[PATCH] config: Add CONFIGURE_DIRTY_MEMORY
Tue Feb 4 14:27:37 UTC 2020
Replace the BSP_DIRTY_MEMORY BSP option with a CONFIGURE_DIRTY_MEMORY
configuration option.
Update #3843.
 bsps/shared/start/bootcard.c            | 13 ------------
 c/src/aclocal/bsp-bootcard-options.m4   | 12 ++---------
 cpukit/Makefile.am                      |  1 +
 cpukit/include/rtems/confdefs.h         |  8 +++++++
 cpukit/include/rtems/score/memory.h     |  5 +++++
 cpukit/score/src/memorydirtyfreeareas.c | 37 +++++++++++++++++++++++++++++++++
 testsuites/sptests/sp54/init.c          |  2 ++
 7 files changed, 55 insertions(+), 23 deletions(-)
 create mode 100644 cpukit/score/src/memorydirtyfreeareas.c
diff --git a/bsps/shared/start/bootcard.c b/bsps/shared/start/bootcard.c
index 2eef1ea710..8f053012ec 100644
--- a/bsps/shared/start/bootcard.c
+++ b/bsps/shared/start/bootcard.c
@@ -24,19 +24,6 @@
 const char *bsp_boot_cmdline;
-#if BSP_DIRTY_MEMORY == 1
-static void bsp_dirty_memory(void)
-  _Memory_Fill( _Memory_Get(), 0xcf );
-RTEMS_SYSINIT_ITEM(
-  bsp_dirty_memory,
-  RTEMS_SYSINIT_DIRTY_MEMORY,
-  RTEMS_SYSINIT_ORDER_MIDDLE
-#endif
 RTEMS_SYSINIT_ITEM(
   bsp_start,
   RTEMS_SYSINIT_BSP_START,
diff --git a/c/src/aclocal/bsp-bootcard-options.m4 b/c/src/aclocal/bsp-bootcard-options.m4
index 2454ec5094..b0d25f383c 100644
--- a/c/src/aclocal/bsp-bootcard-options.m4
+++ b/c/src/aclocal/bsp-bootcard-options.m4
@@ -1,17 +1,9 @@
 dnl
 dnl BSP_BOOTCARD_OPTIONS - some autoconf voodoo to provide each BSPs'
 dnl configure script with the standard options supported by boot_card()
-dnl and other required parts of the BSP Framework.  Currently, this is
-dnl
-dnl   - Can optionally dirty memory at boot time.
+dnl and other required parts of the BSP Framework.
 dnl
 dnl To be used in bsp-configure scripts
-AC_DEFUN([RTEMS_BSP_BOOTCARD_OPTIONS],[
-RTEMS_BSPOPTS_SET([BSP_DIRTY_MEMORY],[*],[0])
-RTEMS_BSPOPTS_HELP([BSP_DIRTY_MEMORY],
-[If defined, then the BSP Framework will put a non-zero pattern into
- the RTEMS Workspace and C program heap.  This should assist in finding
- code that assumes memory starts set to zero.])
+AC_DEFUN([RTEMS_BSP_BOOTCARD_OPTIONS],[])
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index b9ab123b49..9182919558 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -853,6 +853,7 @@ librtemscpu_a_SOURCES += score/src/heapiterate.c
 librtemscpu_a_SOURCES += score/src/heapgreedy.c
 librtemscpu_a_SOURCES += score/src/heapnoextend.c
 librtemscpu_a_SOURCES += score/src/memoryallocate.c
+librtemscpu_a_SOURCES += score/src/memorydirtyfreeareas.c
 librtemscpu_a_SOURCES += score/src/memoryfill.c
 librtemscpu_a_SOURCES += score/src/memoryzerobeforeuse.c
 librtemscpu_a_SOURCES += score/src/memoryzerofreeareas.c
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 982e3ddb56..659fee936f 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -2802,6 +2802,14 @@ struct _reent *__getreent(void)
     #endif
+  #ifdef CONFIGURE_DIRTY_MEMORY
+    RTEMS_SYSINIT_ITEM(
+      _Memory_Dirty_free_areas,
+      RTEMS_SYSINIT_DIRTY_MEMORY,
+      RTEMS_SYSINIT_ORDER_MIDDLE
+  #endif
   #ifdef CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY
     const bool _Memory_Zero_before_use = true;
diff --git a/cpukit/include/rtems/score/memory.h b/cpukit/include/rtems/score/memory.h
index ffc4897ed5..440a59c793 100644
--- a/cpukit/include/rtems/score/memory.h
+++ b/cpukit/include/rtems/score/memory.h
@@ -344,6 +344,11 @@ extern const bool _Memory_Zero_before_use;
 void _Memory_Zero_free_areas( void );
+ * @brief Dirty all free memory areas of the system.
+void _Memory_Dirty_free_areas( void );
 #ifdef __cplusplus
diff --git a/cpukit/score/src/memorydirtyfreeareas.c b/cpukit/score/src/memorydirtyfreeareas.c
new file mode 100644
index 0000000000..537dff2697
--- /dev/null
+++ b/cpukit/score/src/memorydirtyfreeareas.c
@@ -0,0 +1,37 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 embedded brains GmbH
+ * are met:
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/memory.h>
+  _Memory_Fill( _Memory_Get(), 0xcf );
diff --git a/testsuites/sptests/sp54/init.c b/testsuites/sptests/sp54/init.c
index c9c8d6fe30..07001e1e5e 100644
--- a/testsuites/sptests/sp54/init.c
+++ b/testsuites/sptests/sp54/init.c
@@ -83,6 +83,8 @@ rtems_initialization_tasks_table Initialization_tasks[1] =
 #define CONFIGURE_INIT_TASK_TABLE_SIZE 0
 #define CONFIGURE_INIT_TASK_STACK_SIZE 0
+#define CONFIGURE_DIRTY_MEMORY
  *  Ensure we test the case where memory is zero.
2.16.4
