Small doubt in how chain works in RTEMS
Fri Jun 12 13:58:46 UTC 2020
On Fri, Jun 12, 2020 at 7:50 AM Richi Dubey <richidubey at gmail.com> wrote:
> Hi everyone,
> While going through testsuites/sptests/spchain/init.c, I noticed the following code:
> rtems_task Init(
>   rtems_task_argument ignored
>   rtems_chain_control  chain1;
>   rtems_chain_node    *p;
>   test_node            node1, node2;
>   int                  id;
>   TEST_BEGIN();
>   puts( "Init - Initialize chain empty" );
>   rtems_chain_initialize_empty( &chain1 );
>   rtems_chain_initialize_node( &node1.Node );
>   rtems_chain_initialize_node( &node2.Node );
>   /* verify that the chain append and insert work */
>   puts( "INIT - Verify rtems_chain_insert" );
>   node1.id = 1;
>   node2.id = 2;
>   rtems_chain_append( &chain1, &node1.Node );
>   rtems_chain_insert( &node1.Node, &node2.Node );
>   for ( p = rtems_chain_first(&chain1), id = 1 ;
>         !rtems_chain_is_tail(&chain1, p) ;
>         p = p->next , id++ ) {
>      test_node *t = (test_node *)p;
>      if ( id > 2 ) {
>        puts( "INIT - TOO MANY NODES ON CHAIN" );
>        rtems_test_exit(0);
>      if ( t->id != id ) {
>        puts( "INIT - ERROR ON CHAIN ID MISMATCH" );
>        rtems_test_exit(0);
> Where test_node is defined as:
> typedef struct {
>   rtems_chain_node Node;
>   int              id;
> } test_node;
> Now when we are inserting or appending our structure into the chain, we are only inserting the part of strucuture correspoing to rtems_chain_node, i.e.:
> So, how do we ever get our node1.id ? How can we (or how do we ever) access our data from the structure when we are only adding some part of the structure into the node?
> I hope my doubt is not too vague.
Hi Richi,
This is an old C programming trick.
This looks like a reasonable explanation:
https://medium.com/@414apache/kernel-data-structures-linkedlist-b13e4f8de4bf
Feel free to write something for rtems ;)
> Thanks,
> Richi.
> devel mailing list
> devel at rtems.org
