[GSoC 2020]: Weekly thread: Preparing RSB recipies for EPICS
Mritunjay Sharma mritunjaysharma394 at gmail.com
Tue Jul 21 16:42:18 UTC 2020
[UPDATE]: The error was actually a mismatch of names which was fixed with
the following
changes:
diff --git a/source-builder/config/epics-7-1.cfg
b/source-builder/config/epics-7-1.cfg
index fe1fb458..ea25f284 100644
--- a/source-builder/config/epics-7-1.cfg
+++ b/source-builder/config/epics-7-1.cfg
@@ -10,7 +10,7 @@
 %define epics_version 3afec267ab08568ea454789e562450b00feea5c0
-Name:      epics-%{epics_version}-%{_host}-%{release}
+Name:      epicsBaseOwnPlayground-%{epics_version}-%{_host}-%{release}
 Summary:   EPICS v%{epics_version} for target %{_target} on host %{_host}
 Version:   %{epics_version}
 Release:   %{release}
@@ -19,7 +19,8 @@ URL: 	  https://epics.mpg.de/
 # Source
-%source set epics --rsb-file=epics-%{epics_version}.zip
https://github.com/hjunkes/epicsBaseOwnPlayground/archive/%{epics_version}.zip
+%source set epics
--rsb-file=epicsBaseOwnPlayground-%{epics_version}.tar.gz
https://github.com/hjunkes/epicsBaseOwnPlayground/archive/%{epics_version}.tar.gz
 # Prepare the source code.
@@ -27,25 +28,20 @@ URL: 	  https://epics.mpg.de/
 %prep
   build_top=$(pwd)
-  source_dir_epics="epics-%{epics_version}"
+  source_dir_epics="epicsBaseOwnPlayground-%{epics_version}"
-  %source setup epics -q -n epics-%{epics_version}
+  %source setup epics -q -n epicsBaseOwnPlayground-%{epics_version}
   cd ${build_top}
 %build
   build_top=$(pwd)
-  %{build_directory}
-  mkdir -p ${build_dir}
-  cd ${build_dir}
+  cd ${source_dir_epics}
-  %{host_build_flags}
+  %{build_build_flags}
-  #cd ${source_dir_epics}
+  %{__make} PREFIX=%{_prefix}
   ./configure \
     --prefix=%{_prefix}
After this, I ran the command
`../source-builder/sb-builder --prefix=/home/mritunjay/development
--log=log_epics epics-7-1 --trace`
again. The error that has come now was expected because the changes I
made in epicsBaseOwnPlayground/configure file
were done manually and here it has to be done through a script. The
changes that I did manually were;
in epics-base/configure/CONFIG_SITE
> set
> CROSS_COMPILER_TARGET_ARCHS=
   What I entered:
   CROSS_COMPILER_TARGET_ARCHS=  RTEMS-pc386-qemu
> e.g. RTEMS-pc386
> or RTEMS-xilinx_zynq_a9_qemu
> in epics-base/configure/os there must be a file for the target used,
> e.g.
> CONFIG.Common.RTEMS-xilinx_zynq_a9_qemu
> or
> CONFIG.Common.RTEMS-pc386
Checked.  CONFIG.Common.RTEMS-pc386 was there
> Then you have to set in configure/os/CONFIG_SITE.Common.RTEMS
> where to find RTEMS:
> # Where to find RTEMS
> # APS:
> #RTEMS_VERSION = 4.10.2
> #RTEMS_BASE = /usr/local/vw/rtems/rtems-$(RTEMS_VERSION)
In my system, I entered this:
#FHI
RTEMS_VERSION = 5
RTEMS_BASE = /home/mritunjay/development/rtems/$(RTEMS_VERSION)
I have a doubt on how to implement the above changes in the
`source-builder/config/epics-7-1.cfg` to make it work.
Do we have to write a patch? And what will be the best way to do it?
The latest error looks somewhat like this which is because I have to
change the configurations in epics directory.
The question is how to accomplish it through the script.
../../configure/os/CONFIG.Common.RTEMS:36:
/Users/junkes/MVME6100/RTEMS/rtems-5/powerpc-rtems5/beatnik/Makefile.inc:
No such file or directory
Thanks
Mritunjay
On Tue, Jul 21, 2020 at 4:09 AM Mritunjay Sharma <
mritunjaysharma394 at gmail.com> wrote:
> Hello all,
> I went through the
> https://docs.rtems.org/branches/master/user/rsb/index.html
> and started writing a recipe for building EPICS 7.
> The code is based on a very raw idea just now and
> so was expected to give errors.
> The code can be found here:
> https://github.com/mritunjaysharma394/rtems-source-builder/blob/epics-support/source-builder/config/epics-7-1.cfg
> After this, just to check, what errors it might gave,
> I ran the following command:
> This gave me the following error:
> `+ cd epics-3afec267ab08568ea454789e562450b00feea5c0
> /home/mritunjay/development/rtems/src/rsb_GSoC/rtems/build/epics-3afec267ab08568ea454789e562450b00feea5c0-x86_64-linux-gnu-1/do-build:
> 90: cd: can't cd to epics-3afec267ab08568ea454789e562450b00feea5c0
> shell cmd failed: /bin/sh -ex
> error: building
> epics-3afec267ab08568ea454789e562450b00feea5c0-x86_64-linux-gnu-1`
> I think there seems to be some problem with naming the directory.
> I request you all to kindly help with the error as well as please check
> the code
> to see if I am on the right path.
> I am attaching the log and trace file as well.
> Thanks,
> Mritunjay
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200721/c6c4a9c7/attachment.html>
