Need to disable "atsamv" watchdog to avoid reset
Peter Dufault dufault at hda.com
Fri Jan 31 20:22:39 UTC 2020
I noticed this while tracking down the GMAC transmit initialization on non-revA SAMV71 chips and wanted to send it as heads-up and to see if anyone understands what's happening.
If I left the board doing nothing then after about fifteen or twenty minutes (I never characterized it) I would see "External reset detected" in the "ocd-remote" window and the program would restart.  I put breakpoints in the RTEMS fatal exit and it was never called, so I suspected a watch-dog timer reset.  I checked the RTEMS code and couldn't see anywhere the watch-dog was programmed.  I checked on-line:
"The Watchdog Timer (WDT) is used to prevent system lock-up if the software becomes trapped in a deadlock. It features a 12-bit down counter that allows a watchdog period of up to 16 seconds (slow the clock to around 32kHz). It can generate a general reset or a processor reset only. In addition, it can be stopped while the processor is in debug mode or idle mode.
"After a processor reset, the Watchdog peripheral is enabled by default with the value of watchdog counter value equal to 0xFFF, which corresponds to the maximum value of the counter with the external reset generation enabled (bit WDT_MR.WDRSTEN at 1 after a backup reset). The user can either disable the WDT by setting bit WDT_MR.WDDIS or reprogram the WDT to meet the maximum watchdog period the application requires."
This implies the board will get an external reset after sixteen seconds, not fifteen or twenty minutes, if the behavior isn't changed, but I added a "WDT_Disable(WDT);" to my code anyway and that solved the problem.
I posted this to give anyone else a heads-up and also to find out if anyone understood why it would take so long for the WDT to kick in.
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
This email is delivered through the public internet using protocols subject to interception and tampering.
