Project query
Thu Feb 20 01:28:48 UTC 2020
On Wed, Feb 19, 2020, 6:12 PM John Millard <jmillard at sprynet.com> wrote:
> Greetings:
> I took Joel’s week-long class in June.
:) Thanks. Hope you enjoyed it.
I’m currently retired and looking for a project, but clearly not a GSoC
> guy. The default list of tickets is mostly old or currently assigned.
Currently assigned may not mean as much as you think. It is often done by
someone to direct the ticket to who wrote the code. I know I often file
tickets where I have looked into who is most likely to fix it and assign it
to them.
For example, I need to file a ticket for breakages building rtems-examples
using waf. And when you build RTEMS using rtems6 tools, there are breakages
because rtems5 is not replaced with rtems6 is still in some places. I
reported both I think this week to devel.
The “open projects” page looks more relevant. I can buy hardware if
> somewhat reasonably priced. Having actual hardware would be somewhat
> preferred, even if qemu is amazing. I can do assembly (most familiar with
> Intel, but open to learning), low-level C down to the hardware, and have
> experience with OS level programming and drivers, serial and network
> transport, debuggers.
If that's the direction you want to go in, the x86_64 port and bsp are
incomplete. There should be plenty of room to get things working. This
would help ween us off of depending on legacy boot PCs.
> Is there some priority on the projects? They are all equal, but some are
> more equal than others. I can guess the scope on some of them.
For the most part, there isn't much priority. If you ask different people,
you will likely get different answers.
> Suggestions welcome.
> John
> —where there are tools, a will, and a will to build tools there is a way
> _________________________________
> devel mailing list
> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200219/0850b1be/attachment-0001.html>
