Converting stack address to shared-memory object name
Thu Jul 9 15:24:24 UTC 2020
On Wed, Jul 8, 2020 at 10:08 PM Utkarsh Rai <utkarsh.rai60 at gmail.com> wrote:
> On Wed, Jul 8, 2020 at 6:56 PM Gedare Bloom <gedare at rtems.org> wrote:
>> On Wed, Jul 8, 2020 at 6:53 AM Sebastian Huber
>> <sebastian.huber at embedded-brains.de> wrote:
>> > On 08/07/2020 14:43, Utkarsh Rai wrote:
>> > > Hello,
>> > > For my GSoC project, I have to provide high-level APIs for sharing
>> > > isolated stacks.
>> > > The POSIX compliant high-level way of sharing stacks can be to create
>> > > a shared memory object of the stack to be shared through shm_open and
>> > > then mmap that to the address space of the current stack. My doubt is,
>> > > shm_open() takes the path-name of the shared memory object. Since this
>> > > is a high-level API, how does the user 'convert' the stack address to
>> > > a shared memory object name?
>> > Do we need any POSIX compatibility for this? What would you do in a
>> > POSIX environment? You first get some memory, then hand it over to
>> > shm_open() to get a file descriptor, then use the file descriptor in
>> > mmap(), then use this for pthread_attr_setstack() and whatever?
>> Yes, but the way to name objects is not set by posix.
>> We need to provide our own way of translating an address into a name.
>> > > Dr.Gedare mentioned that one way to deal with naming would be
>> > > something like Mr.Sebastian has been doing with specifications. From
>> > > what I could gather, it is a hierarchical way of representing
>> > > objects(Though, I am not very sure if  I understand this accurately).
>> > > How can something like this be implemented for naming stack-addresses?
>> > I am not sure if the specification of RTEMS is helpful in this context.
>> I should have provided a little bit more guidance. I was thinking out
>> loud in yesterday's IRC meeting. My thought was more along the lines
>> of looking at how UIDs/naming should be done, and that specs had to
>> solve a naming problem. However the static nature of specs is not a
>> great fit to this problem.
>> Actually, what is a good model would be something like /proc or
>> Linux's sysfs. An IMFS filesystem that exports task information could
>> be used to name memory regions. (It could eventually supplant
>> task-based statistics reporting too.)
>> Another idea I had though, which seems to have been lost in the
>> shuffle, is to look at how the object names work in RTEMS and see if
>> we can add some fixed relationships, e.g., task_name # stack.
>> I think we should start by just treating the entire task stack as a
>> single named object; either it is all shared, or none of it is shared.
>> This will be easier to implement and also more widely supported by
>> simpler MPU/MMU hardware. Later on, we can consider extending the
>> namespace with 'offsets' /taskfs/IDLE/stack/00000A28
>> could be a location at byte A28 offset from the start of the stack of
>> the IDLE task.
> I have a few questions -
> > Users would get the stack address of the stack they want to share through pthread_attr_getstack(). Now, when they get the address they want to share, they would pass the appropriate name of this memory-region. What we have to provide is a mechanism to 'convert' this address to an appropriate name. Is this the accepted way or the other way round, i.e. the user passes a name as per a specified convention, and that name is 'converted' to a specific address?
We may want both to work. You definitely want to have the
address->name working though, at the very least with the base address
returned by pthread_attr_getstack, but you might also want to be able
to map any address in a task's stack to the stack's "name". I'm not
sure if that is needed yet, but keep it in mind as a possible
extension later to use an address interval instead of a fixed base
address.
> > When you say "treating the entire task stack as a single named object" does it mean that we assign a single name, say "task_stack" to the complete stack address space? In that case, how do we deal we the presence of multiple tasks that are allocated from the same pool of task stack? I understand that on a simpler MPU/MMU hardware it would make sense to specify names for each memory section (.txt- "text", .bss - "bss" etc.) but in this case,  where we are sharing only selected thread-stacks, I suppose we will have to have a way to handle 'offsets' right from the start?
No, I'm thinking one name for each task's stack. If you have 10 tasks,
you'd have 10 names.
Each allocated task stack is logically a separate region within the
pool. For simple MPU hardware, it may not be possible to share
arbitrary task stacks, but in that case the implementation can just
ignore the name and share the entire pool if that is preferred, or
return an error. (The behavior could be configurable, maybe.)
>> Gedare
