Requirement Document generator tool
Christian Mauderer christian.mauderer at embedded-brains.de
Tue Jan 28 09:14:44 UTC 2020
On 28/01/2020 01:42, Chris Johns wrote:
> On 28/1/20 10:48 am, Joel Sherrill wrote:
>> On Mon, Jan 27, 2020 at 4:18 PM Chris Johns <chrisj at rtems.org
>> <mailto:chrisj at rtems.org>> wrote:
>>     On 24/1/20 9:57 pm, Jose Valdez wrote:
>>     > In fact these tools target the pre-qualified project.
>>     Do you see this as different to the RTEMS project?
>>     > Since it was Sebastian who suggested to create this set of python tools,
>>     I think Sebastian is wanting a smooth path for these tools into the project.
>>     > I think the idea was to standardize the use of python not only for this
>>     project, but also for other python written code in RTEMS community. This has
>>     the advantages that every written python code is standard, but has the
>>     drawbacks:
>>     > -> old written code would need to be adapted to the standards.
>>     How different to the proposed coding standard is the existing code? Why not base
>>     the coding standard on what exists in the code base?
>> This is a very important question.
>>     Have you evaluated the size of the task to update the existing code? How would
>>     get such changes for the rtems-tools and the RSB be tested and integrated back
>>     into the project? This apporach seems like a huge review task for me.
>> It could be or it may turn out that there isn't much changed. Without someone
>> running the reformatter and reporting, we won't know.
> Running a reformatter may give you an idea of the scale however I have some
> concerns as Python's logic is based on indent levels and a missed level changes
> the logic. I am not sure how you know such a tool is safe to use unless you
> review all the changes.
To get some statistics for that I tried using yapf on the rtems-tools
repo. I excluded everything with  "patch-gdb-python", "tftpy" and
"asciidoc" in the name. You can see the yapf call in the commit message.
Google style:
https://gist.githubusercontent.com/c-mauderer/18746eaa8f3a077adddfe35c1f7b5194/raw/f8202a53ca043d23732d79ab217071e975dc35ad/0001-FIXME-Format-in-Google-style.patch
PEP8 Style:
https://gist.githubusercontent.com/c-mauderer/18746eaa8f3a077adddfe35c1f7b5194/raw/c97c77762f65041d9244bc8bc64b90ec698735bf/0001-FIXME-Reformat-using-PEP8.patch
In both cases it's about 3000 lines removed and 3700 lines added.
Without having a look at each line: Most seems to be just the normal
formatting stuff. Some lines are too long. Some spaces missing around
operators or spaces where they shouldn't be. Some lists written with
more or less line breaks. Some extra line breaks added between functions.
But I also noted a problem for python 3 compatibility: There are some
tab to space conversions. As far as I know python 3 throws at least a
warning or maybe an error if it finds tabs.
>> I tend to think it is worth knowing if this is a monster or a mouse before making
>> a decision.
> Yes this is important and also if it is a monster which specific rules make it
> so? It maybe most of the rules are fine.
> If these rules are important to the qual effort I hope they see the value in
> find these answers for us.
>>     > Another option could be leave it as it is and only do this for new written
>>     code.
>>     It would be confusing to any new user to the code to have code written to a
>>     standard and code that is not? If you edit the old code is it to the new
>>     standard? If you edit an old file do you need to update the whole file?
>> If we accept a standard, then it is all or nothing. I'm going to sound like a
>> cranky old man but we have said things like this before and regretted it
>> every time. Consistency is critical.
> If you are a cranky old man then that must make me one as well. Ah the youth of
> today ... :)
>> Quick run of sloccount for a baseline
>> + rtems-tools -
>> Totals grouped by language (dominant language first):
>> ansic:        47237 (49.86%)
>> cpp:          25837 (27.27%)
>> python:       21227 (22.40%)
>> sh:             442 (0.47%)
> Nice start. A more accurate report on this code would mean removing the imported
> pieces.
>> + rtems-source-builder/source-builder -
>> SLOC    Directory       SLOC-by-Language (Sorted)
>> 14314   sb              python=14169,sh=145
>> 65      top_dir         sh=65
>> 0       config          (none)
> There are the .cfg and .bset files.
>> 0       patches         (none)
>> So we have about 35K SLOC or Python by that.
>> No idea how the new standard versus the old looks. I thought Python had a consistent
>> style but I could be very wrong. :(
> I am not sure, I have never looked. My python skills have developed producing
> these tools and this code. I know doc comments are missing.
>>     > -> at some point some tools need to be upgraded (ex: python 3.7 will
>>     become unusable in 2030 Operating systems).
>>     I am not sure how this relates. Yes it will need to update however we need to
>>     support python2 for user facing tools for a while yet. A lot of what we do and
>>     how we work is historically driven.
>> CentOS 8 was just released in October. None of the big organization users I
>> see are using it yet.
>> We need to make a LTS release with 5 on Python 2 as a minimum. I feel strongly
>> about that.
> And I suspect longer.
>> As long as the tools are written in a python agnostic manner, the version won't
>> matter.
> Yes I agree, we should aim for a middle ground and avoid hitting any of issues
> that can arise.
>> We need some test cases for the tools to verify them
> Yes.
> Chris
>>     > I hope soon to formalize our suggestion to you and then you may review it
>>     (and propose changes if you find appropriate).
>>     I suggest working in the open and with us will be more beneficial in the
>>     long term.
>> +1 I can't agree strongly enough.
>>     Note, I am assuming the remainder of the email was Christian's. The quoting from
>>     your email client made it difficult to tell.
>>     Chris
>>     _______________________________________________
>>     devel mailing list
>>     devel at rtems.org <mailto:devel at rtems.org>
>>     http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
