Raspberrypi3: AUX Uart driver
Christian Mauderer christian.mauderer at embedded-brains.de
Wed Jan 15 11:44:50 UTC 2020
On 15/01/2020 12:13, Niteesh wrote:
> Thank you, it works now :)
> I have tested in on a real rpi3 and on rpi2 using QEMU, it works on both
> of them.
> Shall I send it as two patches, because the first one adds the facility
> to pass
> user define functions to calculate baud divisor and the 2nd is the
> driver patch?
Yes that sounds like two patches.
> On Wed, Jan 15, 2020 at 1:25 PM Christian Mauderer
> <christian.mauderer at embedded-brains.de
> <mailto:christian.mauderer at embedded-brains.de>> wrote:
>     On 15/01/2020 06:27, Niteesh wrote:
>     > I commented out all FDT queries and everything works using ns16550
>     driver.
>     > How do I load FDT blob using uboot, I tried using the default
>     > bootloader, but
>     > it doesn't work. I tried the following command but they don't work
>     > fatload mmc 0 0x200000 kernel7.img
>     > fatload mmc 0 0x1000 bcm2710-rpi-3-b.dtb
>     > fdt addr 0x1000
>     > fdt boardsetup
>     > go 0x200080
>     Instead of "go 0x200080" try it with bootm with the syntax for linux:
>     https://www.denx.de/wiki/view/DULG/UBootCmdGroupExec#Section_5.9.4.2.
>     With the commands you used it should be a
>        bootm 0x200000 - 0x1000
>     Best regards
>     Christian
>     > On Tue, Jan 14, 2020 at 9:40 PM Niteesh <gsnb.gn at gmail.com
>     <mailto:gsnb.gn at gmail.com>
>     > <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>>> wrote:
>     >     I am finished with code, I tested it in QEMU emulator raspi2but it
>     >     doesn't work
>     >     when testing on real rpi3. I don't know if the problem is with
>     >     loading the FDT
>     >     or with my code?
>     >     How do I send the code, so that you can take a look at it?
>     >     On Tue, Jan 14, 2020 at 8:04 PM Niteesh <gsnb.gn at gmail.com
>     >         On Tue, Jan 14, 2020 at 1:57 PM Christian Mauderer
>     <mailto:christian.mauderer at embedded-brains.de>>> wrote:
>     >             On 13/01/2020 19:04, Niteesh wrote:
>     >             > The ns16550_context already has a field named
>     >             baud_divisor, so if the
>     >             > user passes
>     >             > value for it, then we can skip the GetBaudDivisor
>     function
>     >             and use that
>     >             > value instead.
>     >             > Is this approach okay?
>     >             Is the driver still able to handle different baud
>     rates with
>     >             this? Does
>     >             the ioctl call for setting the baudrate work?
>     >         I didn't think about this, it won't work if we are using this
>     >         method. ns16550_set_attributes
>     >         calls ns16550_GetBaudDivisor, then I think we will have to
>     stick
>     >         with the old method.
>     >             Best regards
>     >             Christian
>     >             > On Mon, Jan 13, 2020 at 3:46 PM Niteesh
>     <gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>
>     >             > <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>
>     <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>>>> wrote:
>     >             >     On Mon, Jan 13, 2020 at 1:38 PM Christian Mauderer
>     >             >     <christian.mauderer at embedded-brains.de
>     >             >     <mailto:christian.mauderer at embedded-brains.de
>     <mailto:christian.mauderer at embedded-brains.de>>>> wrote:
>     >             >         On 12/01/2020 21:26, Niteesh wrote:
>     >             >         > On Sun, Jan 12, 2020 at 11:42 PM Christian
>     Mauderer
>     >             >         <list at c-mauderer.de
>     <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de>>
>     >             <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>
>     >             >         > <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de>> <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de>>>>> wrote:
>     >             >         >     Hello Niteesh,
>     >             >         >     On 12/01/2020 16:06, Niteesh wrote:
>     >             >         >     > The only issue, I faced while using this
>     >             driver is the
>     >             >         baud divisor is
>     >             >         >     > calculated
>     >             >         >     > by CLOCK_FREQ/(BAUD_RATE * 16)
>     >             (*ns16550-context.c:68)*
>     >             >         >     > but it should BAUD_DIV =
>     (CLOCK_FREQ/(8 *
>     >             BAUD_RATE)) -
>     >             >         1, for Rpi3.
>     >             >         >     > For testing, I assigned the baud divisor
>     >             to 270 (115200
>     >             >         bits/s) in
>     >             >         >     > ns16550-context.c,
>     >             >         >     > and everything works fine.
>     >             >         >     Sounds great. In NS16550_GetBaudDivisor
>     >             there is already a
>     >             >         case where
>     >             >         >     the baudDivisor is calculated differently
>     >             (depending on
>     >             >         >     ctx->has_precision_clock_synthesizer and
>     >             >         >     ctx->has_fractional_divider_register). If
>     >             none of the two
>     >             >         cases are ok
>     >             >         >     for the controller you could just add
>     >             another one.
>     >             >         > Can we pass in a function, which gets called,
>     >             won't this be more
>     >             >         > flexible? because
>     >             >         > in the future if we have some other board that
>     >             has a different
>     >             >         > calculation for the baud rate
>     >             >         > the function will take care of it.
>     >             >         It's possible. Please make sure to be compatible
>     >             with the
>     >             >         current API.
>     >             >         For example if the pointer is NULL you
>     should call
>     >             the legacy
>     >             >         function
>     >             >         instead.
>     >             >     I will be adding an extra field, a function
>     pointer to
>     >             ns16550_context,
>     >             >     the prototype of the function would be *uint32_t
>     >             >     calculate_baud_divisor( ns16550_context * )*
>     >             >     This is will calculate the baud divisor using
>     its own
>     >             formula and
>     >             >     the initial baud.
>     >             >     If this function is not NULL then it would be called
>     >             inside
>     >             >     *NS16550_GetBaudDivisor* function,
>     >             >         >     > For console selection, my plan is to
>     >             search for the aux
>     >             >         node using
>     >             >         >     > compatible
>     >             >         >     > property and if its status is enabled,
>     >             then initialize
>     >             >         the AUX
>     >             >         >     uart and
>     >             >         >     > set the BSP_output_char
>     >             >         >     > to aux_output_char, else
>     >             pl011_output_char. All this
>     >             >         will be done
>     >             >         >     inside
>     >             >         >     > the uart_probe function,
>     >             >         >     > except for the initialization of AUX
>     which
>     >             will be done in
>     >             >         >     init_ctx_aux.
>     >             >         >     > And finally, call the output char
>     >             >         >     > function using *BSP_output_char. Do you
>     >             have any neat
>     >             >         way to do this?
>     >             >         >     I don't have an example for a similar case
>     >             at hand. So:
>     >             >         No, no neat way
>     >             >         >     that I can tell you.
>     >             >         >     Before you start to write code: Please
>     take
>     >             a look at the
>     >             >         different
>     >             >         >     beagle variants what is possible. Is
>     there a
>     >             variant where
>     >             >         AUX uart
>     >             >         >     would be there but shouldn't be used as a
>     >             console (one of
>     >             >         the Zeros
>     >             >         >     maybe or the compute module?). How does
>     >             Raspbian or
>     >             >         FreeBSD decide which
>     >             >         >     port should be used? Maybe they decide
>     based
>     >             on the
>     >             >         commandline.txt? In
>     >             >         >     such a case it would be better to just
>     >             initialize all
>     >             >         active (in the
>     >             >         >     fdt) serial ports and decide based on the
>     >             commandline too.
>     >             >         > The Documentation says the following:
>     >             >         > *By default, on Raspberry Pis equipped
>     with the
>     >             >         wireless/Bluetooth*
>     >             >         > *module (Raspberry Pi 3 and Raspberry Pi Zero
>     >             W), **the PL011
>     >             >         UART is*
>     >             >         > *connected to the Bluetooth module, while the
>     >             mini UART is
>     >             >         used as the
>     >             >         > primary UART and*
>     >             >         > *will have a Linux console on it. On all other
>     >             models, the
>     >             >         PL011 is used
>     >             >         > as the primary UART.
>     >             >         > *In Linux device terms, by default, /dev/ttyS0
>     >             refers to the
>     >             >         mini UART,
>     >             >         > and /dev/ttyAMA0 refers*
>     >             >         > *to the PL011. The primary UART is the one
>     >             assigned to the Linux
>     >             >         > console, which depends on*
>     >             >         > *the Raspberry Pi model as described above.
>     >             There are also
>     >             >         symlinks:
>     >             >         > /dev/serial0, which always*
>     >             >         > *refers to the primary UART (if enabled), and
>     >             /dev/serial1, which
>     >             >         > similarly always refers to the secondary UART
>     >             (if enabled).*
>     >             >         > I checked in all the DTB files, by decompiling
>     >             them (files are
>      from https://github.com/raspberrypi/firmware/tree/master/boot).
>     >             >         > In all board with support for wireless and
>     >             bluetooth, the AuX
>     >             >         is enabled
>     >             >         > and serial0 points to it. So we could use
>     serial0
>     >             >         > to find the correct UART port. I think this is
>     >             solid enough.
>     >             >         So, should
>     >             >         > I use this approach?
>     >             >         Sounds OK. If possible please initialize the
>     other
>     >             UART too if it is
>     >             >         enabled in the FDT. Although we don't support
>     >             bluetooth yet
>     >             >         maybe there
>     >             >         will be support in the future or someone
>     wants to
>     >             do it in the
>     >             >         application.
>     >             >     I will go with this method then.
>     >             >         > Or if using the command line, then we need to
>     >             move the link to
>     >             >         > CONSOLE_DEVICE to console_initialize, and
>     parse the
>     >             >         > command line twice. If this is no problem,
>     then
>     >             we could use this
>     >             >         > approach also.
>     >             >         Would be possible too.
>     >             >         >     > And why don't we have a function similar
>     >             >         to *of_device_is_available*,
>     >             >         >     > since there will be more and more
>     >             >         >     > FDT based boards, this will be
>     really helpful.
>     >             >         >     I agree that it would be helpful.
>     Seems that
>     >             you just
>     >             >         found a function
>     >             >         >     that should be in a FDT framework.
>     >             >         >     RTEMS currently only has the basic libfdt
>     >             functions and
>     >             >         some RTEMS
>     >             >         >     specific ones. The of_... functions belong
>     >             to the FreeBSD
>     >             >         "Open Firmware
>     >             >         >     Bus" which is an abstraction layer on
>     top of
>     >             FDT. It would
>     >             >         be great to
>     >             >         >     identify useful ones and port them or
>     >             provide an RTEMS
>     >             >         implementation.
>     >             >         >     Like already discussed this could be
>     part of
>     >             a GSoC project.
>     >             >         >     Best regards
>     >             >         >     Christian
>     >             >         >     > On Sun, Jan 5, 2020 at 12:57 AM
>     Christian
>     >             Mauderer
>     >             >         >     <list at c-mauderer.de
>     >             <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>
>     >             >         >     > <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de>>>>>> wrote:
>     >             >         >     >     On 04/01/2020 09:32, Niteesh wrote:
>     >             >         >     >     > We could now run RTEMS on Rpi3. I
>     >             tried examples
>     >             >         from the
>     >             >         >     samples
>     >             >         >     >     > section and they run
>     >             >         >     >     > fine. But still, a lot of
>     >             functionality has to
>     >             >         tested since it
>     >             >         >     >     uses the
>     >             >         >     >     > RPI2 BSP. To test these examples
>     >             >         >     >     > I used a simple driver for the
>     AUX.
>     >             >         >     >     > The documentation from BCM link
>         <https://www.raspberrypi.org/app/uploads/2012/02/BCM2835-ARM-Peripherals.pdf> (pg
>     >             >         >     >     > no 10) states that
>     >             >         >     >     >     *The implemented UART is
>     not a 16650
>     >             >         compatible UART However
>     >             >         >     >     as far
>     >             >         >     >     >     as possible the first 8
>     control
>     >             and status
>     >             >         registers are
>     >             >         >     laid out
>     >             >         >     >     >     like a 16550 UART.*
>     >             >         >     >     It also tells
>     >             >         >     >         "Al 16550 register bits
>     which are
>     >             not supported
>     >             >         can be
>     >             >         >     written but
>     >             >         >     >     will be ignored and read back as 0.
>     >             All control bits for
>     >             >         >     simple UART
>     >             >         >     >     receive/transmit operations are
>     >             available."
>     >             >         >     >     So I would expect that not
>     everything
>     >             works like
>     >             >         expected (for
>     >             >         >     example
>     >             >         >     >     setting DCD, DSR, DTR, RI - they are
>     >             not there for
>     >             >         the mini
>     >             >         >     UART) but
>     >             >         >     >     the basic stuff should work.
>     >             >         >     >     > My question is can we use the
>     >             existing ns16550
>     >             >         driver or
>     >             >         >     should I
>     >             >         >     >     create
>     >             >         >     >     > a new one? I also checked the
>     >             address of the
>     >             >         registers the
>     >             >         >     offsets
>     >             >         >     >     don't
>     >             >         >     >     > seem right to me, but someone
>     should
>     >             check and
>     >             >         correct me if
>     >             >         >     I am
>     >             >         >     >     wrong.
>     >             >         >     >     If you compare the registers in the
>     >             existing driver
>     >             >         >     >     (NS16550_RECEIVE_BUFFER, ... in
>     >             ns16550_p.h) and the
>     >             >         one in
>     >             >         >     the BCM
>     >             >         >     >     datasheet the registers look very
>     >             similar (at least
>     >             >         from the
>     >             >         >     position /
>     >             >         >     >     function). I haven't done a bit
>     by bit
>     >             comparison
>     >             >         yet. Please
>     >             >         >     note that
>     >             >         >     >     you have to do a conversion between
>     >             the defines and
>     >             >         register
>     >             >         >     addresses.
>     >             >         >     >     The define gives you a register
>     index
>     >             for a 32bit
>     >             >         register. So
>     >             >         >     you have
>     >             >         >     >     to multiply by 4 to get an address.
>     >             The driver is
>     >             >         designed
>     >             >         >     that you
>     >             >         >     >     provide a setRegister and
>     getRegister
>     >             function that
>     >             >         can do this
>     >             >         >     >     conversion.
>     >             >         >     >     Where did you find differences?
>     >             >         >     >     I would suggest to just try the
>     driver.
>     _______________________________________________
>     >             >         > devel mailing list
>     >             >         > devel at rtems.org <mailto:devel at rtems.org>
>     <mailto:devel at rtems.org <mailto:devel at rtems.org>>
>     <mailto:devel at rtems.org <mailto:devel at rtems.org>>>
>     >             >         > http://lists.rtems.org/mailman/listinfo/devel
>     >             >         embedded brains GmbH
>     >             >         Herr Christian Mauderer
>     >             >         Dornierstr. 4
>     >             >         D-82178 Puchheim
>     >             >         Germany
>     >             >         email: christian.mauderer at embedded-brains.de
>     >             >         Phone: +49-89-18 94 741 - 18
>     >             >         Fax:   +49-89-18 94 741 - 08
>     >             >         PGP: Public key available on request.
>     >             >         Diese Nachricht ist keine geschäftliche
>     Mitteilung
>     >             im Sinne des
>     >             >         EHUG.
>     >             Dornierstr. 4
>     >             D-82178 Puchheim
>     >             Germany
>     >             Diese Nachricht ist keine geschäftliche Mitteilung im
>     Sinne
>     >             des EHUG.
>     Dornierstr. 4
>     D-82178 Puchheim
>     Germany
>     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
Dornierstr. 4
D-82178 Puchheim
Germany
