Ticket #3515
Bran S archsbran at gmail.com
Sat Feb 1 16:01:08 UTC 2020
On Sat, 1 Feb 2020 at 18:44, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> On Sat, Feb 1, 2020 at 12:57 PM Bran S <archsbran at gmail.com> wrote:
>> On Thu, 30 Jan 2020 at 05:52, Chris Johns <chrisj at rtems.org> wrote:
>> > On 29/1/20 7:03 pm, Bran S wrote:
>> > > Hi Guys,
>> > > I am trying to solve #3515
>> > > https://devel.rtems.org/ticket/3515 <
https://devel.rtems.org/ticket/3515>
>> > Nice and thanks.
>> > > For this issue covoar is required.
>> > > So I cloned https://git.rtems.org/rtems-tools/ <
https://git.rtems.org/rtems-tools/>
>> > > This is my directory structure:
>> > > $HOME/quick-start/src/rtems - Main RTEMS repo
>> > > $HOME/quick-start/src/rsb - Source Builder
>> > > $HOME/quick-start/src/rtems-tools - The one that I have recently
cloned
>> > > But running `rtems-test --list-bsps` inside
'$HOME/quick-start/src/rtems-tools'
>> > > gives "error: RTEMS Toolkit python wrapper not found, plrease report"
>> > > Any ideas on how to resolve this error ?
>> > What does `type rtems-test` say?
>> > Have you built a set of sparc tools?
>> > Have you build the leon3 BSP and all the tests?
>> > I am not sure what happens if the `rtems-test` is run in the source
tree while
>> > picking up a version from your path. Maybe `./tester/rtems-test ...`
works?
> Hi Bran,
> Thanks for taking up this ticket.
>> It is now working my $PATH was wrongly set with rtems/4.11 instead of
rtems/5.
>> I have corrected it. It now contains '$HOME/quick-start/rtems/5/bin'
> Nice.
>> Moving on to the next problem:
https://devel.rtems.org/wiki/GCI/Documentation/CoverageAnalysis/Coverage#RunningRTEMS-TESTERforCoverageanalysis
>> I was reading this to know more about covoar.
>> So as mentioned above I ran
>> `rtems-test --rtems-tools=/home/user45/quick-start/rtems/5/
>> --log=coverage_analysis.log --no-clean --coverage=score
>> --rtems-bsp=leon3-qemu-cov
/home/user45/quick-start/build/b-leon3/sparc-rtems5/c/leon3/testsuites/samples/hello.exe`
>> And the output was: https://paste.debian.net/1128608/
>> `qemu-system-sparc` not being installed seems to be the cause for the
error.
>> So I followed suggestion found here:
>> https://lists.rtems.org/pipermail/users/2018-January/065583.html
>> Ran the commands as:
>> $ cd /quick-start/src/rsb/rtems/
>> The rsb directory contains rtems source builder.
>> $ ../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/5
>> devel/qemu.bset
> You need devel/qemu-couverture.bset but while trying to build it, I see
the same error
> as you see with qemu.bset
>> Running this further gives errors and reports it into
>> 'rsb-report-glib-2.39.3-x86_64-linux-gnu-1.txt'
>> Full output of above command is at: https://paste.debian.net/1128609/
>> The content of 'rsb-report-glib-2.39.3-x86_64-linux-gnu-1.txt' is
>> here: https://paste.debian.net/1128610/
>> In file 'rsb-report-glib-2.39.3-x86_64-linux-gnu-1.txt' (at
>> https://paste.debian.net/1128610/) the first error occurs at line 385,
>> which is:
>> ../../glib-2.39.3/glib/gdate.c:2497:7: error: format not a string
>> literal, format string not checked [-Werror=format-nonliteral]
>>        tmplen = strftime (tmpbuf, tmpbufsize, locale_format, &tm);
>>   CC       libglib_2_0_la-gdir.lo
>>   CC       libglib_2_0_la-genviron.lo
>> cc1: some warnings being treated as errors
>> Makefile:1782: recipe for target 'libglib_2_0_la-gdate.lo' failed
>> make[4]: *** [libglib_2_0_la-gdate.lo] Error 1
>> This happens to be a known error/bug (Ref:
>> https://bugs.freedesktop.org/show_bug.cgi?id=95326)
>> and a patch is available for it here:
https://gitlab.gnome.org/GNOME/glib/commit/8cdbc7fb2c8c876902e457abe46ee18a0b134486
>> Following the patch I manually made changes into
'$HOME/quick-start/src/rsb/rtems/build/glib-2.39.3-x86_64-linux-gnu-1/glib-2.39.3/glib/gdate.c'
>> But the problem is that as soon as I run
>> `../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/5
>> devel/qemu.bset`
>> My manual changes to the gdate.c disappear and I get the same error as
>> before. I don't know what is going on.
> I applied the patch that you found along with another patch and built the
souces, glib built
> successfully, but unfortunately the couverture-qemu itself failed to
build. Here's the log:
> https://paste.ofcode.org/KmJCNZrJyQNev6R4FSUafe
> Here I'm pasting the diff to add patches to RSB:
> diff --git a/bare/config/devel/glib-2.39.3-1.cfg
b/bare/config/devel/glib-2.39.3-1.cfg
> index d86fe28..0bada15 100644
> --- a/bare/config/devel/glib-2.39.3-1.cfg
> +++ b/bare/config/devel/glib-2.39.3-1.cfg
> @@ -14,6 +14,10 @@
>  %hash sha256 glib-%{glib_version}.tar.xz
d9fa6c9aa645a5e688a3bb29013bb83801b19ee767d99e33ff52e004e1cc5fc8
> +#Patch to supress string literal warning
> +%patch add glib
https://gitlab.gnome.org/GNOME/glib/commit/0817af40e8c74c721c30f6ef482b1f53d12044c7.patch
> +%patch add glib
https://gitlab.gnome.org/GNOME/glib/commit/566e1d61a500267c7849ad0b2552feec9c9a29a6.patch
>  # The GLib build instructions. We use 2.x.x Release 1.
> You can apply the above diff into your rtems-source-builder and try to
build couverture qemu.
> Most likely it will fail it seems.
>> After this I found out that `qemu4.bset` is also present so I ran
>> devel/qemu4.bset
>> It seems to have run successfully here is the full output:
>> https://paste.debian.net/1128611/
>> Seems like qemu-system-sparc is now installed. But still while running
>> I get the same error related to qemu-system-sparc.
>> Here is the full output: https://paste.debian.net/1128612/
>> But this time there is a little difference.
>> Earlier it exited with exit code 2. see (
https://paste.debian.net/1128608/)
>> Now it is exiting with exit code 1. see (
https://paste.debian.net/1128612/)
>> Note: To see the exit code on the above 2 links you may have to use
>> the horizontal scroll.
>> What am I doing wrong ? Please suggest a way to solve this. I am just
>> trying to run a simple rtems-test coverage.
> For now, I suggest you to use --rtems-bsp=leon3-sis-cov instead of qemu,
> this is give you the reports and you can start focusing on your main
ticket.
Thanks for the suggestion, leon3-sis-cov works, with a minor error as:
error: copying tree (4):
/home/user45/quick-start/rtems/5/share/rtems/tester/covoar/covoar.css
-> /home/user45/quick-start/leon3-sis-coverage/score: [Errno 2] No
such file or directory:
'/home/user45/quick-start/rtems/5/share/rtems/tester/covoar/covoar.css'
But the leon3-sis-report.html gives the coverage report. I am still
studying the leon3-sis-coverage directory.
On a sidenote I see that you worked on this as your gsoc project.
Please mention any source which proved to be helpful in understanding
rtems better.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200201/2217a48a/attachment-0001.html>
