Error while building FTW Patch
Wed Aug 26 15:13:37 UTC 2020
This looks unrelated. See if the plain toolchain without your patch
fails in the same way.
On Tue, Aug 25, 2020 at 12:58 PM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
> hello everyone,
> I after building arm-rtems6 toolchain with my ftw patch
> when i build rtems i receive this error
> The error comes on the patches that were earlier version of the successfully tested patch:)
> Error log :
> /home/eshan/development/rtems/kernel/rtems/c/src/../../testsuites/sptests/spcxx01/init.cc: In function 'void test_future()':
> /home/eshan/development/rtems/kernel/rtems/c/src/../../testsuites/sptests/spcxx01/init.cc:64:20: error: variable 'std::future<int> f' has initializer but incomplete type
>    64 |   std::future<int> f = std::async(std::launch::async, []{ return 12358; });
> /home/eshan/development/rtems/kernel/rtems/c/src/../../testsuites/sptests/spcxx01/init.cc:64:74: error: invalid use of incomplete type 'class std::future<int>'
>    64 | d::future<int> f = std::async(std::launch::async, []{ return 12358; });
> In file included from /home/eshan/development/rtems/kernel/rtems/c/src/../../testsuites/sptests/spcxx01/init.cc:32:
> /home/eshan/development/rtems/6/lib/gcc/arm-rtems6/10.2.1/include/c++/future:125:11: note: declaration of 'class std::future<int>'
>   125 |     class future;
> /home/eshan/development/rtems/6/lib/gcc/arm-rtems6/10.2.1/include/c++/future: At global scope:
> /home/eshan/development/rtems/6/lib/gcc/arm-rtems6/10.2.1/include/c++/future:189:5: error: 'std::future<typename std::__invoke_result<typename std::decay<_Tp>::type, typename std::decay<_Args>::type ...>::type> std::async(std::launch, _Fn&&, _Args&& ...) [with _Fn = test_future()::<lambda()>; _Args = {}; typename std::__invoke_result<typename std::decay<_Tp>::type, typename std::decay<_Args>::type ...>::type = int]', declared using local type 'test_future()::<lambda()>', is used but never defined [-fpermissive]
>   189 |     async(launch __policy, _Fn&& __fn, _Args&&... __args);
> Makefile:12245: recipe for target 'spcxx01/spcxx01-init.o' failed
> make[5]: *** [spcxx01/spcxx01-init.o] Error 1
> make[5]: Leaving directory '/home/eshan/development/rtems/kernel/xilinx_zynq_a9_qemu/arm-rtems6/c/xilinx_zynq_a9_qemu/testsuites/sptests'
> Makefile:663: recipe for target 'sptests' failed
> make[4]: *** [sptests] Error 2
> make[4]: Leaving directory '/home/eshan/development/rtems/kernel/xilinx_zynq_a9_qemu/arm-rtems6/c/xilinx_zynq_a9_qemu/testsuites'
> Makefile:1222: recipe for target 'testsuites' failed
> make[3]: *** [testsuites] Error 2
> make[3]: Leaving directory '/home/eshan/development/rtems/kernel/xilinx_zynq_a9_qemu/arm-rtems6/c/xilinx_zynq_a9_qemu'
> Makefile:716: recipe for target 'all-recursive' failed
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory '/home/eshan/development/rtems/kernel/xilinx_zynq_a9_qemu/arm-rtems6/c/xilinx_zynq_a9_qemu'
> Makefile:289: recipe for target 'all-recursive' failed
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory '/home/eshan/development/rtems/kernel/xilinx_zynq_a9_qemu/arm-rtems6/c'
> Makefile:410: recipe for target 'all-recursive' failed
> make: *** [all-recursive] Error 1
>  ~/development/rtems/kernel/xilinx_zynq_a9_qemu              01:25:05  eshan
>  2 ❯
> Thanks
> - Eshan
> devel mailing list
> devel at rtems.org
