[PATCH] Updated docs to use the standalone SIS simulator, instead of GDB inbuilt SIS for the erc32 BSP.
Christian Mauderer list at c-mauderer.de
Sat Jan 4 19:29:57 UTC 2020
Gedare acknowledged it so I'll push it together with the other RTEMS
patches in a few days.
On 04/01/2020 08:18, Niteesh wrote:
> Just a reminder, it's almost been a week since I sent the patch. I also
> sent it a month ago, but it slipped from everyone's eyes.
> On Thu, Jan 2, 2020 at 9:45 PM Gedare Bloom <gedare at rtems.org
> <mailto:gedare at rtems.org>> wrote:
>     looks good to me.
>     On Fri, Dec 27, 2019 at 5:02 AM G S Niteesh <gsnb.gn at gmail.com
>     <mailto:gsnb.gn at gmail.com>> wrote:
>     >  user/start/bsp-test.rst |   4 +-
>     >  user/tools/tester.rst   | 144
>     >  2 files changed, 132 insertions(+), 16 deletions(-)
>     > diff --git a/user/start/bsp-test.rst b/user/start/bsp-test.rst
>     > index 5278375..aefeeb9 100644
>     > --- a/user/start/bsp-test.rst
>     > +++ b/user/start/bsp-test.rst
>     > @@ -21,7 +21,7 @@ Just run this command:
>     >  .. code-block:: none
>     >      cd $HOME/quick-start/build/b-erc32
>     > -    rtems-test --rtems-bsp=erc32
>     --rtems-tools=$HOME/quick-start/rtems/5 .
>     > +    rtems-test --rtems-bsp=erc32-sis
>     >  This command should output something like this (omitted lines are
>     denoted by
>     >  ...).  In this output the base directory
>     :file:`$HOME/quick-start` was replaced
>     > @@ -30,7 +30,7 @@ by ``$BASE``.
>     >      RTEMS Testing - Tester, 5.0.not_released
>     > -     Command Line: $BASE/rtems/5/bin/rtems-test --rtems-bsp=erc32
>     --rtems-tools=$BASE/rtems/5 .
>     > +     Command Line: $BASE/rtems/5/bin/rtems-test
>     --rtems-bsp=erc32-sis --rtems-tools=$BASE/rtems/5 .
>     >       Python: 2.7.15 (default, Jan 10 2019, 01:14:47) [GCC 4.2.1
>     Compatible FreeBSD Clang 6.0.1 (tags/RELEASE_601/final 335540)]
>     >      Host: FreeBSD-12.0-RELEASE-p2-amd64-64bit-ELF (FreeBSD
>     Build_FreeBSD12 12.0-RELEASE-p2 FreeBSD 12.0-RELEASE-p2 GENERIC
>     amd64 amd64)
>     >      [  1/589] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0
>      W:0   | sparc/erc32: dhrystone.exe
>     > diff --git a/user/tools/tester.rst b/user/tools/tester.rst
>     > index 609384b..c3c3fe2 100644
>     > --- a/user/tools/tester.rst
>     > +++ b/user/tools/tester.rst
>     > @@ -109,39 +109,155 @@ the tests. Using the run with the ERC32 BSP
>     the command is:
>     >  The run command is the GDB simulator without the GDB part.
>     > -Running the example using GDB:
>     > +Running the example using SIS:
>     > +.. code-block:: none
>     > +    $ sparc-rtems5-sis
>     sparc-rtems5/c/erc32/testsuites/samples/hello/hello.exe
>     > +    SIS - SPARC/RISCV instruction simulator 2.20,  copyright Jiri
>     Gaisler 2019
>     > +    Bug-reports to jiri at gaisler.se <mailto:jiri at gaisler.se>
>     > +    ERC32 emulation enabled
>     > +    Loaded sparc-rtems5/c/erc32/testsuites/samples/hello.exe,
>     entry 0x02000000
>     > +    sis> run
>     > +    *** BEGIN OF TEST HELLO WORLD ***
>     > +    *** TEST VERSION: 5.0.0.c6d8589bb00a9d2a5a094c68c90290df1dc44807
>     > +    *** TEST STATE: EXPECTED-PASS
>     > +    *** TEST BUILD: RTEMS_POSIX_API
>     > +    *** TEST TOOLS: 7.5.0 20191114 (RTEMS 5, RSB
>     83fa79314dd87c0a8c78fd642b2cea3138be8dd6, Newlib 3e24fbf6f)
>     > +    Hello World
>     > +    *** END OF TEST HELLO WORLD ***
>     > +    *** FATAL ***
>     > +    fatal source: 0 (INTERNAL_ERROR_CORE)
>     > +    fatal code: 5 (INTERNAL_ERROR_THREAD_EXITTED)
>     > +    RTEMS version: 5.0.0.c6d8589bb00a9d2a5a094c68c90290df1dc44807
>     > +    RTEMS tools: 7.5.0 20191114 (RTEMS 5, RSB
>     > +    executing thread ID: 0x08a010001
>     > +    executing thread name: UI1
>     > +    cpu 0 in error mode (tt = 0x101)
>     > +        116401  02009ae0:  91d02000   ta  0x0
>     > +    sis> q
>     > +The examples can also be run using GDB with SIS as the backend.
>     SIS can be connected to
>     > +gdb through a network socket using the gdb remote interface.
>     > +Either start SIS with ``-gdb``, or issue the ``gdb`` command
>     inside SIS, and connect
>     > +gdb with ``target remote:1234``. The default port is ``1234``,
>     the port can be changed
>     > +using the ``-port`` option.
>     > +Open a terminal and issue the command:
>     > +    $ sparc-rtems5-sis -gdb
>     Gaisler 2019
>     > +    gdb: listening on port 1234
>     > +Now open another terminal and issue the command:
>     >      $ sparc-rtems5-gdb
>     > -    GNU gdb (GDB) 7.12
>     > -    Copyright (C) 2016 Free Software Foundation, Inc.
>     > +    GNU gdb (GDB) 8.3
>     > +    Copyright (C) 2019 Free Software Foundation, Inc.
>     >      License GPLv3+: GNU GPL version 3 or later
>     <http://gnu.org/licenses/gpl.html>
>     >      This is free software: you are free to change and
>     redistribute it.
>     > -    There is NO WARRANTY, to the extent permitted by law.  Type
>     "show copying"
>     > -    and "show warranty" for details.
>     > +    There is NO WARRANTY, to the extent permitted by law.
>     > +    Type "show copying" and "show warranty" for details.
>     >      This GDB was configured as "--host=x86_64-linux-gnu
>     --target=sparc-rtems5".
>     >      Type "show configuration" for configuration details.
>     >      For bug reporting instructions, please see:
>     >      <http://www.gnu.org/software/gdb/bugs/>.
>     >      Find the GDB manual and other documentation resources online at:
>     > -    <http://www.gnu.org/software/gdb/documentation/>.
>     > +        <http://www.gnu.org/software/gdb/documentation/>.
>     >      For help, type "help".
>     >      Type "apropos word" to search for commands related to "word"...
>     > -    Reading symbols from
>     > -    sparc-rtems5/c/erc32/testsuites/samples/hello/hello.exe...done.
>     > -    (gdb) target sim
>     > -    Connected to the simulator.
>     > +    Reading symbols from
>     sparc-rtems5/c/erc32/testsuites/samples/hello.exe...
>     > +    (gdb) target remote:1234
>     > +The ``target remote:1234`` will tell gdb to connect to the sis
>     simulator. After this
>     > +command the output of the first terminal will change to
>     Gaisler 2019
>     > +    gdb: listening on port 1234 connected
>     > +Before running the executable, it must be loaded, this is done
>     using the
>     > +``load`` command in gdb, and to run, issue ``continue`` command.
>     > +    $ sparc-rtems5-gdb
>     > +    GNU gdb (GDB) 8.3
>     > +    License GPLv3+: GNU GPL version 3 or later
>     > +    This is free software: you are free to change and
>     redistribute it.
>     > +    This GDB was configured as "--host=x86_64-linux-gnu
>     > +    Type "show configuration" for configuration details.
>     > +    For bug reporting instructions, please see:
>     > +    <http://www.gnu.org/software/gdb/bugs/>.
>     > +    Find the GDB manual and other documentation resources online at:
>     > +    For help, type "help".
>     > +    Type "apropos word" to search for commands related to "word"...
>     > +    Remote debugging using :1234
>     > +    0x00000000 in ?? ()
>     >      (gdb) load
>     > -    (gdb) r
>     > -    Starting program:
>     > +    Loading section .text, size 0x17170 lma 0x2000000
>     > +    Loading section .rtemsroset, size 0x40 lma 0x2017170
>     > +    Loading section .data, size 0x600 lma 0x20181c0
>     > +    Start address 0x2000000, load size 96176
>     > +    Transfer rate: 4696 KB/sec, 270 bytes/write.
>     > +    (gdb) continue
>     > +    Continuing.
>     > +You can see your executable running in the first terminal.
>     Gaisler 2019
>     > +    gdb: listening on port 1235 connected
>     > +    X2000000,0:#40
>     >      Hello World
>     > -    [Inferior 1 (process 42000) exited normally]
>     > -    (gdb) q
>     > +    ^Csis> q
>     > +For more information on the sis simulator refer to this doc:
>     https://gaisler.se/sis/sis.pdf
>     >  The command ``r`` is used to debug set break points before
>     issuing the GDB
>     >  ``run`` command.
>     > 2.17.1
>     > _______________________________________________
>     > devel mailing list
>     > devel at rtems.org <mailto:devel at rtems.org>
>     > http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
