[PATCH 6/7] bsps: Remove uses of BSP_GET_WORK_AREA_DEBUG
Mon Feb 3 05:21:12 UTC 2020
----- Am 3. Feb 2020 um 1:14 schrieb Chris Johns chrisj at rtems.org:
> On 2/2/20 1:28 am, Sebastian Huber wrote:
>> ----- Am 20. Jan 2020 um 6:01 schrieb Chris Johns chrisj at rtems.org:
>>> On 17/12/19 4:57 pm, Sebastian Huber wrote:
>>>> My experience tells me that doing a BSP development without a debugger is a
>>>> waste of time.
>>> Sometimes getting a working debugger is more effort than getting a BSP to work.
>>> The Pi is an example. I believe Alan used print statements.
>> Ok, what do you think about a new configuration option:
>> CONFIGURE_ENABLE_VERBOSE_INITIALIZATION
> CONFIGURE_ENABLE_VERBOSE_SYS_INIT ?
In v2 of the patch set I named it CONFIGURE_VERBOSE_INITIALIZATION. I am not in favour of abbreviations, since they are in general not used in the configuration options. More precise would be CONFIGURE_VERBOSE_SYSTEM_INITIALIZATION. It is longer, but would be not the longest configuration option name (e.g. CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER is longer). So, what about this one?
