[PATCH 18/18] config: Add <rtems/confdefs/obsolete.h>
Fri Feb 14 16:02:43 UTC 2020
Unify handling of obsolete configuration options.  Change license to
BSD-2-Clause.
Update #3053.
Update #3875.
 cpukit/header-dirs.am                    |   2 +
 cpukit/headers.am                        |   1 +
 cpukit/include/rtems/confdefs.h          | 156 +-----------------------
 cpukit/include/rtems/confdefs/obsolete.h | 199 +++++++++++++++++++++++++++++++
 4 files changed, 203 insertions(+), 155 deletions(-)
 create mode 100644 cpukit/include/rtems/confdefs/obsolete.h
diff --git a/cpukit/header-dirs.am b/cpukit/header-dirs.am
index 7197f1a29f..d90271be9e 100644
--- a/cpukit/header-dirs.am
+++ b/cpukit/header-dirs.am
@@ -50,6 +50,8 @@ include_rtems_bfindir = $(includedir)/rtems/bfin
 include_rtems_bfin_HEADERS =
 include_rtems_bsdnetdir = $(includedir)/rtems/bsdnet
 include_rtems_bsdnet_HEADERS =
+include_rtems_confdefsdir = $(includedir)/rtems/confdefs
+include_rtems_confdefs_HEADERS =
 include_rtems_debuggerdir = $(includedir)/rtems/debugger
 include_rtems_debugger_HEADERS =
 include_rtems_m68kdir = $(includedir)/rtems/m68k
diff --git a/cpukit/headers.am b/cpukit/headers.am
index 6e1ab4ccd0..f0c8319dcb 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -183,6 +183,7 @@ include_rtems_HEADERS += include/rtems/userenv.h
 include_rtems_HEADERS += include/rtems/version.h
 include_rtems_HEADERS += include/rtems/vmeintr.h
 include_rtems_HEADERS += include/rtems/watchdogdrv.h
+include_rtems_confdefs_HEADERS += include/rtems/confdefs/obsolete.h
 include_rtems_debugger_HEADERS += include/rtems/debugger/rtems-debugger-bsp.h
 include_rtems_debugger_HEADERS += include/rtems/debugger/rtems-debugger-remote.h
 include_rtems_debugger_HEADERS += include/rtems/debugger/rtems-debugger-server.h
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index e0d4a77075..cf58f5ecc2 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -50,6 +50,7 @@
 #include <rtems/posix/semaphore.h>
 #include <rtems/posix/shm.h>
 #include <rtems/posix/timer.h>
+#include <rtems/confdefs/obsolete.h>
 #include <limits.h>
@@ -138,11 +139,6 @@ extern "C" {
 #endif
 #endif
-#ifdef CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
-  #warning "CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS has been renamed to CONFIGURE_MAXIMUM_FILE_DESCRIPTORS since RTEMS 5.1"
-  #define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
-#endif
  * This macro defines the number of POSIX file descriptors allocated
  * and managed by libio.  These are the "integer" file descriptors that
@@ -167,11 +163,6 @@ extern "C" {
   const uint32_t rtems_libio_number_iops = RTEMS_ARRAY_SIZE(rtems_libio_iops);
 #endif
-#ifdef CONFIGURE_SMP_MAXIMUM_PROCESSORS
-  #warning "CONFIGURE_SMP_MAXIMUM_PROCESSORS has been renamed to CONFIGURE_MAXIMUM_PROCESSORS since RTEMS 5.1"
-  #define CONFIGURE_MAXIMUM_PROCESSORS CONFIGURE_SMP_MAXIMUM_PROCESSORS
-#endif
 /* Ensure that _CONFIGURE_MAXIMUM_PROCESSORS > 1 only in SMP configurations */
 #if defined(CONFIGURE_MAXIMUM_PROCESSORS) && defined(RTEMS_SMP)
   #define _CONFIGURE_MAXIMUM_PROCESSORS CONFIGURE_MAXIMUM_PROCESSORS
@@ -191,34 +182,10 @@ extern "C" {
   #endif
 #endif
-#ifdef CONFIGURE_SMP_APPLICATION
-  #warning "CONFIGURE_SMP_APPLICATION is obsolete since RTEMS 5.1"
-#endif
  * This sets up the resources for the FIFOs/pipes.
- * This is specified to configure the maximum number of POSIX FIFOs.
-#ifdef CONFIGURE_MAXIMUM_FIFOS
-  #warning "CONFIGURE_MAXIMUM_FIFOS is obsolete since RTEMS 5.1; use CONFIGURE_IMFS_ENABLE_MKFIFO instead"
-  #if CONFIGURE_MAXIMUM_FIFOS > 0
-    #define CONFIGURE_IMFS_ENABLE_MKFIFO
-  #endif
-#endif
- * This is specified to configure the maximum number of POSIX named pipes.
-#ifdef CONFIGURE_MAXIMUM_PIPES
-  #warning "CONFIGURE_MAXIMUM_PIPES is obsolete since RTEMS 5.1; use CONFIGURE_IMFS_ENABLE_MKFIFO instead"
-  #if CONFIGURE_MAXIMUM_PIPES > 0
-  #endif
-#endif
  *  @defgroup ConfigFilesystems Filesystems and Mount Table Configuration
@@ -617,14 +584,6 @@ extern "C" {
 #endif
 /**@}*/ /* end of file system group */
- *  STACK_CHECKER_ON was still available in 4.9 so give a warning for now.
-#if defined(STACK_CHECKER_ON)
-  #define CONFIGURE_STACK_CHECKER_ENABLED
-  #warning "STACK_CHECKER_ON deprecated -- use CONFIGURE_STACK_CHECKER_ENABLED"
-#endif
  * This configures the stack checker user extension.
@@ -702,21 +661,6 @@ extern "C" {
  *    - CONFIGURE_SCHEDULER_USER_PER_THREAD
-#ifdef CONFIGURE_SCHEDULER_CONTEXT
-  #warning "CONFIGURE_SCHEDULER_CONTEXT has been renamed to CONFIGURE_SCHEDULER since RTEMS 5.1"
-  #define CONFIGURE_SCHEDULER CONFIGURE_SCHEDULER_CONTEXT
-#endif
-#ifdef CONFIGURE_SCHEDULER_CONTROLS
-  #warning "CONFIGURE_SCHEDULER_CONTROLS has been renamed to CONFIGURE_SCHEDULER_TABLE_ENTRIES since RTEMS 5.1"
-  #define CONFIGURE_SCHEDULER_TABLE_ENTRIES CONFIGURE_SCHEDULER_CONTROLS
-#endif
-#ifdef CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS
-  #warning "CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS has been renamed to CONFIGURE_SCHEDULER_ASSIGNMENTS since RTEMS 5.1"
-  #define CONFIGURE_SCHEDULER_ASSIGNMENTS CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS
-#endif
 #if !defined(CONFIGURE_SCHEDULER_USER) && \
     !defined(CONFIGURE_SCHEDULER_PRIORITY) && \
     !defined(CONFIGURE_SCHEDULER_PRIORITY_SMP) && \
@@ -1665,12 +1609,6 @@ const Thread_Idle_body _Thread_Idle_body = CONFIGURE_IDLE_TASK_BODY;
     (_CONFIGURE_LIBBLOCK_TASKS * \
     (CONFIGURE_BDBUF_TASK_STACK_SIZE <= CONFIGURE_MINIMUM_TASK_STACK_SIZE ? \
     0 : CONFIGURE_BDBUF_TASK_STACK_SIZE - CONFIGURE_MINIMUM_TASK_STACK_SIZE))
-  #if defined(CONFIGURE_HAS_OWN_BDBUF_TABLE) || \
-      defined(CONFIGURE_BDBUF_BUFFER_SIZE) || \
-      defined(CONFIGURE_BDBUF_BUFFER_COUNT)
-    #error BDBUF Cache does not use a buffer configuration table. Please remove.
-  #endif
 #else
   /** This specifies the number of libblock tasks. */
   #define _CONFIGURE_LIBBLOCK_TASKS 0
@@ -2932,82 +2870,6 @@ struct _reent *__getreent(void)
   #error "Maximum priority configured higher than supported by target."
 #endif
-#ifdef CONFIGURE_HAS_OWN_CONFIGURATION_TABLE
-  #warning "The CONFIGURE_HAS_OWN_CONFIGURATION_TABLE configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
-  #warning "The CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_HAS_OWN_FILESYSTEM_TABLE
-  #warning "The CONFIGURE_HAS_OWN_FILESYSTEM_TABLE configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_HAS_OWN_INIT_TABLE
-  #warning "The CONFIGURE_HAS_OWN_INIT_TABLE configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_HAS_OWN_MOUNT_TABLE
-  #warning "The CONFIGURE_HAS_OWN_MOUNT_TABLE configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE
-#endif
-#ifdef CONFIGURE_NUMBER_OF_TERMIOS_PORTS
-  #warning "The CONFIGURE_NUMBER_OF_TERMIOS_PORTS configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_MAXIMUM_ADA_TASKS
-  #warning "The CONFIGURE_MAXIMUM_ADA_TASKS configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_MAXIMUM_FAKE_ADA_TASKS
-  #warning "The CONFIGURE_MAXIMUM_FAKE_ADA_TASKS configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_MAXIMUM_MRSP_SEMAPHORES
-  #warning "The CONFIGURE_MAXIMUM_MRSP_SEMAPHORES configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_MAXIMUM_POSIX_BARRIERS
-  #warning "The CONFIGURE_MAXIMUM_POSIX_BARRIERS configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES
-  #warning "The CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS
-  #warning "The CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_MAXIMUM_POSIX_MUTEXES
-  #warning "The CONFIGURE_MAXIMUM_POSIX_MUTEXES configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_MAXIMUM_POSIX_RWLOCKS
-  #warning "The CONFIGURE_MAXIMUM_POSIX_RWLOCKS configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_MAXIMUM_POSIX_SPINLOCKS
-  #warning "The CONFIGURE_MAXIMUM_POSIX_SPINLOCKS configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_MAXIMUM_PTYS
-  #warning "The CONFIGURE_MAXIMUM_PTYS configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
-  #warning "The CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_TERMIOS_DISABLED
-  #warning "The CONFIGURE_TERMIOS_DISABLED configuration option is obsolete since RTEMS 5.1"
-#endif
  * POSIX Key pair shouldn't be less than POSIX Key, which is highly
  * likely to be error.
@@ -3032,21 +2894,5 @@ struct _reent *__getreent(void)
   #error "IMFS Memfile block size must be a power of 2 between 16 and 512"
 #endif
-#ifdef CONFIGURE_ENABLE_GO
-  #warning "The CONFIGURE_ENABLE_GO configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_GNAT_RTEMS
-  #warning "The CONFIGURE_GNAT_RTEMS configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_MAXIMUM_GOROUTINES
-  #warning "The CONFIGURE_MAXIMUM_GOROUTINES configuration option is obsolete since RTEMS 5.1"
-#endif
-#ifdef CONFIGURE_MAXIMUM_GO_CHANNELS
-  #warning "The CONFIGURE_MAXIMUM_GO_CHANNELS configuration option is obsolete since RTEMS 5.1"
-#endif
 #endif
 /* end of include file */
diff --git a/cpukit/include/rtems/confdefs/obsolete.h b/cpukit/include/rtems/confdefs/obsolete.h
new file mode 100644
index 0000000000..cd87df1138
--- /dev/null
+++ b/cpukit/include/rtems/confdefs/obsolete.h
@@ -0,0 +1,199 @@
+ * @file
+ * @ingroup RTEMSApplicationConfiguration
+ * @brief This header file deals with obsolete configuration options.
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2017, 2020 embedded brains GmbH
+ * are met:
+#ifndef _RTEMS_CONFDEFS_OBSOLETE_H
+#define _RTEMS_CONFDEFS_OBSOLETE_H
+#ifndef __CONFIGURATION_TEMPLATE_h
+#error "Do not include this file directly, use <rtems/confdefs.h> instead"
+#endif
+#ifdef CONFIGURE_INIT
+#ifdef CONFIGURE_BDBUF_BUFFER_SIZE
+  #error "The CONFIGURE_BDBUF_BUFFER_SIZE configuration option is obsolete since RTEMS 4.10"
+#endif
+#ifdef CONFIGURE_BDBUF_BUFFER_COUNT
+  #error "The CONFIGURE_BDBUF_BUFFER_COUNT configuration option is obsolete since RTEMS 4.10"
+#endif
+#ifdef CONFIGURE_ENABLE_GO
+  #warning "The CONFIGURE_ENABLE_GO configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_GNAT_RTEMS
+  #warning "The CONFIGURE_GNAT_RTEMS configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_HAS_OWN_CONFIGURATION_TABLE
+  #warning "The CONFIGURE_HAS_OWN_CONFIGURATION_TABLE configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_HAS_OWN_BDBUF_TABLE
+  #error "The CONFIGURE_HAS_BDBUF_TABLE configuration option is obsolete since RTEMS 4.10"
+#endif
+#ifdef CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
+  #warning "The CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_HAS_OWN_FILESYSTEM_TABLE
+  #warning "The CONFIGURE_HAS_OWN_FILESYSTEM_TABLE configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_HAS_OWN_INIT_TABLE
+  #warning "The CONFIGURE_HAS_OWN_INIT_TABLE configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_HAS_OWN_MOUNT_TABLE
+  #warning "The CONFIGURE_HAS_OWN_MOUNT_TABLE configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE
+#endif
+#ifdef CONFIGURE_NUMBER_OF_TERMIOS_PORTS
+  #warning "The CONFIGURE_NUMBER_OF_TERMIOS_PORTS configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_MAXIMUM_ADA_TASKS
+  #warning "The CONFIGURE_MAXIMUM_ADA_TASKS configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_MAXIMUM_FAKE_ADA_TASKS
+  #warning "The CONFIGURE_MAXIMUM_FAKE_ADA_TASKS configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_MAXIMUM_FIFOS
+  #warning "CONFIGURE_MAXIMUM_FIFOS is obsolete since RTEMS 5.1; use CONFIGURE_IMFS_ENABLE_MKFIFO instead"
+  #if CONFIGURE_MAXIMUM_FIFOS > 0
+    #define CONFIGURE_IMFS_ENABLE_MKFIFO
+  #endif
+#endif
+#ifdef CONFIGURE_MAXIMUM_GOROUTINES
+  #warning "The CONFIGURE_MAXIMUM_GOROUTINES configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_MAXIMUM_GO_CHANNELS
+  #warning "The CONFIGURE_MAXIMUM_GO_CHANNELS configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_MAXIMUM_MRSP_SEMAPHORES
+  #warning "The CONFIGURE_MAXIMUM_MRSP_SEMAPHORES configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_MAXIMUM_PIPES
+  #warning "CONFIGURE_MAXIMUM_PIPES is obsolete since RTEMS 5.1; use CONFIGURE_IMFS_ENABLE_MKFIFO instead"
+  #if CONFIGURE_MAXIMUM_PIPES > 0
+  #endif
+#endif
+#ifdef CONFIGURE_MAXIMUM_POSIX_BARRIERS
+  #warning "The CONFIGURE_MAXIMUM_POSIX_BARRIERS configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES
+  #warning "The CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS
+  #warning "The CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_MAXIMUM_POSIX_MUTEXES
+  #warning "The CONFIGURE_MAXIMUM_POSIX_MUTEXES configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_MAXIMUM_POSIX_RWLOCKS
+  #warning "The CONFIGURE_MAXIMUM_POSIX_RWLOCKS configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_MAXIMUM_POSIX_SPINLOCKS
+  #warning "The CONFIGURE_MAXIMUM_POSIX_SPINLOCKS configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_MAXIMUM_PTYS
+  #warning "The CONFIGURE_MAXIMUM_PTYS configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
+  #warning "CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS has been renamed to CONFIGURE_MAXIMUM_FILE_DESCRIPTORS since RTEMS 5.1"
+  #define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
+#endif
+#ifdef CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
+  #warning "The CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_SCHEDULER_CONTEXT
+  #warning "CONFIGURE_SCHEDULER_CONTEXT has been renamed to CONFIGURE_SCHEDULER since RTEMS 5.1"
+  #define CONFIGURE_SCHEDULER CONFIGURE_SCHEDULER_CONTEXT
+#endif
+#ifdef CONFIGURE_SCHEDULER_CONTROLS
+  #warning "CONFIGURE_SCHEDULER_CONTROLS has been renamed to CONFIGURE_SCHEDULER_TABLE_ENTRIES since RTEMS 5.1"
+  #define CONFIGURE_SCHEDULER_TABLE_ENTRIES CONFIGURE_SCHEDULER_CONTROLS
+#endif
+#ifdef CONFIGURE_SMP_APPLICATION
+  #warning "CONFIGURE_SMP_APPLICATION is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_SMP_MAXIMUM_PROCESSORS
+  #warning "CONFIGURE_SMP_MAXIMUM_PROCESSORS has been renamed to CONFIGURE_MAXIMUM_PROCESSORS since RTEMS 5.1"
+  #define CONFIGURE_MAXIMUM_PROCESSORS CONFIGURE_SMP_MAXIMUM_PROCESSORS
+#endif
+#ifdef CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS
+  #warning "CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS has been renamed to CONFIGURE_SCHEDULER_ASSIGNMENTS since RTEMS 5.1"
+  #define CONFIGURE_SCHEDULER_ASSIGNMENTS CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS
+#endif
+#ifdef CONFIGURE_TERMIOS_DISABLED
+  #warning "The CONFIGURE_TERMIOS_DISABLED configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef STACK_CHECKER_ON
+  #warning "STACK_CHECKER_ON has been renamed to CONFIGURE_STACK_CHECKER_ENABLED since RTEMS 4.10"
+  #define CONFIGURE_STACK_CHECKER_ENABLED
+#endif
+#endif /* CONFIGURE_INIT */
+#endif /* _RTEMS_CONFDEFS_OBSOLETE_H */
2.16.4
