[PATCH] eng: Rework file template section
Wed Feb 19 07:07:40 UTC 2020
Update #3053.
 eng/coding-file-hdr.rst | 161 +++++++++++++++++++++++++++++++++++++++---------
 1 file changed, 131 insertions(+), 30 deletions(-)
diff --git a/eng/coding-file-hdr.rst b/eng/coding-file-hdr.rst
index c724c5d..788da95 100644
--- a/eng/coding-file-hdr.rst
+++ b/eng/coding-file-hdr.rst
@@ -1,45 +1,146 @@
 .. SPDX-License-Identifier: CC-BY-SA-4.0
-.. Copyright (C) 2018.
-.. COMMENT: RTEMS Foundation, The RTEMS Documentation Project
+.. Copyright (C) 2018, 2020 embedded brains GmbH
+.. Copyright (C) 2018, 2020 Sebastian Huber
-.. COMMENT:TBD - Convert the following to Rest and insert into this file
-.. COMMENT:TBD - https://devel.rtems.org/wiki/Developer/Coding/Boilerplate_File_Header
+File Templates
+Every file shall have a copyright and license comment block.  It should have a
+Doxygen file comment block.
-Boilerplate File Header
+The preferred licence for new source code is
+`BSD-2-Clause <https://spdx.org/licenses/BSD-2-Clause.html>`_:
-Every file should include two comment header blocks, one for the Doxygen
-output and a copyright notice.  This is a typical example:
+.. code-block:: none
+    Copyright (C) <FIRST YEAR>, <LAST YEAR> <COPYRIGHT HOLDER>
+    Redistribution and use in source and binary forms, with or without
+    modification, are permitted provided that the following conditions
+    are met:
+    1. Redistributions of source code must retain the above copyright
+       notice, this list of conditions and the following disclaimer.
+    2. Redistributions in binary form must reproduce the above copyright
+       notice, this list of conditions and the following disclaimer in the
+       documentation and/or other materials provided with the distribution.
+    THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+    AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+    IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+    ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+    LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+    CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+    SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+    INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+    CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+    ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+    POSSIBILITY OF SUCH DAMAGE.
+Copyright and License Comment Block
+You are the copyright holder.  Copy the comment below the top of the file in
+which you want to use this license for your contribution.  Replace the
+<FIRST YEAR> placeholder with the year of your first substantial contribution to
+this file.  Update the <LAST YEAR> with the year of your last substantial
+contribution to this file.  If the first and last years are the same, then
+remove the <LAST YEAR> placeholder with the comma.  Replace the
+<COPYRIGHT HOLDER> placeholder with your name.
+In case you are a real person, then use the following format for
+<COPYRIGHT HOLDER>: <FIRST NAME> <MIDDLE NAMES> <LAST NAME>.  The <FIRST NAME>
+is your first name (also known as given name), the <MIDDLE NAMES> are your
+optional middle names, the <LAST NAME> is your last name (also known as family
+name).
+If more than one copyright holder exists for a file, then sort the copyright
+lines by the first year (earlier years are below later years) followed by the
+copyright holder in alphabetical order (A is above B in the file).
+Use the following template for a copyright and license comment block.  Please
+note that there is no verbatim copy of the BSD-2-Clause license included.  The
+license is specified by the SPDX Licence Identifier.
+     * SPDX-License-Identifier: BSD-2-Clause
+     * Copyright (C) <FIRST YEAR>, <LAST YEAR> <COPYRIGHT HOLDER>
+Check if the top-level :file:`COPYING` file needs an update.
+Header File Template
+Use the following guidelines and template for header files (here
+:file:`<foo/bar/baz.h>`):
+* Place the copyright and license comment block to the top of the file.
+* Use exactly one blank line between the copyright and licence comment block and
+  the Doxygen comment block.
+* Separate the Doxygen comment block from the copyright and license, so that
+  the copyright and license information is not included in the Doxygen output.
+* For C++ header files discard the extern "C".
 .. code-block:: c
-   * @file
-   * @ingroup TheGroupForThisFile
-   * @brief Short "Table of Contents" Description of File Contents
-   * A short description of the purpose of this file.
+     * @file
+     * @ingroup TheGroupForThisFile
+     * @brief Short "Table of Contents" Description of File Contents
+     * A short description of the purpose of this file.
+    #ifndef _FOO_BAR_BAZ_H
+    #define _FOO_BAR_BAZ_H
+    #include <foo/bar/xyz.h>
-   * Copyright (c) 20XX Your Name Or Your Company.
-   * The license and distribution terms for this file may be
-   * found in the file LICENSE in this distribution or at
-   * https://www.rtems.org/license/LICENSE.
+    #ifdef __cplusplus
+    extern "C" {
+    #endif
+    /* Declarations, defines, macros, inline functions, etc. */
+    #endif
+    #endif /* _FOO_BAR_BAZ_H */
+Source File Template
+Use the following template for source files (here implementation of
+.. code-block:: c
-* Use exactly one blank line between the Doxygen header and copyright notice.
-  Leave the first line of the copyright notice blank.
-* Separate the Doxygen header and copyright notice so the copyright notice is
-  not included in the Doxygen output.
+    #if HAVE_CONFIG_H
+    #include "config.h"
+    #endif
-* The copyright owner and specific license terms may vary.
+    #include <foo/bar/baz.h>
-.. COMMENT: TBD - TBD Add link to license requirements section and show variant licenses.
+    /* Definitions, etc. */
2.16.4
