[PATCH] rsb: Adding EPICS7 Package to RTEMS RSB
Mritunjay Sharma mritunjaysharma394 at gmail.com
Thu Aug 27 22:01:11 UTC 2020
 rtems/config/epics/epics-7.0-1.cfg    | 21 +++++++++
 rtems/config/epics/epics-base.bset    | 14 ++++++
 source-builder/config/epics-7.0-1.cfg | 65 +++++++++++++++++++++++++++
 3 files changed, 100 insertions(+)
 create mode 100644 rtems/config/epics/epics-7.0-1.cfg
 create mode 100644 rtems/config/epics/epics-base.bset
 create mode 100644 source-builder/config/epics-7.0-1.cfg
diff --git a/rtems/config/epics/epics-7.0-1.cfg b/rtems/config/epics/epics-7.0-1.cfg
new file mode 100644
index 0000000..34270ee
--- /dev/null
+++ b/rtems/config/epics/epics-7.0-1.cfg
@@ -0,0 +1,21 @@
+# EPICS 7.0
+%if %{release} == %{nil}
+ %define release 1
+%endif
+%include %{_configdir}/rtems-bsp.cfg
+# EPICS Version
+%define epics_version 7.0
+%hash sha512 epics-base-%{epics_version}.tar.gz 63edef9d3019e8253b81610286578a1e917cc9df75db3e8f5aaf99210b4fa842be296cf7cbd384726b81b648c4e0d041c4ef266ae81a580940d7613ce8ce48e0
+# EPICS Build configuration
+%include %{_configdir}/epics-7.0-1.cfg
diff --git a/rtems/config/epics/epics-base.bset b/rtems/config/epics/epics-base.bset
index 0000000..7ee3815
--- /dev/null
+++ b/rtems/config/epics/epics-base.bset
@@ -0,0 +1,14 @@
+# Build set for EPICS
+%define release 1
+# The RTEMS Package defines
+%include rtems-package.bset
+# Build EPICS.
+epics/epics-7.0-1
diff --git a/source-builder/config/epics-7.0-1.cfg b/source-builder/config/epics-7.0-1.cfg
index 0000000..c255dc3
--- /dev/null
+++ b/source-builder/config/epics-7.0-1.cfg
@@ -0,0 +1,65 @@
+# EPICS 7.x.x Version 1.
+# This configuration file configure's, make's and install's EPICS.
+%define release 1
+%endif
+Name:      epics-base-%{epics_version}-%{_host}-%{release}
+Summary:   EPICS v%{epics_version} for target %{_target} on host %{_host}
+Version:   %{epics_version}
+Release:   %{release}
+URL: 	  https://epics-controls.org/
+# Source
+%source set epics-base https://gitlab.fhi.mpg.de/junkes/epics-base/-/archive/%{epics_version}/epics-base-%{epics_version}.tar.gz
+# Prepare the source code.
+%prep
+  build_top=$(pwd)
+  source_dir_epics="epics-base-%{epics_version}"
+  %source setup epics-base -q -n ${source_dir_epics}
+  cd ${build_top}
+%build
+  build_top=$(pwd)
+  cd ${source_dir_epics}
+  %{build_build_flags}
+  # Using macros to dynamically path to RTEMS_BASE and RTEMS_VERSION using
+  # --with-rtems-bsp
+  %{__make} RTEMS_BASE=%{_prefix} \
+      RTEMS_VERSION=%{rtems_version} \
+      CROSS_COMPILER_TARGET_ARCHS=RTEMS-%{with_rtems_bsp}
+  cd ${build_top}
+#%install
+  build_top=$(pwd)
+  %{__rmdir} $SB_BUILD_ROOT
+  %{__make} DESTDIR=$SB_BUILD_ROOT \
+      RTEMS_BASE=%{_prefix} \
+      CROSS_COMPILER_TARGET_ARCHS=RTEMS-%{with_rtems_bsp} install
+  cd ${build_top}
2.25.1
