Feature request libbsd, dhcpcd adding a dhcp option
junkes junkes at fhi-berlin.mpg.de
Fri Aug 21 08:30:57 UTC 2020
To get the most out of epics with libbsd, I would like to see an option
added to dhcpcd.
option 129 rtems_cmdline.
diff --git a/dhcpcd/dhcpcd-definitions.conf
b/dhcpcd/dhcpcd-definitions.conf
index 84260861..cb7d4306 100644
--- a/dhcpcd/dhcpcd-definitions.conf
+++ b/dhcpcd/dhcpcd-definitions.conf
@@ -160,6 +160,10 @@ encap 8            byte
provisioning_timer
  define 124     binhex                  vivco
  define 125     embed                   vivso
  embed          uint32                  enterprise_number
+# RTEMS
+define 129     string                  rtems_cmdline
  # Vendor options are shared between DHCP/DHCPv6
  # Their code is matched to the enterprise number defined above
  # see the end of this file for an example
diff --git a/dhcpcd/dhcpcd-embedded.c b/dhcpcd/dhcpcd-embedded.c
index 068a8dfd..b857eaba 100644
--- a/dhcpcd/dhcpcd-embedded.c
+++ b/dhcpcd/dhcpcd-embedded.c
@@ -154,6 +154,7 @@ const char *dhcpcd_embedded_conf[] = {
  "define 124 binhex vivco",
  "define 125 embed vivso",
  "embed uint32 enterprise_number",
+"define 129 string rtems_cmdline",
  "define 212 rfc5969 sixrd",
  "define6 1 binhex client_id",
  "define6 2 binhex server_id",
Danke Heinz
