[PATCH 02/27] libfdt: Don't use memcpy to handle unaligned reads on ARM
Fri Feb 28 06:51:19 UTC 2020
From: David Gibson <david at gibson.dropbear.id.au>
6dcb8ba4 "libfdt: Add helpers for accessing unaligned words" introduced
the fdt32_ld() and fdt64_ld() helpers for loading values from the FDT blob
which might not be naturally aligned.  This matters for ARM, where
attempting a plain unaligned load will often cause an exception.
However, it seems the memcpy() we used here was surprisingly expensive,
making libfdt nearly 6x slower on at least some ARM platforms.
This patch takes an alternative approach, using a bunch of 1-byte loads
and shifts to implement the helpers.
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
 cpukit/include/libfdt.h | 22 +++++++++++++++-------
 1 file changed, 15 insertions(+), 7 deletions(-)
diff --git a/cpukit/include/libfdt.h b/cpukit/include/libfdt.h
index face02c102..fdaa3e6f39 100644
--- a/cpukit/include/libfdt.h
+++ b/cpukit/include/libfdt.h
@@ -163,18 +163,26 @@ uint32_t fdt_next_tag(const void *fdt, int offset, int *nextoffset);
 static inline uint32_t fdt32_ld(const fdt32_t *p)
-	fdt32_t v;
+	const uint8_t *bp = (const uint8_t *)p;
-	memcpy(&v, p, sizeof(v));
-	return fdt32_to_cpu(v);
+	return ((uint32_t)bp[0] << 24)
+		| ((uint32_t)bp[1] << 16)
+		| ((uint32_t)bp[2] << 8)
+		| bp[3];
 static inline uint64_t fdt64_ld(const fdt64_t *p)
-	fdt64_t v;
-	return fdt64_to_cpu(v);
+	return ((uint64_t)bp[0] << 56)
+		| ((uint64_t)bp[1] << 48)
+		| ((uint64_t)bp[2] << 40)
+		| ((uint64_t)bp[3] << 32)
+		| ((uint64_t)bp[4] << 24)
+		| ((uint64_t)bp[5] << 16)
+		| ((uint64_t)bp[6] << 8)
+		| bp[7];
2.16.4
