../thread_stack_protection.doc               |   2 +
>> >> >  .../thread_stack_protection.scn               |  20 +++
>> >> >  .../samples/thread_stack_sharing/init.c       | 136
>> >> >  28 files changed, 959 insertions(+), 6 deletions(-)
>> >> >  create mode 100644 bsps/arm/realview-pbx-a9/mmu/bsp-set-mmu-attr.c
>> >> >  create mode 100644 cpukit/include/rtems/score/memoryprotection.h
>> >> >  create mode 100644 cpukit/include/rtems/score/stackprotection.h
>> >> >  create mode 100644 cpukit/score/src/stackprotection.c
>> >> >  create mode 100644 spec/build/cpukit/optthreadstackprotection.yml
>> >> >  create mode 100644
>> spec/build/testsuites/samples/threadstackprotection.yml
>> >> >  create mode 100644
>> spec/build/testsuites/samples/threadstacksharing.yml
>> >> >  create mode 100644 testsuites/samples/thread_stack_protection/init.c
>> >> >  create mode 100644
>> testsuites/samples/thread_stack_protection/thread_stack_protection.doc
>> >> >  create mode 100644
>> testsuites/samples/thread_stack_protection/thread_stack_protection.scn
>> >> >  create mode 100644 testsuites/samples/thread_stack_sharing/init.c
>> >> > diff --git a/bsps/arm/realview-pbx-a9/mmu/bsp-set-mmu-attr.c
>> b/bsps/arm/realview-pbx-a9/mmu/bsp-set-mmu-attr.c
>> >> > new file mode 100644
>> >> > index 0000000000..c3b469dd2a
>> >> > --- /dev/null
>> >> > +++ b/bsps/arm/realview-pbx-a9/mmu/bsp-set-mmu-attr.c
>> >> > @@ -0,0 +1,75 @@
>> >> file header block?
>> >> > +#include <bsp/arm-cp15-start.h>
>> >> > +#include <rtems/score/memoryprotection.h>
>> >> > +#include <libcpu/arm-cp15.h>
>> >> > +#include <rtems.h>
>> >> > +static uint32_t translate_flags(uint32_t attr_flags)
>> >> > +  uint32_t flags;
>> >> > +  uint32_t memory_attribute;
>> >> > +  switch (attr_flags)
>> >> > +    case RTEMS_READ_WRITE:
>> >> > +     flags = ARMV7_MMU_READ_WRITE;
>> >> > +     break;
>> >> > +    case RTEMS_READ_ONLY:
>> >> > +     flags = ARMV7_MMU_READ_ONLY;
>> >> > +     break;
>> >> > +    case RTEMS_NO_ACCESS:
>> >> > +    default:
>> >> > +     flags = 0;
>> >> > +     break;
>> >> Does this switch statement work when the attr_flags have other fields
>> >> defined such as RTEMS_MEMORY_CACHED?
>> > Yes, I missed that.
>> >> When bit flags are not mutually exclusive it makes more sense to write
>> as...
>> >> if ( (attr_flags & RTEMS_READ_WRITE) == RTEMS_READ_WRITE) ) {
>> >> if ( ... ) {
>> >> Maybe it makes more sense to write your helper function this way?
>> >> > +  * Check for memory-cache operation
>> >> > +  if( attr_flags & RTEMS_MEMORY_CACHED ) {
>> >> > +    flags |= ARM_MMU_SECT_TEX_0 | ARM_MMU_SECT_C | ARM_MMU_SECT_B;
>> >> > +  return flags;
>> >> > +void _Memory_protection_Set_entries(uintptr_t begin, size_t size,
>> uint32_t flags)
>> >> > +  uintptr_t end;
>> >> > +  rtems_interrupt_level irq_level;
>> >> > +  uint32_t access_flags;
>> >> > +  if(begin != NULL ) {
>> >> whitespace: "if ( begin ..."
>> >> If begin is invalid, the set_entries fails. Maybe you want to return
>> >> an error code?
>> >> You might want to refactor a helper to validate the memory range. That
>> >> will make this easier to maintain and tighten the checks.
>> > We can only change the memory attributes of the workspace and heap
>> region, so we need to check the memory range for only these regions right?
>> For data protection that is probably true.
>> >> > +    end = begin + size;
>> >> > +    access_flags = translate_flags(flags);
>> >> > +     * The ARM reference manual instructs to disable all the
>> interrupts before
>> >> > +     * setting up page table entries.
>> >> > +    rtems_interrupt_disable(irq_level);
>> >> > +    arm_cp15_set_translation_table_entries(begin, end,
>> access_flags);
>> >> > +    rtems_interrupt_enable(irq_level);
>> >> > +void _Memory_protection_Unset_entries(uintptr_t begin, size_t size)
>> >> > +  uintptr_t end;
>> >> > +  if( begin != NULL ) {
>> >> > +    access_flags = translate_flags( RTEMS_NO_ACCESS );
>> interrupts before
>> access_flags);
>> >> > \ No newline at end of file
>> >> > diff --git a/bsps/shared/start/stackalloc.c
>> b/bsps/shared/start/stackalloc.c
>> >> > index f7cf7be0f1..6ebef4d6e5 100644
>> >> > --- a/bsps/shared/start/stackalloc.c
>> >> > +++ b/bsps/shared/start/stackalloc.c
>> >> > @@ -44,6 +44,15 @@ void *bsp_stack_allocate(size_t size)
>> >> >    void *stack = NULL;
>> >> > +#if defined (RTEMS_THREAD_STACK_PROTECTION)
>> >> > + * This is a temporary hack, we need to use
>> _Heap_Allocate_aligned() but the heap
>> >> > + * intialization for bsp_stack_heap fails as bsp_section_stack_size
>> is 0. See
>> >> typo: initialization
>> >> > + * bsp_stack_allocate_init().
>> >> This is an interesting problem. You may want to explore how to solve
>> >> this better.
>> >> > +  posix_memalign(&stack, 4096 , size);
>> >> > +  _Memory_protection_Set_entries( stack, size, ( RTEMS_READ_ONLY |
>> RTEMS_MEMORY_CACHED ) );
>> >> > +#else
>> >> >    if (bsp_stack_heap.area_begin != 0) {
>> >> >      stack = _Heap_Allocate(&bsp_stack_heap, size);
>> >> > @@ -51,6 +60,7 @@ void *bsp_stack_allocate(size_t size)
>> >> >    if (stack == NULL) {
>> >> >      stack = _Workspace_Allocate(size);
>> >> > +#endif
>> >> >    return stack;
>> >> > @@ -62,4 +72,4 @@ void bsp_stack_free(void *stack)
>> >> >    if (!ok) {
>> >> >      _Workspace_Free(stack);
>> >> spurious change. check the settings on your text editor. It seems to
>> >> be truncating the end of your files.
>> >> > diff --git a/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am
>> b/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am
>> >> > index d5549275be..24847c7b91 100644
>> >> > --- a/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am
>> >> > +++ b/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am
>> >> > @@ -74,6 +74,9 @@ librtemsbsp_a_SOURCES +=
>> ../../../../../../bsps/arm/shared/clock/clock-a9mpcore.
>> ../../../../../../bsps/arm/shared/cache/cache-cp15.c
>> ../../../../../../bsps/arm/shared/cache/cache-v7ar-disable-data.S
>> >> > +#MMU
>> >> > +librtemsbsp_a_SOURCES +=
>> ../../../../../../bsps/arm/realview-pbx-a9/mmu/bsp-set-mmu-attr.c
>> >> >  # Start hooks
>> ../../../../../../bsps/arm/realview-pbx-a9/start/bspstarthooks.c
>> >> > diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
>> >> > index 75e119ea3c..2d50d0fdce 100644
>> >> > --- a/cpukit/Makefile.am
>> >> > +++ b/cpukit/Makefile.am
>> >> > @@ -929,6 +929,7 @@ librtemscpu_a_SOURCES +=
>> score/src/schedulercbsgetserverid.c
>> >> >  librtemscpu_a_SOURCES += score/src/schedulercbssetparameters.c
>> >> >  librtemscpu_a_SOURCES += score/src/schedulercbsreleasejob.c
>> >> >  librtemscpu_a_SOURCES += score/src/schedulercbsunblock.c
>> >> > +librtemscpu_a_SOURCES += score/src/stackprotection.c
>> >> >  librtemscpu_a_SOURCES += score/src/stackallocator.c
>> >> >  librtemscpu_a_SOURCES += score/src/pheapallocate.c
>> >> >  librtemscpu_a_SOURCES += score/src/pheapextend.c
>> >> > diff --git a/cpukit/headers.am b/cpukit/headers.am
>> >> > index 0bba9674cd..211e17ddf8 100644
>> >> > --- a/cpukit/headers.am
>> >> > +++ b/cpukit/headers.am
>> >> > @@ -352,6 +352,7 @@ include_rtems_score_HEADERS +=
>> include/rtems/score/isr.h
>> >> >  include_rtems_score_HEADERS += include/rtems/score/isrlevel.h
>> >> >  include_rtems_score_HEADERS += include/rtems/score/isrlock.h
>> >> >  include_rtems_score_HEADERS += include/rtems/score/memory.h
>> >> > +include_rtems_score_HEADERS +=
>> >> >  include_rtems_score_HEADERS += include/rtems/score/mpci.h
>> >> >  include_rtems_score_HEADERS += include/rtems/score/mpciimpl.h
>> >> >  include_rtems_score_HEADERS += include/rtems/score/mppkt.h
>> >> > @@ -405,6 +406,7 @@ include_rtems_score_HEADERS +=
>> include/rtems/score/smplockstats.h
>> >> >  include_rtems_score_HEADERS += include/rtems/score/smplockticket.h
>> >> >  include_rtems_score_HEADERS += include/rtems/score/stack.h
>> >> >  include_rtems_score_HEADERS += include/rtems/score/stackimpl.h
>> >> > +include_rtems_score_HEADERS += include/rtems/score/stackprotection.h
>> >> >  include_rtems_score_HEADERS += include/rtems/score/states.h
>> >> >  include_rtems_score_HEADERS += include/rtems/score/statesimpl.h
>> >> >  include_rtems_score_HEADERS += include/rtems/score/status.h
>> >> > diff --git a/cpukit/include/rtems/score/memoryprotection.h
>> b/cpukit/include/rtems/score/memoryprotection.h
>> >> > index 0000000000..245e50313c
>> >> > --- /dev/null
>> >> > +++ b/cpukit/include/rtems/score/memoryprotection.h
>> >> > @@ -0,0 +1,91 @@
>> >> > +/* SPDX-License-Identifier: BSD-2-Clause */
>> >> > + * @file
>> >> > + * @ingroup RTEMSScoreMemoryprotection
>> >> > + * @brief This file provodes APIs for high-level memory protection
>> >> typo
>> >> remove extra blank line
>> >> > + * Copyright (C) 2020 Utkarsh Rai
>> >> > + * Redistribution and use in source and binary forms, with or
>> without
>> >> > + * modification, are permitted provided that the following
>> conditions
>> >> > + * are met:
>> >> > + * 1. Redistributions of source code must retain the above copyright
>> >> > + *    notice, this list of conditions and the following disclaimer.
>> >> > + * 2. Redistributions in binary form must reproduce the above
>> copyright
>> in the
>> >> > + *    documentation and/or other materials provided with the
>> distribution.
>> >> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>> CONTRIBUTORS "AS IS"
>> >> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
>> LIMITED TO, THE
>> >> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
>> PARTICULAR PURPOSE
>> >> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
>> CONTRIBUTORS BE
>> >> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY,
>> OR
>> >> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
>> PROCUREMENT OF
>> >> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>> BUSINESS
>> >> > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>> WHETHER IN
>> >> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>> OTHERWISE)
>> >> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
>> ADVISED OF THE
>> >> > + * POSSIBILITY OF SUCH DAMAGE.
>> >> > +#ifndef _RTEMS_SCORE_MEMORYPROTECTION_H
>> >> > +#define _RTEMS_SCORE_MEMORYPROTECTION_H
>> >> > +#if defined ( ASM )
>> >> > +  #include <rtems/asm.h>
>> >> > +#else
>> >> > +  #include <rtems/score/basedefs.h>
>> >> > +#endif
>> >> > +#ifdef __cplusplus
>> >> > +extern "C" {
>> >> > +#endif
>> >> > +#if !defined ( ASM )
>> >> > +#define RTEMS_NO_ACCESS 0x00
>> >> > +#define RTEMS_READ_ONLY 0x01
>> >> > +#define RTEMS_WRITE_ONLY 0x02
>> >> > +#define RTEMS_READ_WRITE ( RTEMS_READ_ONLY | RTEMS_WRITE_ONLY )
>> >> > +#define RTEMS_MEMORY_CACHED 0x04
>> >> > + * @brief Define the memory access permission for the specified
>> memory region
>> >> > + * @param begin_addr Beginning of the memory region
>> >> > + * @param size Size of the memory region
>> >> > + * @param flag Memory access flag
>> >> delete extra blank
>> >> > +  uintptr_t begin_addr,
>> >> > +  size_t size,
>> >> > +  uint32_t flag
>> >> > + * @brief Unset the memory access permission for the specified
>> memory region
>> >> > + * This operation implicitly sets the specified memory region with
>> 'NO_ACCESS'
>> >> > + * flag.
>> >> > + * @param begin_addr Begining of the memory region
>> >> typo: Beginning
>> >> > +  size_t size
>> >> > +#endif  /* !defined ( ASM ) */
>> >> does this get included from ASM? if so, it is not actually doing
>> anything...
>> >> > +#ifdef __cplusplus
>> >> > +#endif
>> >> > +#endif
>> >> > diff --git a/cpukit/include/rtems/score/stack.h
>> b/cpukit/include/rtems/score/stack.h
>> >> > index df1df74867..d561bf61c1 100644
>> >> > --- a/cpukit/include/rtems/score/stack.h
>> >> > +++ b/cpukit/include/rtems/score/stack.h
>> >> > @@ -47,6 +47,47 @@ extern "C" {
>> >> >  #define STACK_MINIMUM_SIZE  CPU_STACK_MINIMUM_SIZE
>> >> > + * The number of stacks that can be shared with a thread.
>> >> > +#define SHARED_STACK_NUMBER 8
>> >> Magic number 8?
>> > Will it be ok to have the shared stack number equal to
>> CONFIGURE_MAXIMUM_POSIX_THREADS -1?
>> If it is a limit of the hardware, then it needs to come through from
>> the CPU macros (score/cpu) or as a BSP Option.
> No, actually it is just a very broad assumption that if we have n threads,
> each thread can have access to remaining n-1 thread stacks at max.
>> >> > +#if defined ( RTEMS_THREAD_STACK_PROTECTION )
>> >> > + * The following defines the attributes of a protected stack
>> >> > +typedef struct
>> >> > +  /** The pointer to the page table base */
>> >> > +  uintptr_t      page_table_base;
>> >> PT is an attribute of a thread, not a stack. This is a little bit
>> misplaced.
>> >> > +  /**Memory flag for the alllocated/shared stack */
>> >> typo: allocated
>> >> > +} Stack_Protection_attr;
>> >> > + * The following defines the control block  of a shared stack. Each
>> stack can have
>> >> > + * different sharing attributes.
>> >> > +typedef struct
>> >> > +  /** This is the attribute of a shared stack*/
>> >> > +  Stack_Protection_attr    Base;
>> >> > +  /** This is the stack address of the sharing thread*/
>> >> > +  void* shared_stack_area;
>> >> > +  /** Stack size of the sharing thread*/
>> >> > +  size_t shared_stack_size;
>> >> > +  /** This is the stack address of the target stack. Maybe this
>> area is not
>> >> > +   * needed but this helps in selecting the target thread during
>> stack sharing.
>> >> > +  void* target_stack_area;
>> >> > + /** Error checking for valid target stack address. This is also
>> used to
>> >> > +  * distinguish between a normal mmap operation and a stack sharing
>> operation.
>> >> > +  bool stack_shared;
>> >> > +} Stack_Shared_attr;
>> >> > +#endif
>> >> I thought you were planning to integrate this better with the existing
>> >> Stack_Control stuff?
>> >> Do we really need a separate structure to track 'shared' stacks (as
>> >> opposed to 'non-shared' ones?)
>> > This is because of the design of the stack sharing mechanism. I have
>> elaborated more on this below.
>> >> >   *  The following defines the control block used to manage each
>> stack.
>> >> > @@ -55,6 +96,14 @@ typedef struct {
>> >> >    size_t      size;
>> >> >    /** This is the low memory address of stack. */
>> >> >    void       *area;
>> >> > +   /** The attribute of a protected stack */
>> >> This 'Base' stuff should only be used when the structure sits at the
>> >> base, to implement some kind of inheritance/polymorphism.
>> >> > +  Stack_Shared_attr *shared_stacks[SHARED_STACK_NUMBER];
>> >> I'm not sure about this design choice.
>> > Yes, I now realize that we cannot do it this way. But we do have to
>> track the shared stacks as discussed here,  and for setting memory
>> attributes of any shared stack we need three properties, base address, size
>> of the stack, and the memory flag for sharing which can be different from
>> its 'intrinsic' memory flag. The stack control structure already has the
>> size and the base address but a single thread stack can be shared with
>> multiple threads with different memory flags. This is an implementation
>> challenge I have to look out for.
>> I see. Maybe it can be a pointer to the Stack_Control, plus the flags?
>> >> > +  uint32_t shared_stacks_count;
>> >> > +#endif
>> >> >  }   Stack_Control;
>> >> > diff --git a/cpukit/include/rtems/score/stackprotection.h
>> b/cpukit/include/rtems/score/stackprotection.h
>> >> > index 0000000000..58ab5f8673
>> >> > --- /dev/null
>> >> > +++ b/cpukit/include/rtems/score/stackprotection.h
>> >> > @@ -0,0 +1,80 @@
>> >> > + * @file
>> >> > + * @ingroup RTEMSScoreStackprotection
>> >> > + * @brief Stackprotection API
>> >> > + * This include file provides the API for the management of
>> protected thread-
>> >> > + * stacks
>> >> > + *  COPYRIGHT (c) 2020 Utkarsh Rai.
>> without
>> conditions
>> >> > + * are met:
>> copyright
>> >> > + * notice, this list of conditions and the following disclaimer in
>> the
>> distribution.
>> LIMITED TO, THE
>> PARTICULAR PURPOSE
>> CONTRIBUTORS BE
>> OR
>> PROCUREMENT OF
>> BUSINESS
>> WHETHER IN
>> OTHERWISE)
>> ADVISED OF THE
>> >> > +#ifndef _RTEMS_SCORE_STACKPROTECTION_H
>> >> > +#define _RTEMS_SCORE_STACKPROTECTION_H
>> >> > +#include <rtems/score/basedefs.h>
>> >> > +#include <rtems/score/stack.h>
>> >> > +#ifdef __cplusplus
>> >> > +extern "C" {
>> >> > +#endif
>> >> > + * @brief Share the stack address of a given thread with the target
>> thread.
>> >> > + * @param target_stack Stack address of the target thread
>> >> > + * @param sharing_stack Stack address of the sharin thread
>> >> > +int _Stackprotection_Share_stack(
>> >> _Stack_protection_
>> >> > +  void *target_stack,
>> >> > +  void *sharing_stack,
>> >> > +  size_t size,
>> >> > +  uint32_t memory_flag
>> >> > + * @brief Swap the restored shared stacks  in the page table during
>> context
>> >> > + * restoration
>> >> > + * We set the entries of the restored stack and mark all the
>> remainig stacks as
>> >> typo: remaining
>> >> > + * 'NO-ACCESS'.
>> >> > + * @param Control block of the restored stack
>> >> > +void _Stackprotection_Context_restore(
>> >> > +  Stack_Control *heir_stack
>> >> > +#ifdef __cplusplus
>> >> > +#endif
>> >> > +#endif
>> >> > diff --git a/cpukit/include/rtems/score/thread.h
>> b/cpukit/include/rtems/score/thread.h
>> >> > index ee0aee5b79..0ad22feac4 100644
>> >> > --- a/cpukit/include/rtems/score/thread.h
>> >> > +++ b/cpukit/include/rtems/score/thread.h
>> >> > @@ -34,6 +34,7 @@
>> >> >  #include <rtems/score/priority.h>
>> >> >  #include <rtems/score/schedulernode.h>
>> >> > +#include <rtems/score/stackprotection.h>
>> >> >  #include <rtems/score/states.h>
>> >> >  #include <rtems/score/threadq.h>
>> >> >  #include <rtems/score/timestamp.h>
>> >> > diff --git a/cpukit/posix/src/mmap.c b/cpukit/posix/src/mmap.c
>> >> > index 176c6e4fe8..6587819c0f 100644
>> >> > --- a/cpukit/posix/src/mmap.c
>> >> > +++ b/cpukit/posix/src/mmap.c
>> >> > @@ -28,7 +28,27 @@
>> >> >  #include <rtems/posix/mmanimpl.h>
>> >> >  #include <rtems/posix/shmimpl.h>
>> >> > +static uint32_t mmap_flag_translate(int prot)
>> >> > +  int prot_read;
>> >> > +  int prot_write;
>> >> > +  int memory_flag;
>> >> > +  prot_read = (prot_read & PROT_READ) == PROT_READ;
>> >> > +  prot_write = (prot_write & PROT_WRITE) == PROT_WRITE;
>> >> > +  if(prot_read){
>> >> whitespace
>> >> > +    memory_flag |= ( RTEMS_READ_ONLY| RTEMS_MEMORY_CACHED );
>> >> > +  if(prot_write) {
>> >> ws
>> >> > +    memory_flag |= ( RTEMS_READ_WRITE | RTEMS_MEMORY_CACHED );
>> >> > +  return memory_flag;
>> >> >   * mmap chain of mappings.
>> >> > @@ -50,6 +70,9 @@ void *mmap(
>> >> >    bool            map_private;
>> >> >    bool            is_shared_shm;
>> >> >    int             err;
>> >> > +  uint32_t memory_flags;
>> >> > +  uintptr_t shared_stack_address;
>> >> > +  int status;
>> >> >    map_fixed = (flags & MAP_FIXED) == MAP_FIXED;
>> >> >    map_anonymous = (flags & MAP_ANON) == MAP_ANON;
>> >> > @@ -67,7 +90,10 @@ void *mmap(
>> >> >     * We can provide read, write and execute because the memory in
>> RTEMS does
>> >> > -   * not normally have protections but we cannot hide access to
>> memory.
>> >> > +   * not normally have protections but we cannot hide access to
>> memory. For
>> >> > +   * thread-stack protection we can provide no-access option, but
>> stacks are
>> >> > +   * implicitly isolated and it makes no sense to specify no-access
>> option for
>> >> > +   * already isolated stacks.
>> >> >    if ( prot == PROT_NONE ) {
>> >> >      errno = ENOTSUP;
>> >> > @@ -292,11 +318,18 @@ void *mmap(
>> >> >        free( mapping );
>> >> >        return MAP_FAILED;
>> >> > +    * We share thread-stacks only when we have a shared memory
>> object and map
>> >> > +    * shared flag set
>> >> > +    memory_flags = mmap_flag_translate( prot );
>> >> > +    status = _Stackprotection_Share_stack( mapping->addr, addr,
>> len,memory_flags );
>> >> What if someone passes an addr that is not in stack?
>> >> Fundamentally what is the difference between sharing stacks and
>> >> sharing some arbitrary 'pages'?
>> >> > +  if(status == RTEMS_INVALID_ADDRESS ) {
>> >> ws
>> >> what leads to this status?
>> > The _Stackprotection_Share_stack() takes the address of the target
>> thread-stack and sharing thread-stack. Now we check all the thread stack
>> addresses against the passed
>> > thread stack address. If we match against a valid address it returns
>> RTEMS_SUCCESSFUL otherwise we return RTEMS_INVALID_ADDRESS. Although now
>> when I relook at
>> > the implementation there is a glaring mistake, simply adding the
>> pointer of the Shared_stack structure that has been initialized from a
>> thread stack that we may not be able
>> > to access from a certain thread. I will have to change the
>> implementation a bit, again :(.
>> I'm confused why it is only tracking the mapping for an invalid
>> address. that seems backward. is it to avoid breaking mmap() on
>> non-stack objects? if so, it should be commented.
> Yes, it is for preventing that. We also have the condition that we can
> only share stacks when the sharing stack is passed as a file descriptor for
> a
> shared memory object.
>> >> > +    rtems_chain_append_unprotected( &mmap_mappings, &mapping->node
>> >> > -  rtems_chain_append_unprotected( &mmap_mappings, &mapping->node );
>> >> >    mmap_mappings_lock_release( );
>> >> >    return mapping->addr;
>> >> > diff --git a/cpukit/posix/src/shmwkspace.c
>> b/cpukit/posix/src/shmwkspace.c
>> >> > index 4fa4ec4771..e4e3c594d9 100644
>> >> > --- a/cpukit/posix/src/shmwkspace.c
>> >> > +++ b/cpukit/posix/src/shmwkspace.c
>> >> > @@ -16,6 +16,7 @@
>> >> >  #include <errno.h>
>> >> >  #include <string.h>
>> >> > +#include <rtems/posix/pthread.h>
>> >> >  #include <rtems/score/wkspace.h>
>> >> > @@ -24,6 +25,49 @@ int _POSIX_Shm_Object_create_from_workspace(
>> >> >    size_t size
>> >> > +#if defined(RTEMS_THREAD_STACK_PROTECTION)
>> >> > +  POSIX_Shm_Control *shm;
>> >> > +  Objects_Id id;
>> >> > +  Objects_Name_or_id_lookup_errors err;
>> >> > +  Thread_Control *Control;
>> >> > +  ISR_lock_Context lock_context;
>> >> > +  char *name;
>> >> > +  shm = RTEMS_CONTAINER_OF(shm_obj, POSIX_Shm_Control, shm_object);
>> >> > +  name = shm->Object.name.name_p;
>> >> > +  /** We assign fixed pattern of naming for thread-stacks, and
>> treat them
>> >> > +   *  accordingly.
>> >> > +  if( strncmp( name, "/taskfs/", 8) == 0 ) {
>> >> > +     * Obtain the object id of the thread and then get the thread
>> control block
>> >> > +     * corresponding to that id.
>> >> > +    err = _Objects_Name_to_id_u32(
>> >> > +            &_POSIX_Threads_Information.Objects,
>> >> > +           _Objects_Build_name( name[8], name[9], name[10],
>> name[11]),
>> >> > +            RTEMS_LOCAL,
>> >> > +            &id
>> >> > +    Control = _Thread_Get( id, &lock_context );
>> >> > +     if( Control != NULL ) {
>> >> ws
>> >> > +       shm_obj->handle = Control->Start.Initial_stack.area;
>> >> > +       if( size != Control->Start.Initial_stack.size) {
>> >> ws
>> >> > +         return ENOMEM;
>> >> I'm not sure this is the right place for this logic. It's not really
>> >> creating from the workplace in case of the tasksfs name match? should
>> >> this be handled before calling this function?
>> >> > +     } else {
>> >> > +       return ENOMEM;
>> >> > +  } else {
>> >> > +    shm_obj->handle = _Workspace_Allocate( size );
>> >> > +    if ( shm_obj->handle == NULL ) {
>> >> > +      return ENOMEM;
>> >> > +  shm_obj->size = size;
>> >> > +  return 0;
>> >> > +#else
>> >> >      return ENOMEM;
>> >> > @@ -32,6 +76,7 @@ int _POSIX_Shm_Object_create_from_workspace(
>> >> >    memset( shm_obj->handle, 0, size );
>> >> >    return 0;
>> >> > +#endif
>> >> >  int _POSIX_Shm_Object_delete_from_workspace( POSIX_Shm_Object
>> *shm_obj )
>> >> > @@ -97,4 +142,3 @@ void * _POSIX_Shm_Object_mmap_from_workspace(
>> >> >    return (char*)shm_obj->handle + off;
>> >> stray change
>> >> > diff --git a/cpukit/score/cpu/arm/cpu_asm.S
>> b/cpukit/score/cpu/arm/cpu_asm.S
>> >> > index 66f8ba6032..8e9a4a9f88 100644
>> >> > --- a/cpukit/score/cpu/arm/cpu_asm.S
>> >> > +++ b/cpukit/score/cpu/arm/cpu_asm.S
>> >> > @@ -66,6 +66,73 @@ DEFINE_FUNCTION_ARM(_CPU_Context_switch)
>> >> >         str     r3, [r0, #ARM_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE]
>> >> > + * We make a function call to set the memory attributes of the heir
>> >> > + * stack and unset that of the executing stack (including shared
>> stacks ).
>> >> > + * This will be a simple asm code when done by switching the
>> translation
>> >> > + * table base.
>> >> > +/* Save the registers modified during function call */
>> >> > +       mov r8, r0
>> >> > +       mov r9, r1
>> >> > +       mov r10, r2
>> >> > +/* Load the parameters for function call */
>> >> > +       mov r0, r1
>> >> > +       sub r0, r0, #76
>> >> > +       ldr r1, [r0]
>> >> > +       ldr r0, [r0, #4]
>> >> > +       mov r2, #3
>> >> > +       bl _Memory_protection_Set_entries
>> >> > +/* Restore the saved registers  */
>> >> > +       mov r0, r8
>> >> > +       mov r1, r9
>> >> > +       mov r2, r10
>> >> > +/* We load the stack-pointer of the heir thread pre-maturely, this
>> is
>> >> > + * done as oherwise the *_unset_entries call will execute from the
>> stack of the
>> >> > + * executing thread causing fatal exceptions.
>> >> > +       ldr sp, [r1, #32]
>> >> > +/* Load the parameters of the function call */
>> >> > +       mov r1, r0
>> >> > +       sub r0, r0, #76
>> >> > +       ldr r1, [r0]
>> >> > +       ldr r0, [r0, #4]
>> >> > +       bl  _Memory_protection_Unset_entries
>> >> > + * Restore the saved registers
>> >> > +       mov r0, r8
>> >> > +       mov r1, r9
>> >> > +       mov r2, r10
>> >> > +/* Set the memory entries of the shared stack */
>> >> > +    sub        r0, r0, #76
>> >> > +       add r6, r0, #16
>> >> > +.L_shared_stack_restore:
>> >> > +       ldr r1, [r6, #8]
>> >> > +       ldr r0, [r6, #12]
>> >> > +       add  r6, #4
>> >> > +       add  r11, #1
>> >> > +/* We compare with a hard-coded value, this is the number of shared
>> stacks
>> >> > + * (SHARED_STACK_NUMBER)
>> >> > +       cmp r11, #8
>> >> > +       bne .L_shared_stack_restore
>> >> > +       mov r0, r8
>> >> > +       mov r1, r9
>> >> > +       mov r2, r10
>> >> > +#endif
>> >> >  #ifdef RTEMS_SMP
>> >> >          * The executing thread no longer executes on this
>> processor.  Switch
>> >> > @@ -95,6 +162,7 @@ DEFINE_FUNCTION_ARM(_CPU_Context_switch)
>> >> >  /* Start restoring context */
>> >> >  .L_restore:
>> >> >  #if !defined(RTEMS_SMP) &&
>> defined(ARM_MULTILIB_HAS_LOAD_STORE_EXCLUSIVE)
>> >> >         clrex
>> >> >  #endif
>> >> > @@ -133,7 +201,33 @@ DEFINE_FUNCTION_ARM(_CPU_Context_switch)
>> >> >  DEFINE_FUNCTION_ARM(_CPU_Context_restore)
>> >> >          mov     r1, r0
>> >> >         GET_SELF_CPU_CONTROL    r2
>> >> > +       /* Save the registers modified during function call */
>> >> > +       mov r8, r0
>> >> > +       mov r9, r1
>> >> > +       mov r10, r2
>> >> > +       /* Load the parameters for function call */
>> >> > +       mov r1, r0
>> >> > +       sub r0, r0, #76
>> >> > +       ldr r1, [r0]
>> >> > +       ldr r0, [r0, #4]
>> >> > +       mov r2, #3
>> >> > +       /* Restore the saved registers   */
>> >> > +       mov r0, r8
>> >> > +       mov r1, r9
>> >> > +       mov r2, r10
>> >> > +       /* Set memory entries of the shared thread stacks */
>> >> > +#endif
>> >> >          b       .L_restore
>> >> >  #ifdef RTEMS_SMP
>> >> > diff --git a/cpukit/score/src/stackprotection.c
>> b/cpukit/score/src/stackprotection.c
>> >> > index 0000000000..8427046aa0
>> >> > --- /dev/null
>> >> > +++ b/cpukit/score/src/stackprotection.c
>> >> > @@ -0,0 +1,103 @@
>> >> > + * @file
>> without
>> conditions
>> >> > + * are met:
>> copyright
>> in the
>> distribution.
>> LIMITED TO, THE
>> PARTICULAR PURPOSE
>> CONTRIBUTORS BE
>> OR
>> PROCUREMENT OF
>> BUSINESS
>> WHETHER IN
>> OTHERWISE)
>> ADVISED OF THE
>> >> > +#ifdef HAVE_CONFIG_H
>> >> > +#include "config.h"
>> >> > +#endif
>> >> > +#include <rtems/score/threadimpl.h>
>> >> > +Stack_Control *heir_stack
>> >> > +  void* stack_address;
>> >> > +  size_t stack_size;
>> >> > +  uint32_t index;
>> >> > +  for(index = 0;index < heir_stack->shared_stacks_count; index++) {
>> >> > +    stack_address =
>> heir_stack->shared_stacks[index]->shared_stack_area;
>> >> > +    stack_size =
>> heir_stack->shared_stacks[index]->shared_stack_size;
>> >> > +    _Memory_protection_Set_entries( stack_address, stack_size,
>> memory_flags );
>> >> > +static bool get_target_thread( Thread_Control *Control, void *arg)
>> >> > +  Stack_Shared_attr *shared_stack;
>> >> > +  uint32_t count;
>> >> > +  shared_stack = arg;
>> >> > +   * Check for the target thread by comparing the stack address.
>> Add the shared stack
>> >> > +   * attribute structure to the array tracking all the shared
>> stacks.
>> >> > +  if( Control->Start.Initial_stack.area ==
>> shared_stack->target_stack_area) {
>> >> > +     count =  Control->Start.Initial_stack.shared_stacks_count + 1;
>> >> > +     if(count >= SHARED_STACK_NUMBER) {
>> >> > +       return false;
>> >> > +     Control->Start.Initial_stack.shared_stacks_count = count;
>> >> > +     Control->Start.Initial_stack.shared_stacks[count] =
>> shared_stack;
>> >> > +     shared_stack->stack_shared = true;
>> >> > +     return true;
>> >> > +  void* target_stack,
>> >> > +  void* sharing_stack,
>> >> > +  size_t size,
>> >> > + Thread_Control *target_thread;
>> >> > + Stack_Shared_attr shared_stack;
>> >> > + shared_stack.Base.access_flags= memory_flag;
>> >> > + shared_stack.shared_stack_area = sharing_stack;
>> >> > + shared_stack.target_stack_area = target_stack;
>> >> > + shared_stack.shared_stack_size = size;
>> >> > + _Thread_Iterate( get_target_thread, &shared_stack );
>> >> > + if( shared_stack.stack_shared == true ) {
>> >> > +   return 0;
>> >> > + } else {
>> >> > +   return -1;
>> >> > diff --git a/cpukit/score/src/threadhandler.c
>> b/cpukit/score/src/threadhandler.c
>> >> > index 6742b0b391..c18e33f688 100644
>> >> > --- a/cpukit/score/src/threadhandler.c
>> >> > +++ b/cpukit/score/src/threadhandler.c
>> >> > @@ -22,6 +22,7 @@
>> >> >  #include <rtems/score/assert.h>
>> >> >  #include <rtems/score/interr.h>
>> >> >  #include <rtems/score/isrlevel.h>
>> >> >  #include <rtems/score/userextimpl.h>
>> >> > @@ -94,6 +95,11 @@ void _Thread_Handler( void )
>> >> >    level = executing->Start.isr_level;
>> >> >    _ISR_Set_level( level );
>> >> > +   * Switch-out the the shared thread-stacks
>> >> delete the
>> >> > +  _Stackprotection_Context_restore( &executing->Start.Initial_stack
>> >> >     * Initialize the floating point context because we do not come
>> >> >     * through _Thread_Dispatch on our first invocation. So the normal
>> >> > diff --git a/cpukit/score/src/threadinitialize.c
>> b/cpukit/score/src/threadinitialize.c
>> >> > index 691f56388e..96db4193bc 100644
>> >> > --- a/cpukit/score/src/threadinitialize.c
>> >> > +++ b/cpukit/score/src/threadinitialize.c
>> >> > @@ -114,6 +114,15 @@ bool _Thread_Initialize(
>> >> >       stack_size
>> >> > +   * Initialize the protected stack attributes. Initially we
>> initialize the
>> >> > +   * thread with no access attributes, on context switch/restore
>> action the
>> >> > +   * thread stacks are assigned READ/WRITE attribute.
>> >> > +   the_thread->Start.Initial_stack.Base.access_flags =
>> RTEMS_NO_ACCESS | RTEMS_MEMORY_CACHED;
>> >> > +#endif
>> >> >     *  Get thread queue heads
>> >> > diff --git
>> a/spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml
>> b/spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml
>> >> > index 2721152b93..f7d2187c66 100644
>> >> > --- a/spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml
>> >> > +++ b/spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml
>> >> > @@ -57,6 +57,7 @@ links:
>> >> >  source:
>> >> >  - bsps/arm/realview-pbx-a9/console/console-config.c
>> >> >  - bsps/arm/realview-pbx-a9/console/console-polled.c
>> >> > +- bsps/arm/realview-pbx-a9/mmu/bsp-set-mmu-attr.c
>> >> >  - bsps/arm/realview-pbx-a9/start/bspreset.c
>> >> >  - bsps/arm/realview-pbx-a9/start/bspstart.c
>> >> >  - bsps/arm/realview-pbx-a9/start/bspstarthooks.c
>> >> > diff --git a/spec/build/cpukit/cpuopts.yml
>> b/spec/build/cpukit/cpuopts.yml
>> >> > index 1902e543ca..f7641a5e50 100644
>> >> > --- a/spec/build/cpukit/cpuopts.yml
>> >> > +++ b/spec/build/cpukit/cpuopts.yml
>> >> > @@ -63,6 +63,8 @@ links:
>> >> >    uid: optszoff
>> >> >  - role: build-dependency
>> >> >    uid: optsztime
>> >> > +- role: build-dependency
>> >> > +  uid: optthreadstackprotection
>> >> >    uid: optversion
>> >> >  target: cpukit/include/rtems/score/cpuopts.h
>> >> > diff --git a/spec/build/cpukit/librtemscpu.yml
>> b/spec/build/cpukit/librtemscpu.yml
>> >> > index 63a0b7dca5..9855401665 100644
>> >> > --- a/spec/build/cpukit/librtemscpu.yml
>> >> > +++ b/spec/build/cpukit/librtemscpu.yml
>> >> > @@ -353,6 +353,7 @@ install:
>> >> >    - cpukit/include/rtems/score/isrlevel.h
>> >> >    - cpukit/include/rtems/score/isrlock.h
>> >> >    - cpukit/include/rtems/score/memory.h
>> >> > +  - cpukit/include/rtems/score/memoryprotection.h
>> >> >    - cpukit/include/rtems/score/mpci.h
>> >> >    - cpukit/include/rtems/score/mpciimpl.h
>> >> >    - cpukit/include/rtems/score/mppkt.h
>> >> > @@ -405,6 +406,7 @@ install:
>> >> >    - cpukit/include/rtems/score/smplockstats.h
>> >> >    - cpukit/include/rtems/score/smplockticket.h
>> >> >    - cpukit/include/rtems/score/stack.h
>> >> > +  - cpukit/include/rtems/score/stackprotection.h
>> >> >    - cpukit/include/rtems/score/stackimpl.h
>> >> >    - cpukit/include/rtems/score/states.h
>> >> >    - cpukit/include/rtems/score/statesimpl.h
>> >> > @@ -1509,6 +1511,7 @@ source:
>> >> >  - cpukit/score/src/semaphore.c
>> >> >  - cpukit/score/src/smpbarrierwait.c
>> >> >  - cpukit/score/src/stackallocator.c
>> >> > +- cpukit/score/src/stackprotection.c
>> >> >  - cpukit/score/src/threadallocateunlimited.c
>> >> >  - cpukit/score/src/thread.c
>> >> >  - cpukit/score/src/threadchangepriority.c
>> >> > diff --git a/spec/build/cpukit/optthreadstackprotection.yml
>> b/spec/build/cpukit/optthreadstackprotection.yml
>> >> > index 0000000000..4722d9f0cb
>> >> > --- /dev/null
>> >> > +++ b/spec/build/cpukit/optthreadstackprotection.yml
>> >> > @@ -0,0 +1,16 @@
>> >> > +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>> >> > +actions:
>> >> > +- get-boolean: null
>> >> > +- env-enable: null
>> >> > +- define-condition: null
>> >> > +build-type: option
>> >> > +copyrights:
>> >> > +- Copyright (C) 2020 Utkarsh Rai (utkarsh.rai60 at gmail.com)
>> >> > +default: false
>> >> > +default-by-variant: []
>> >> > +description: |
>> >> > +  Enable the thread stack protection support
>> >> > +enabled-by: true
>> >> > +links: []
>> >> > +name: RTEMS_THREAD_STACK_PROTECTION
>> >> > +type: build
>> >> > diff --git a/spec/build/testsuites/samples/grp.yml
>> b/spec/build/testsuites/samples/grp.yml
>> >> > index c7591dc551..f0367b0f9b 100644
>> >> > --- a/spec/build/testsuites/samples/grp.yml
>> >> > +++ b/spec/build/testsuites/samples/grp.yml
>> >> > @@ -40,6 +40,10 @@ links:
>> >> >    uid: pppd
>> >> >    uid: ticker
>> >> > +  uid: threadstackprotection
>> >> > +  uid: threadstacksharing
>> >> >    uid: unlimited
>> >> >  type: build
>> >> > diff --git a/spec/build/testsuites/samples/threadstackprotection.yml
>> b/spec/build/testsuites/samples/threadstackprotection.yml
>> >> > index 0000000000..a33c53d392
>> >> > --- /dev/null
>> >> > +++ b/spec/build/testsuites/samples/threadstackprotection.yml
>> >> > @@ -0,0 +1,19 @@
>> >> > +build-type: test-program
>> >> > +cflags: []
>> >> > +copyrights:
>> >> > +cppflags: []
>> >> > +cxxflags: []
>> >> > +enabled-by: true
>> >> > +features: c cprogram
>> >> > +includes: []
>> >> > +ldflags: []
>> >> > +links: []
>> >> > +source:
>> >> > +- testsuites/samples/thread_stack_protection/init.c
>> >> > +stlib: []
>> >> > +target: testsuites/samples/thread_stack_protection.exe
>> >> > +type: build
>> >> > +use-after: []
>> >> > +use-before: []
>> >> > diff --git a/spec/build/testsuites/samples/threadstacksharing.yml
>> b/spec/build/testsuites/samples/threadstacksharing.yml
>> >> > index 0000000000..bbe99af189
>> >> > --- /dev/null
>> >> > +++ b/spec/build/testsuites/samples/threadstacksharing.yml
>> >> > @@ -0,0 +1,19 @@
>> >> > +cflags: []
>> >> > +copyrights:
>> >> > +cppflags: []
>> >> > +cxxflags: []
>> >> > +enabled-by: true
>> >> > +includes: []
>> >> > +ldflags: []
>> >> > +links: []
>> >> > +source:
>> >> > +- testsuites/samples/thread_stack_sharing/init.c
>> >> > +stlib: []
>> >> > +target: testsuites/samples/thread_stack_sharing.exe
>> >> > +type: build
>> >> > +use-after: []
>> >> > +use-before: []
>> >> > diff --git a/testsuites/samples/Makefile.am
>> b/testsuites/samples/Makefile.am
>> >> > index 1944d90ccc..4d76bcb167 100644
>> >> > --- a/testsuites/samples/Makefile.am
>> >> > +++ b/testsuites/samples/Makefile.am
>> >> > @@ -146,6 +146,22 @@ ticker_CPPFLAGS = $(AM_CPPFLAGS)
>> $(TEST_FLAGS_ticker) \
>> >> >         $(support_includes)
>> >> >  endif
>> >> > +if TEST_thread_stack_protection
>> >> > +samples += thread_stack_protection
>> >> > +sample_screens +=
>> >> > +sample_docs += thread_stack_protection/thread_stack_protection.doc
>> >> > +thread_stack_protection_SOURCES = thread_stack_protection/init.c
>> >> > +thread_stack_protection_CPPFLAGS = $(AM_CPPFLAGS)
>> $(TEST_FLAGS_thread_stack_protection) \
>> >> > +       $(support_includes)
>> >> > +endif
>> >> > +if TEST_thread_stack_sharing
>> >> > +samples += thread_stack_sharing
>> >> > +thread_stack_sharing_SOURCES = thread_stack_sharing/init.c
>> >> > +thread_stack_sharing_CPPFLAGS = $(AM_CPPFLAGS)
>> $(TEST_FLAGS_thread_stack_sharing) \
>> >> > +endif
>> >> >  if TEST_unlimited
>> >> >  samples += unlimited
>> >> >  sample_screens += unlimited/unlimited.scn
>> >> > diff --git a/testsuites/samples/configure.ac b/testsuites/samples/
>> configure.ac
>> >> > index 9721ea4f26..6460f8f2c9 100644
>> >> > --- a/testsuites/samples/configure.ac
>> >> > +++ b/testsuites/samples/configure.ac
>> >> > @@ -50,6 +50,8 @@ RTEMS_TEST_CHECK([nsecs])
>> >> >  RTEMS_TEST_CHECK([paranoia])
>> >> >  RTEMS_TEST_CHECK([pppd])
>> >> >  RTEMS_TEST_CHECK([ticker])
>> >> > +RTEMS_TEST_CHECK([thread_stack_protection])
>> >> > +RTEMS_TEST_CHECK([thread_stack_sharing])
>> >> >  RTEMS_TEST_CHECK([unlimited])
>> >> >  AC_CONFIG_FILES([Makefile])
>> >> > diff --git a/testsuites/samples/thread_stack_protection/init.c
>> b/testsuites/samples/thread_stack_protection/init.c
>> >> > index 0000000000..a9359b459d
>> >> > --- /dev/null
>> >> > +++ b/testsuites/samples/thread_stack_protection/init.c
>> >> > @@ -0,0 +1,112 @@
>> >> > +#endif
>> >> > +#include <rtems.h>
>> >> > +#include <tmacros.h>
>> >> > +#include <pthread.h>
>> >> > +#include <rtems/score/thread.h>
>> >> > +const char rtems_test_name[] = " THREAD STACK PROTECTION ";
>> >> > +static void fatal_extension(
>> >> > +  rtems_fatal_source source,
>> >> > +  bool is_internal,
>> >> > +  rtems_fatal_code error
>> >> > +  if (source == RTEMS_FATAL_SOURCE_EXCEPTION)
>> >> > +       printk("Internal Exception Occured \n");
>> >> > +  exit(0);
>> >> > +void* Test_routine( void* arg )
>> >> > +void *POSIX_Init( void *argument )
>> >> > +  void *stack_addr1;
>> >> > +  void *stack_addr2;
>> >> > +  size_t stack_size1;
>> >> > +  size_t stack_size2;
>> >> > +  pthread_t id1;
>> >> > +  pthread_t id2;
>> >> > +  pthread_attr_t attr1;
>> >> > +  pthread_attr_t attr2;
>> >> > +  Thread_Control Control;
>> >> > +  TEST_BEGIN();
>> >> > +  *  We set the stack size as 8Kb.
>> >> > +  stack_size1 = 8192;
>> >> > +  stack_size2 = 8192;
>> >> > +  printf("%d %d \n",sizeof(Control.Post_switch_actions),
>> sizeof(Control.Start.tls_area));
>> >> > +   * We allocate page-aligned memory of the stack  from the
>> application.
>> >> > +  posix_memalign(&stack_addr1, sysconf( _SC_PAGESIZE ), stack_size1
>> >> > +  posix_memalign(&stack_addr2, sysconf( _SC_PAGESIZE ), stack_size2
>> >> > +  pthread_attr_init( &attr1 );
>> >> > +  pthread_attr_init( &attr2 );
>> >> > +  * We set the stack size and address of the thread from the
>> application itself
>> >> > +  pthread_attr_setstack( &attr1, stack_addr1, stack_size1 );
>> >> > +  pthread_attr_setstack( &attr2, stack_addr2, stack_size2 );
>> >> > +  pthread_create( &id1, &attr1, Test_routine, NULL );
>> >> > +  pthread_create( &id2, &attr2, Test_routine, NULL );
>> >> > +  * We set the memory attributes of the stack from the application.
>> >> > +  _Memory_protection_Set_entries( stack_addr1, stack_size1,
>> RTEMS_NO_ACCESS | RTEMS_MEMORY_CACHED );
>> >> > +  _Memory_protection_Set_entries( stack_addr2, stack_size2,
>> >> > +  pthread_join( id1, NULL );
>> >> > +   * Write to the stack address of thread1 after it has been
>> switched out.
>> >> > +  printf("Writing to the stack of thread1 \n");
>> >> > +  memset(stack_addr1, 0, stack_size1);
>> >> > +  pthread_join( id2, NULL );
>> >> > +   * Write to the stack address of thread2 after it has been
>> switched out.
>> >> > +  TEST_END();
>> >> > +  rtems_test_exit( 0 );
>> >> > +/* configuration information */
>> >> > +#define CONFIGURE_INIT
>> >> > +#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
>> >> > +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>> >> > +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
>> >> > +#define CONFIGURE_MAXIMUM_POSIX_THREADS        2
>> >> > +#define CONFIGURE_POSIX_INIT_THREAD_TABLE
>> >> > +#define CONFIGURE_INITIAL_EXTENSIONS { .fatal = fatal_extension }
>> >> > +#define CONFIGURE_TASK_STACK_ALLOCATOR_INIT  bsp_stack_allocate_init
>> >> > +#define CONFIGURE_TASK_STACK_ALLOCATOR       bsp_stack_allocate
>> >> > +#define CONFIGURE_TASK_STACK_DEALLOCATOR     bsp_stack_free
>> >> > +#include <bsp/stackalloc.h>
>> >> > +#include <rtems/confdefs.h>
>> >> > diff --git
>> a/testsuites/samples/thread_stack_protection/thread_stack_protection.doc
>> b/testsuites/samples/thread_stack_protection/thread_stack_protection.doc
>> >> > index 0000000000..c5c9cdfa81
>> >> > --- /dev/null
>> >> > @@ -0,0 +1,2 @@
>> >> > +This test sample demonstrates the thread stack protection
>> functionality. We try
>> >> > +to write to the stack of a switched-out thread.
>> >> > diff --git
>> a/testsuites/samples/thread_stack_protection/thread_stack_protection.scn
>> b/testsuites/samples/thread_stack_protection/thread_stack_protection.scn
>> >> > index 0000000000..1d36d0dfaf
>> >> > --- /dev/null
>> >> > @@ -0,0 +1,20 @@
>> >> > +*** BEGIN OF TEST  THREAD STACK PROTECTION  ***
>> >> > +*** TEST VERSION:
>> 5.0.0.a3b39c9e567f3f1ef5ab01de78b113e61b11853b-modified
>> >> > +*** TEST STATE: EXPECTED_PASS
>> >> > +*** TEST BUILD: RTEMS_NETWORKING RTEMS_POSIX_API
>> >> > +*** TEST TOOLS: 7.5.0 20191114 (RTEMS 5, RSB 5 (3bd11fd4898b),
>> Newlib 7947581)
>> >> > +Creating thread1
>> >> > +Creating thread2
>> >> > +Joining thread1
>> >> > +Writing to the stack of thread1
>> >> > +Internal Exception Occured
>> >> > diff --git a/testsuites/samples/thread_stack_sharing/init.c
>> b/testsuites/samples/thread_stack_sharing/init.c
>> >> > index 0000000000..5bb7d01418
>> >> > --- /dev/null
>> >> > +++ b/testsuites/samples/thread_stack_sharing/init.c
>> >> > @@ -0,0 +1,136 @@
>> >> > +#endif
>> >> > +#include <rtems.h>
>> >> > +#include <sys/mman.h>
>> >> > +#include <sys/fcntl.h>
>> >> > +const char rtems_test_name[] = " THREAD STACK SHARING ";
>> >> > +  void* addr;
>> >> > +  pthread_t id1;
>> >> > +  pthread_t id2;
>> >> > +  int fd;
>> >> > +  char name[4] = "0x01";
>> >> > +  char thread_name[13] = "/taskfs/0x01";
>> >> > +  TEST_BEGIN();
>> application.
>> application itself
>> RTEMS_READ_ONLY | RTEMS_MEMORY_CACHED );
>> >> > +   * Add leading "/taskfs/" to denote thread-stack name.
>> >> > +  strlcat( thread_name, name, 4);
>> >> > +  * Set the name of the thread object same as that of the shared
>> memory object name
>> >> > +  rtems_object_set_name( id1, name);
>> >> > +   * Create a shared memory object of the  stack we want to share
>> with
>> >> > +   * appropraite permissions. We share the stack with read and
>> write permission
>> >> > +  fd = shm_open( thread_name, O_CREAT | O_RDWR, S_IRUSR | S_IWUSR );
>> >> > +   * Truncate the size of the file to the size of the stack.
>> >> > +  ftruncate( fd, stack_size1 );
>> >> > +   * For sharing the stack we specify the address of the
>> >> > +   * thread-stack we want to share with, the size of the shared
>> stack,
>> >> > +   * protection and access flags, file descriptor of the shared
>> memory objcet
>> >> > +  addr = mmap( stack_addr2, stack_size1, PROT_READ | PROT_WRITE,
>> O_RDWR, fd, 0 );
>> >> > +  rtems_test_assert( addr != NULL );
>> switched out.
>> >> > +  memset( stack_addr1, 0, stack_size1 );
>> switched out.
>> >> > +  memset( stack_addr2, 0, stack_size2 );
>> >> > +  TEST_END();
>> >> > +#define CONFIGURE_MAXIMUM_POSIX_THREADS        4
>> >> > +#define CONFIGURE_MAXIMUM_POSIX_SHMS           2
>> >> > +#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 10
>> >> > 2.17.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200814/f8c6c973/attachment-0001.html>
