Ticket #3515: covoar failure while running for full testsuites
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Wed Feb 26 06:58:39 UTC 2020
On Fri, Feb 21, 2020 at 1:27 PM Bran S <archsbran at gmail.com> wrote:
> On Wed, 19 Feb 2020 at 22:51, Vijay Kumar Banerjee
> <vijaykumar9597 at gmail.com> wrote:
> > On Mon, Feb 17, 2020 at 12:08 AM Bran S <archsbran at gmail.com> wrote:
> >> Hi Guys,
> > Hi Bran!
> >> I am trying to understand and solve Ticket #3515.
> >> https://devel.rtems.org/ticket/3515
> >> $ /home/user45/quick-start/rtems/5/share/rtems/tester/bin/covoar -vvvv
> >> -S
> /home/user45/quick-start/rtems/5/share/rtems/tester/rtems/testing/coverage/leon3-sis-symbols.ini
> >> -O leon3-sis-coverage -E
> /home/user45/quick-start/rtems/5/share/rtems/tester/rtems/testing/coverage/Explanations.txt
> >> -p RTEMS-5
> /home/user45/quick-start/build/b-leon3/sparc-rtems5/c/leon3/testsuites/fstests/fsclose01.exe
> >> The output of the above command is at:
> >> https://gist.github.com/archsbran/7834a931d52311c7b26842c6325d8d9a
> >> On the last line it can be seen that absence of `wait` symbol causes
> the error.
> >> I made some changes in ExecutableInfo.cc to print out the symbols
> >> being added into coverageMap.
> >> Added symbols can be seen from line 636 to 7236 at the above link.
> >> In those lines we can see that `wait` is not added into coverageMap.
> > Great work in finding the possible issue.
> >> I am new so the only thing I know about covoar is that it does
> >> coverage analysis.
> >> Any ideas on how to move further into solving this ?
> > I added Chris in CC, he'll be able to tell us where to look for the
> source
> > of the error you found.
> > In general, you can follow covoar.cc file, which has the main `covoar`
> > function in it. That will be a good starting point.
> Yeah, I traversed through the code in covoar.cc
> It goes something like:
> In covoar.cc: covar()
> at line 382: objdumpProcessor->load( exe, objdumpFile, err );
> Here, `exe` points to the executableinfo object, the one in which the
> coverageMap was created via createCoverageMap()
> Now inside objdumpProcessor->load()
> at line 301: finalizeSymbol() is called which further calls
> findCoverageMap() at line 35. This is the point where error occurs, as
> `wait` symbol is not found.
> Hi Bran,
Sorry, I couldn't find time to look into the details and I was hoping
someone
else will join in. You are in the right direction and found the function
that is
getting the error. Now that you have a function to follow, I will suggest
you to
run gdb on covoar and follow this function, especially where it's getting
the
symbols.
To run covoar on gdb do the following:
$gdb /path/to/covoar
(gdb) r -vvvv -S
/home/lunatic/development/rtems/rtems-tools/tester/rtems/testing/coverage/leon3-qemu-symbols.ini
-O leon3-qemu-coverage \
-E
/home/lunatic/development/rtems/rtems-tools/tester/rtems/testing/coverage/Explanations.txt
-p RTEMS-5 /your/exe.exe
set a breakpoint at findCoverageMap() and see what it is doing.
Most likely, you'll be able to see where is it getting other symbols
from and why is "wait" not there, or if it's there, why is it skipping it.
Best regards,
Vijay
> The objdumpProcessor->load() function searches symbols in
> CoverageMap(via finalizeSymbol()) according to the symbols present in
> objdump generated at
> line 291: getFile( executableInformation->getFileName(), objdumpFile, err
> The objdump is created using the executableinfo from which we loaded
> the symbols into CoverageMap, right ?
> Then is it so that the code missed out on the symbol while adding them
> into CoverageMap ?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200226/6de3db06/attachment.html>
