RTEMS-BSP testing
John kongtcheu johnkongtcheu at gmail.com
Sun Feb 23 15:52:51 UTC 2020
Hello again,
DIfferent problem though it's more minor. I was running the test files and
at the end of them I always got this message
*** FATAL ***
fatal source: 5 (RTEMS_FATAL_SOURCE_EXIT)
fatal code: 0 (0x00000000)
RTEMS version: 5.0.0.486829b2766119275f74e7a2a11d7bf3a9561f54
RTEMS tools: 7.5.0 20191114 (RTEMS 5, RSB 5 (22135c9a7612), Newlib
d14714c69)
executing thread ID: 0x08a010001
executing thread name: UI1
cpu 0 in error mode (tt = 0x101)
   113807  0200a080:  91d02000   ta  0x0
. Is this message normal, because I didn't see it in the other runs of this
program. I still get the expected output otherwise , just with this
appended.
For context the command run was ,
sparc-rtems5-sis ticker.exe
run
Thank you,
On Sun, Feb 23, 2020 at 4:47 AM John kongtcheu <johnkongtcheu at gmail.com>
wrote:
> Hello New Guy Here,
> I was going through the Gsoc getting started page and I got a bit stuck on
> the Test a Board Support Package section.I went through the steps provided
> prior to this. However, when I ran the command
> cd $HOME/quick-start/build/b-erc32
> rtems-test --rtems-bsp=erc32-sis --rtems-tools=$HOME/quick-start/rtems/5 .
> I received the message
> RTEMS Testing - Tester, 5.0.not_released
>  Command Line: /home/kingkong/Coding-Projects/rtems/5/bin/rtems-test --rtems-bsp=sis-run --rtems-tools=/home/kingkong/Coding-Projects/rtems/5
>  Host: Linux kingkong-ThinkPad-X390-Yoga 5.3.0-28-generic #30~18.04.1-Ubuntu SMP Fri Jan 17 06:14:09 UTC 2020 x86_64
>  Python: 3.6.9 (default, Nov  7 2019, 10:44:02) [GCC 8.3.0]
> Host: Linux-5.3.0-28-generic-x86_64-with-Ubuntu-18.04-bionic (Linux kingkong-ThinkPad-X390-Yoga 5.3.0-28-generic #30~18.04.1-Ubuntu SMP Fri Jan 17 06:14:09 UTC 2020 x86_64 x86_64)
> error: no executables supplied
> I looked online and the only similar error I ran across was someone who didn't run the make correctly , so I double checked running both make && make install and I still received the same error.
> I'm positive it has something to do with my development setup. If anyone could point me in the right direction regarding this it would be greatly appreciated.
> Thank you,
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200223/d76e0488/attachment.html>
