Remove support for RTEMS_SCHEDSIM?
Fri Feb 14 15:42:52 UTC 2020
On 14/02/2020 16:31, Joel Sherrill wrote:
> On Fri, Feb 14, 2020 at 9:04 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 14/02/2020 15:42, Joel Sherrill wrote:
>     > I guess it is time to kill it.
>     I already have a smoking gun in my hands. I think it would be
>     possible
>     to make it working again with some effort. However, it is quite
>     easy to
>     add scheduler test scenarios in the RTEMS test suite itself, for
>     example:
>     https://git.rtems.org/rtems/tree/testsuites/smptests/smpschededf02/init.c#n108
> The simulator allowed you to instance any number of cores in a system and
> reduce the testing to just the scheduling events -- no interrupts, no
> hardware,
> no device drivers, and native debug environment.
> You can easily construct a system with 2, 4, 8, 32, or 64 nodes with
> it. It is
> more flexible and really much simpler to debug with when developing a
> scheduler.
Ok, this is difficult with real hardware. If there is a need, we can
make it work again.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200214/4b1f06ad/attachment.html>
