[PATCH] user: Add a link for the setup of frdme310arty BSP
Pragnesh Patel pragnesh.patel at sifive.com
Fri Jan 3 09:22:34 UTC 2020
>-----Original Message-----
>From: Gedare Bloom <gedare at rtems.org>
>Sent: 02 January 2020 21:28
>To: Sebastian Huber <sebastian.huber at embedded-brains.de>
>Cc: devel at rtems.org; Pragnesh Patel <pragnesh.patel at sifive.com>
>Subject: Re: [PATCH] user: Add a link for the setup of frdme310arty BSP
>On Wed, Jan 1, 2020 at 11:21 PM Sebastian Huber
><sebastian.huber at embedded-brains.de> wrote:
>> >> From: Pragnesh Patel<pragnesh.patel at sifive.com>
>> >> Sent: 29 November 2019 19:14
>> >> To:Sebastian.Huber at embedded-brains.de
>> >> Cc:devel at rtems.org; Pragnesh Patel<pragnesh.patel at sifive.com>
>> >> Subject: [PATCH] user: Add a link for the setup of frdme310arty BSP
>> >> Signed-off-by: Pragnesh Patel<pragnesh.patel at sifive.com>
>> >> user/bsps/bsps-riscv.rst | 3 +++
>> >> 1 file changed, 3 insertions(+)
>> >> diff --git a/user/bsps/bsps-riscv.rst b/user/bsps/bsps-riscv.rst
>> >> index
>> >> 0799ad6..40d7606 100644
>> >> --- a/user/bsps/bsps-riscv.rst
>> >> +++ b/user/bsps/bsps-riscv.rst
>> >> @@ -93,6 +93,9 @@ The following options are available at the
>> >> configure command line.
>> >>       Enables support sifive Freedom E310 Arty board if defined to a non-
>zero
>> >>       value,otherwise it is disabled (disabled by default)
>> >> +     Please seehttps://github.com/pragnesh26992/rtems  and follow
>> >> +     README-frdme310arty.md
>> > Any update on this patch ?
>> It would be nice if most of the content of
>> https://github.com/pragnesh26992/rtems/blob/master/README-
>frdme310arty
>> .md
>> could move to the User Manual.
>> In general, this repository gives rise to an RTEMS Project question.
>> Should it provide BIT files, device tree files, debugger configuration
>> files, etc. to set up a target (evaluation board)? If yes, where?
>> Maybe rtems-docs?
>These things are certainly useful. Putting them in 'docs' is misleading though.
>rtems-tools or a new high-level repo might be a better fit. It should be
>discussed separately from the issue of this patch.
I agreed with @Gedare Bloom.
Right now, this repo "https://github.com/pragnesh26992/rtems/" will provide a BIT file,
device tree files, OpenOCD config file, a bootloader, cfg and ini files, .gdbinit file.
We can discuss this separately if needed.
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> devel mailing list
>> devel at rtems.org
