[PATCH v3 2/2] bsp/raspberrypi: Mini UART driver
G. S. Niteesh gsnb.gn at gmail.com
Sun Feb 16 17:44:52 UTC 2020
Can someone please push these patches?
Thanks,
Niteesh
On Sun, Feb 16, 2020 at 11:05 PM Alan Cudmore <alan.cudmore at gmail.com>
wrote:
> Awesome! The Pi Zero W is a bonus too! I think we can run RTEMS on all
> models except the Pi 4 now.
> On Sun, Feb 16, 2020 at 12:30 PM G. S. Niteesh <gsnb.gn at gmail.com> wrote:
> > Hii Alan,
> > I tested it on my Raspberry Pi 3 model b v1.2 and it works.
> > U-Boot is not required anymore :)
> > Thanks,
> > Niteesh.
> > On Sun, Feb 16, 2020 at 10:51 PM Alan Cudmore <alan.cudmore at gmail.com>
> wrote:
> >> I'm definitely using the kernel_address, but letting the firmware
> >> decide what image to boot. For me kernel.img is the single core ARM
> >> images. kernel7.img is used for the raspberry pi 2 and 3. With these
> >> names, I can have both images on the same SD card to test in all of my
> >> Pis.
> >> my config.txt:
> >> enable_uart=1
> >> kernel_address=0x200000
> >> On Sun, Feb 16, 2020 at 11:44 AM Christian Mauderer <list at c-mauderer.de>
> wrote:
> >> > On 16/02/2020 17:31, G. S. Niteesh wrote:
> >> > > Can you please share your config.txt for Pi3.
> >> > +1
> >> > It's interesting that it seems to work without an adapted config.txt.
> It
> >> > should be at least necessary to define the start address.
> >> > > Thanks,
> >> > > Niteesh
> >> > > On Sun, Feb 16, 2020 at 9:58 PM Alan Cudmore <
> >> > > <mailto:alan.cudmore at gmail.com>> wrote:
> >> > >     I tried running my raspberrypi BSP image that worked on the Pi
> Zero
> >> > >     and W, but it did not work on the Pi 3.
> >> > >     I built the raspberrypi2 BSP, used objcopy to copy the binary
> to my sd
> >> > >     card as kernel7.img, and it works on my Pi 3 and Pi3 A+ (
> without
> >> > >     ethernet) . Note that my config.txt file does not specify the
> kernel
> >> > >     image, so the firmware defaults to kernel.img for the single
> core
> >> > >     models and kernel7.img for the 2 and 3.
> >> > >     I probably wont get a chance to try u-boot until later today or
> >> > >     tomorrow.
> >> > >     But these patches are great for enabling the Pi Zero W and Pi 3
> models!
> >> > >     Thanks,
> >> > >     Alan
> >> > >     On Sun, Feb 16, 2020 at 10:58 AM G. S. Niteesh <
> >> > >     <mailto:gsnb.gn at gmail.com>> wrote:
> >> > >     > On Sun, Feb 16, 2020 at 8:37 PM Alan Cudmore
> >> > >     <alan.cudmore at gmail.com <mailto:alan.cudmore at gmail.com>> wrote:
> >> > >     >> Hi Niteesh,
> >> > >     >> I can try this patch on my Pi 3. Which BSP should I use? Is
> there any
> >> > >     >> special setup or BSP configuration needed?
> >> > >     >> Thanks,
> >> > >     >> Alan
> >> > >     > Hi Alan,
> >> > >     > First of all, thank you for taking this initiative.
> >> > >     > I have tried using the default bootloader in Pi3 to load
> RTEMS but
> >> > >     it doesn't work,
> >> > >     > Can you try it?
> >> > >     > The currently use U-Boot in 32bit mode as the bootloader.
> >> > >     > You can use the below instructions to build U-Boot in 32bit
> mode
> >> > >     > git clone https://github.com/u-boot/u-boot.git u-boot
> >> > >     > cd u-boot
> >> > >     > git revert 995eab8b5b580b67394312b1621c60a71042cd18
> >> > >     > make CROSS_COMPILE=arm-linux-gnueabi- rpi_3_32b_defconfig
> >> > >     > This one uses an old version of U-Boot and I don't know if
> there is
> >> > >     > a new way to build in 32bit mode.
> >> > >     > To build the U-Boot image of RTEMS you can use the below
> instructions
> >> > >     > arm-rtems5-objcopy -Obinary hello.exe kernel.img
> >> > >     > mkimage -A arm -O linux -T kernel -a 0x200000 -e 0x200080 -d
> >> > >     kernel.img -C none rtems.img
> >> > >     > To load and run in U-Boot
> >> > >     > fatload mmc 0 0x200000 rtems.img
> >> > >     > fatload mmc 0 0x1000 bcm2710-rpi-3-b.dtb
> >> > >     > bootm 0x200000 - 0x1000
> >> > >     > And to make your U-Boot build process simpler I have uploaded
> my
> >> > >     u-boot.bin
> >> > >     > to my github, please use it :)
> >> > >     > https://github.com/gs-niteesh/rpi3_RTEMS
> >> > >     > And sorry for the delay, I tested all these instructions again
> >> > >     before sending them.
> >> > >     > Thanks
> >> > >     > Niteesh.
> >> > >     >   On Sun, Feb 16, 2020 at 2:35 AM G. S. Niteesh <
> >> > >     >> > Hii,
> >> > >     >> > This is a reminder message since this patch has been
> unnoticed
> >> > >     for a while.
> >> > >     >> > I have tested it on Raspberry Pi 3 and it works fine.
> There is
> >> > >     also another patch
> https://lists.rtems.org/pipermail/devel/2020-February/057194.html,
> >> > >     please
> >> > >     >> > do have a look at these.
> >> > >     >> > Thank you.
> >> > >     >> > Niteesh
> >> > >     >> > On Mon, Feb 10, 2020 at 12:52 AM G S Niteesh <
> >> > >     >> >> This patch adds driver for Mini UART present in Raspberry
> Pi 3
> >> > >     >> >> and above, this UART is currently used as the primary
> UART in
> >> > >     >> >> these models.
> >> > >     >> >> The Mini UART is similar to ns16550, this driver is built
> >> > >     >> >> upon libchip/ns16550.
> >> > >     >> >>  bsps/arm/raspberrypi/console/console-config.c | 118
> >> > >     >> >>  bsps/arm/raspberrypi/include/bsp/usart.h      |   1 +
> >> > >     >> >>  2 files changed, 110 insertions(+), 9 deletions(-)
> >> > >     >> >> diff --git a/bsps/arm/raspberrypi/console/console-config.c
> >> > >     b/bsps/arm/raspberrypi/console/console-config.c
> >> > >     >> >> index 48c4c6a3ec..62196786dd 100644
> >> > >     >> >> --- a/bsps/arm/raspberrypi/console/console-config.c
> >> > >     >> >> +++ b/bsps/arm/raspberrypi/console/console-config.c
> >> > >     >> >> @@ -24,6 +24,7 @@
> >> > >     >> >>  #include <libchip/serial.h>
> >> > >     >> >>  #include <libfdt.h>
> >> > >     >> >> +#include <libchip/ns16550.h>
> >> > >     >> >>  #include <bspopts.h>
> >> > >     >> >>  #include <bsp/usart.h>
> >> > >     >> >> @@ -34,35 +35,103 @@
> >> > >     >> >>  #include <bsp/console-termios.h>
> >> > >     >> >>  #include <bsp/fdt.h>
> >> > >     >> >>  #include <bsp/fatal.h>
> >> > >     >> >> +#include <bsp/gpio.h>
> >> > >     >> >> +#include <bsp/rpi-gpio.h>
> >> > >     >> >> -#define UART0     "/dev/ttyS0"
> >> > >     >> >> + * UART0 - PL011
> >> > >     >> >> + * UART1 - Mini UART
> >> > >     >> >> +#define PL011     "/dev/ttyAMA0"
> >> > >     >> >> +#define MINIUART  "/dev/ttyS0"
> >> > >     >> >>  #define FBCONS    "/dev/fbcons"
> >> > >     >> >>  arm_pl011_context pl011_context;
> >> > >     >> >> +ns16550_context mini_uart_context;
> >> > >     >> >>  rpi_fb_context fb_context;
> >> > >     >> >> -static void output_char_serial(char c)
> >> > >     >> >> +static void output_char_pl011(char c)
> >> > >     >> >>    arm_pl011_write_polled(&pl011_context.base, c);
> >> > >     >> >> +static void output_char_mini_uart(char c)
> >> > >     >> >> +  ns16550_polled_putchar(&mini_uart_context.base, c);
> >> > >     >> >>  void output_char_fb(char c)
> >> > >     >> >>    fbcons_write_polled(&fb_context.base, c);
> >> > >     >> >> +static uint8_t mini_uart_get_reg(uintptr_t port, uint8_t
> index)
> >> > >     >> >> +  volatile uint32_t *val = (volatile uint32_t *)port +
> index;
> >> > >     >> >> +  return (uint8_t) *val;
> >> > >     >> >> +static void mini_uart_set_reg(uintptr_t port, uint8_t
> index,
> >> > >     uint8_t val)
> >> > >     >> >> +  volatile uint32_t *reg = (volatile uint32_t *)port +
> index;
> >> > >     >> >> +  *reg = val;
> >> > >     >> >>  static void init_ctx_arm_pl011(
> >> > >     >> >>    const void *fdt,
> >> > >     >> >>    int node
> >> > >     >> >>    arm_pl011_context *ctx = &pl011_context;
> >> > >     >> >> -  rtems_termios_device_context_initialize(&ctx->base,
> "UART");
> >> > >     >> >> +  rtems_termios_device_context_initialize(&ctx->base,
> >> > >     "PL011UART");
> >> > >     >> >>    ctx->regs = raspberrypi_get_reg_of_node(fdt, node);
> >> > >     >> >> +static uint32_t calculate_baud_divisor(
> >> > >     >> >> +  ns16550_context *ctx,
> >> > >     >> >> +  uint32_t baud
> >> > >     >> >> +  uint32_t baudDivisor = (ctx->clock / (8 * baud)) - 1;
> >> > >     >> >> +  return baudDivisor;
> >> > >     >> >> +static void init_ctx_mini_uart(
> >> > >     >> >> +  const void *fdt,
> >> > >     >> >> +  int node
> >> > >     >> >> +  const char *status;
> >> > >     >> >> +  int len;
> >> > >     >> >> +  ns16550_context *ctx;
> >> > >     >> >> +  memset(&mini_uart_context, 0,
> sizeof(mini_uart_context));
> >> > >     >> >> +  ctx = &mini_uart_context;
> >> > >     "MiniUART");
> >> > >     >> >> +  status = fdt_getprop(fdt, node, "status", &len);
> >> > >     >> >> +  if ( status == NULL || strcmp(status, "disabled" ) ==
> 0){
> >> > >     >> >> +    return ;
> >> > >     >> >> +  ctx->port = (uintptr_t)
> >> > >     >> >> +  ctx->initial_baud = MINI_UART_DEFAULT_BAUD;
> >> > >     >> >> +  ctx->clock = BCM2835_CLOCK_FREQ;
> >> > >     >> >> +  ctx->calculate_baud_divisor = calculate_baud_divisor;
> >> > >     >> >> +  ctx->get_reg = mini_uart_get_reg;
> >> > >     >> >> +  ctx->set_reg = mini_uart_set_reg;
> >> > >     >> >> +  rtems_gpio_bsp_select_specific_io(0, 14,
> RPI_ALT_FUNC_5, NULL);
> >> > >     >> >> +  rtems_gpio_bsp_select_specific_io(0, 15,
> >> > >     >> >> +  rtems_gpio_bsp_set_resistor_mode(0, 14,
> NO_PULL_RESISTOR);
> >> > >     >> >> +  rtems_gpio_bsp_set_resistor_mode(0, 15,
> NO_PULL_RESISTOR);
> >> > >     >> >> +  BCM2835_REG(AUX_ENABLES) |= 0x1;
> >> > >     >> >> +  ns16550_probe(&ctx->base);
> >> > >     >> >>  static void register_fb( void )
> >> > >     >> >>    if (fbcons_probe(&fb_context.base) == true) {
> >> > >     >> >> @@ -87,16 +156,28 @@ static void console_select( void )
> >> > >     >> >>          link(FBCONS, CONSOLE_DEVICE_NAME);
> >> > >     >> >>          return ;
> >> > >     >> >> +    } else if ( strncmp( opt, MINIUART, sizeof(MINIUART)
> - 1
> >> > >     ) == 0) {
> >> > >     >> >> +      BSP_output_char = output_char_mini_uart;
> >> > >     >> >> +      link(MINIUART, CONSOLE_DEVICE_NAME);
> >> > >     >> >> +    } else if ( strncmp( opt, PL011, sizeof(PL011) - 1 )
> == 0) {
> >> > >     >> >> +      BSP_output_char = output_char_pl011;
> >> > >     >> >> +      link(PL011, CONSOLE_DEVICE_NAME);
> >> > >     >> >> +  }else {
> >> > >     >> >> +     * If no command line option was given, default to
> PL011.
> >> > >     >> >> -  BSP_output_char = output_char_serial;
> >> > >     >> >> -  link(UART0, CONSOLE_DEVICE_NAME);
> >> > >     >> >>  static void uart_probe(void)
> >> > >     >> >>    static bool initialized = false;
> >> > >     >> >>    const void *fdt;
> >> > >     >> >> +  const char *console;
> >> > >     >> >> +  int len;
> >> > >     >> >>    int node;
> >> > >     >> >>    if ( initialized ) {
> >> > >     >> >> @@ -104,17 +185,29 @@ static void uart_probe(void)
> >> > >     >> >>    fdt = bsp_fdt_get();
> >> > >     >> >> -  node = fdt_node_offset_by_compatible(fdt, -1,
> >> > >     "brcm,bcm2835-pl011");
> >> > >     >> >> +  node = fdt_node_offset_by_compatible(fdt, -1,
> >> > >     >> >>    init_ctx_arm_pl011(fdt, node);
> >> > >     "brcm,bcm2835-aux-uart");
> >> > >     >> >> +  init_ctx_mini_uart(fdt, node);
> >> > >     >> >> +  node = fdt_path_offset(fdt, "/aliases");
> >> > >     >> >> +  console = fdt_getprop(fdt, node, "serial0", &len);
> >> > >     >> >> +  if ( strcmp(console, "/soc/serial at 7e215040" ) == 0) {
> >> > >     >> >> +  }else {
> >> > >     >> >>    initialized = true;
> >> > >     >> >>  static void output_char(char c)
> >> > >     >> >>    uart_probe();
> >> > >     >> >> -  output_char_serial(c);
> >> > >     >> >> +  (*BSP_output_char)(c);
> >> > >     >> >>  rtems_status_code console_initialize(
> >> > >     >> >> @@ -127,12 +220,19 @@ rtems_status_code
> console_initialize(
> >> > >     >> >>    uart_probe();
> >> > >     >> >>    rtems_termios_device_install(
> >> > >     >> >> -    UART0,
> >> > >     >> >> +    PL011,
> >> > >     >> >>      &arm_pl011_fns,
> >> > >     >> >>      NULL,
> >> > >     >> >>      &pl011_context.base
> >> > >     >> >> +  rtems_termios_device_install(
> >> > >     >> >> +    MINIUART,
> >> > >     >> >> +    &ns16550_handler_polled,
> >> > >     >> >> +    NULL,
> >> > >     >> >> +    &mini_uart_context.base
> >> > >     >> >>    register_fb();
> >> > >     >> >>    console_select();
> >> > >     >> >> diff --git a/bsps/arm/raspberrypi/include/bsp/usart.h
> >> > >     b/bsps/arm/raspberrypi/include/bsp/usart.h
> >> > >     >> >> index abbf53626c..6af1844b3c 100644
> >> > >     >> >> --- a/bsps/arm/raspberrypi/include/bsp/usart.h
> >> > >     >> >> +++ b/bsps/arm/raspberrypi/include/bsp/usart.h
> >> > >     >> >> @@ -33,6 +33,7 @@ extern "C" {
> >> > >     >> >>  #endif /* __cplusplus */
> >> > >     >> >>  #define PL011_DEFAULT_BAUD 115000
> >> > >     >> >> +#define MINI_UART_DEFAULT_BAUD   115200
> >> > >     >> >>  #define BCM2835_PL011_BASE (RPI_PERIPHERAL_BASE +
> 0x201000)
> >> > >     >> >>  #ifdef __cplusplus
> >> > >     >> >> 2.17.1
> >> > >     >> > _______________________________________________
> >> > >     >> > devel mailing list
> >> > >     >> > devel at rtems.org <mailto:devel at rtems.org>
> >> > >     >> > http://lists.rtems.org/mailman/listinfo/devel
> >> > > devel mailing list
> >> > > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200216/b0ecf04f/attachment-0001.html>
