Error while building the rtems-libbsd
Utkarsh Rai utkarsh.rai60 at gmail.com
Sun Jan 5 02:17:02 UTC 2020
1. For the libbbsd I have been using
https://github.com/nilhoel1/rtems-libbsd/tree/ti_pruss, this was used by @Nils
Hölscher <nilhoel1 at gmail.com> for his GSoc project( I have talked to him
about my errors, and this libbsd builds fine on his host system).
2. The rtems and RSB versions are https://github.com/RTEMS/rtems.git  and
https://github.com/RTEMS/rtems-source-builder.git
3. I have been using the beaglebone black BSP.
On Fri, Jan 3, 2020 at 2:12 PM Christian Mauderer <list at c-mauderer.de>
wrote:
> On 01/01/2020 16:14, Utkarsh Rai wrote:
> > I have been successful in building the rtems-libbsd using 'python3
> > ./waf'. Although, I had to do some weird changes to some of the files in
> > the libbsd package. (These changes were done as there were several build
> > errors even after the 'python ./waf' command )
> > 1. In the  ../freebsd/sys/netinet/in_mcast.c
> > and ../../freebsd/sys/netpfil/pf/if_pfsync.c files I had to change
> > the IP_MIN_MEMBERSHIPS with IP_MAX_MEMBERSHIPS .
> > 2. In the ../../freebsd/sys/netinet6/in6_mcast.c  and
> > .../freebsd/sys/netinet/ip_carp.c files I had to
> > change  IPV6_MIN_MEMBERSHIPS, to IPV6_MAX_MEMBERSHIPS,
> > 3. In the ../testsuite/syscalls01/test_main.c I changed the IPPROTO_SEP
> > to IPPROTO_EGP .
> > Now, I suspect that these changes will come back to bite me as I proceed
> > further as I have simply overwritten them based on build error
> > messages.  It would be helpful if the community can provide its views on
> > my changes and whether this is a bug or something that I am doing wrong.
> I would too expect that these changes are not a good idea. In normal
> case libbsd builds without any trouble.
> Can you give some more information about the exact versions you use:
> - Which commit of libbsd are you trying to build?
> - Which rtems commit do you use?
> - Which tool version do you use? If RSB: Which commit?
> - What BSP do you use?
> Best regards
> Christian
> > On Tue, Dec 31, 2019 at 6:28 PM Christian Mauderer <list at c-mauderer.de
> > <mailto:list at c-mauderer.de>> wrote:
> >     On 31/12/2019 12:41, Utkarsh Rai wrote:
> >     > My host system has an x-86_64  architecture with ubuntu-18.04
> >     running on
> >     > top of it, I have a python2 installed.
> >     > Interestingly enough, when I clean up the libbsd directory and try
> to
> >     > build as a super-user, I have two observations:-
> >     Please note that building as super user is generally not a good idea
> for
> >     any sane build environment. Although I have to say that in this case
> it
> >     provided an interesting error output ...
> >     > 1. The build fails with the following error message:-
> >     > [1/4] Creating
>  ///h/o/m/e///u/r/1/0///s/a/n/d/b/o/x///r/t/e/m/s/-/l/i/b/b/s/d///b/u/i/l/d///a/r/m/-/r/t/e/m/s/5/-/b/e/a/g/l/e/b/o/n/e/b/l/a/c/k/-/d/e/f/a/u/l/t/build-include/rtems/bsd/modules.h
> >     ... here. That looks like some join went horrible wrong. I assume
> that
> >     there is some location in the build system where an array of paths
> >     should be joined but only one is given. Looks like a bug.
> >     > [2/4] Compiling rtemsbsd/rtems/generate_kvm_symbols
> >     > [3/4] Compiling
> >     testsuite/include/rtems/bsd/test/network-config.h.in
> >     <http://network-config.h.in>
> >     > /bin/sh: 1:
> .//home/ur10/sandbox/rtems-libbsd/rtemsbsd/rtems/generate_kvm_symbols:
> >     The ./ in front is a bit odd here. Looks like an absolute path which
> >     (for some reason) has been forced to be local...
> >     > not found
> >     > Now I have checked, and the file in question is present at its
> >     location.
> >     > 2. The traceback of the last calls is something like this:-
> >     >   File
>  "/home/ur10/sandbox/rtems-libbsd/.waf-2.0.13-4c5a17779813574907c253ab5418388d/waflib/Build.py",
> >     > line 100, in execute_build
> >     >     self.compile()
> >     >   File
> >     > line 174, in compile
> >     >     self.store()
> >     >   File
> >     > line 153, in store
> >     >     Utils.writef(db+'.tmp',x,m='wb')
> >     >   File
>  "/home/ur10/sandbox/rtems-libbsd/.waf-2.0.13-4c5a17779813574907c253ab5418388d/waflib/Utils.py",
> >     > line 155, in writef
> >     >     with open(fname,m)as f:
> >     > IOError: [Errno 2] No such file or directory:
>  u'/home/ur10/sandbox/rtems-libbsd/build/arm-rtems5-beagleboneblack-default/.wafpickle-linux2-34017264-20.tmp'
> >     > If I am correct,  this is a python exception for invalid file
> >     handling.
> >     > Since I have already removed the  'build'  directory, I suppose
> >     the call
> >     > should be 'w+' or 'wb+' but this does not seem to be the case. (I
> am
> >     > going out on a limb with this assumption, I may be wrong !)
> >     You are right that it's a python exception. Most likely it's a
> follow up
> >     bug due to the wrong paths further up.
> >     > It would be very helpful if you could provide your views on the
> >     problem
> >     > and as to how I should proceed to resolve this.
> >     The solution is to find the bug in the path handling from further
> above.
> >     As a workaround could you try to use python3? Some string handling is
> >     different there so it might work or give a better error message.
> >     Just use
> >       python3 ./waf ...
> >     instead of only "waf" in every waf command line.
> >     > On Mon, Dec 30, 2019 at 7:19 PM Christian Mauderer
> >     <list at c-mauderer.de <mailto:list at c-mauderer.de>
> >     > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
> >     >     On 28/12/2019 18:43, Utkarsh Rai wrote:
> >     >     > Hi,
> >     >     > While building the rtems-libbsd as described here
> https://devel.rtems.org/browser/rtems-libbsd/README.waf?rev=b83012a9f9f1551d9d223c3126d0f43aba79db62
> > I
> >     >     > was able to successfully configure the waf file as:-
> >     >     > waf configure
> >     >     > --prefix="/home/ur10/sandbox/rtems/5"
> >     >     > --rtems-bsps=arm/beagleboneblack
> >     >     > --buildset=buildset/default.ini
> >     >     > But the build fails on the "waf" instruction with the error
> >     -  "Could
> >     >     > not create the directory ///h".
> >     >     > My path for the build is  PATH="~/sandbox/rtems/bin:$PATH",
> >     with the
> >     >     > tools and the rtems-libbsd in the sandbox directory.
> >     >     > It would be very kind of you if someone could point out as
> >     to what
> >     >     is it
> >     >     > Thank You, Regards.
> >     >     Hello Utkarsh Rai,
> >     >     I now have seen that bug about two or three times on the list.
> >     But I've
> >     >     never been able to reproduce it. What host system are you
> >     using? Do you
> >     >     have a python2 or a python3 as default python?
> >     >     Sometimes it works to clean up the libbsd directory. Remove
> >     the "build"
> >     >     directory and the ".waf2..." or ".waf3..." directory. Also
> >     remove any
> >     >     "__pycache__" directories.
> >     >     >From your call it seems that you use waf from your host
> >     system. Can you
> >     >     try to use the waf version delivered with libbsd instead
> >     (using "./waf
> >     >     configure ...")?
> >     >     Best regards
> >     >     Christian
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200105/397db3d3/attachment.html>
