[PATCH] test for fegetround and fesetround
Eshan Dhawan eshandhawan51 at gmail.com
Mon Mar 2 17:14:31 UTC 2020
On Mon, Mar 2, 2020 at 8:35 PM Aditya Upadhyay <aadit0402 at gmail.com> wrote:
> Hi Eshan,
> Thanks for pointing this out again. I would appreciate if you can send
> here a new v1 patch for the
> fenv methods. I can see the list of functions what you have left
> there, without any test.
> https://lists.rtems.org/pipermail/devel/2020-February/057669.html
> Could you please remove this?
I have sent the patch for it
https://lists.rtems.org/pipermail/devel/2020-February/057671.html
> I have not yet tested the code due to
> sparc-rtems-gdb and tar sim error.
> I will have to resolve this issue.
Psxfenv01 tests won't work on sparc architecture since it doesn't have any
implementation
of the floating-point environment in it yet.
i have checked them with riscv BSP
 For each tests, you need to understand the behavior of that function
> based on different parameters. I assume that
> you must have gone through the open group pages of these functions,
> there you will get to know the different
> outcomes. You will also have to look into some invalid set of inputs.
ok
> If you are interested to contribute in POSIX Compliance, then I would
> suggest you to make yourself familiar with
> newlib-cygwin building process. You can also fix some warnings while
> building Newlib if you find one and send a patch to
> newlib mailing list. You may be spending most of the gsoc duration
> contributing to Newlib rather than RTEMS.
>  thanks
--Eshan
Regards,
> Aditya Upadhyay
> On Mon, Mar 2, 2020 at 1:26 AM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
> > hello everyone,
> > I am new here and I sent the patches:
> > 1. > https://lists.rtems.org/pipermail/devel/2020-February/057669.html
> > 2. > https://lists.rtems.org/pipermail/devel/2020-February/057671.html
> > 3. > https://lists.rtems.org/pipermail/devel/2020-February/057711.html
> > a few days ago.
> > for adding tests to psxfenv01.
> > but no one reviewed it.
> > so I ping it back
> > if someone could review it and give feedback.
> > -- Eshan
> > On Tue, Feb 25, 2020 at 11:15 PM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
> >> added tests for fegetround and fesetround in psxtests / psxfenv01
> >> fegetround fails to send the rounding direction due to soft float and
> returns to_nearest or zero  in the cases
> >> fesetround sends zero if the rounding direction is set and sends
> anything else if the function fails to set the rounding direction
> >> can you check the patch for correctness
> >> - Eshan
> >> On Tue, Feb 25, 2020 at 8:26 PM Eshan dhawan <eshandhawan51 at gmail.com>
> wrote:
> >>>  testsuites/psxtests/psxfenv01/init.c | 42 +++++++++++++++++++++++++++-
> >>>  1 file changed, 41 insertions(+), 1 deletion(-)
> >>> diff --git a/testsuites/psxtests/psxfenv01/init.c
> b/testsuites/psxtests/psxfenv01/init.c
> >>> index 05f3cdc880..4339139c58 100644
> >>> --- a/testsuites/psxtests/psxfenv01/init.c
> >>> +++ b/testsuites/psxtests/psxfenv01/init.c
> >>> @@ -106,7 +106,47 @@ rtems_task Init(rtems_task_argument ignored)
> >>>        printf("fesetexceptflag ==> 0x%x\n", r);
> >>>      rtems_test_assert(r == 0);
> >>> +    /*test for fegetround() and fesetround()*/
> >>> +    /*they have four main macros to be tested seperated by ifdef*/
> >>> +    /* since all the architectures dont support them */
> >>> +    /*the test cases gets and sets the rounding directions */
> >>> +#ifdef FE_TONEAREST
> >>> +    r=fegetround();
> >>> +    if(r)
> >>> +       printf("fegetround ==> 0x%x\n", r);
> >>> +    rtems_test_assert(r == FE_TONEAREST) ;
> >>> +#endif
> >>> +#ifdef FE_TOWARDZERO
> >>> +  r=fesetround(FE_TOWARDZERO);
> >>> +  if(r)
> >>> +       printf("fesetround ==> 0x%x\n", r);
> >>> +  rtems_test_assert(r == 0) ;
> >>> +  rtems_test_assert(fegetround() == FE_TOWARDZERO) ;
> >>> +#endif
> >>> +#ifdef FE_DOWNWARD
> >>> +  r=fesetround(FE_DOWNWARD);
> >>> +  if(r)
> >>> +  rtems_test_assert(fegetround() == FE_DOWNWARD) ;
> >>> +#endif
> >>> +#ifdef FE_UPWARD
> >>> +  r=fesetround(FE_UPWARD);
> >>> +  if(r)
> >>> +  rtems_test_assert(fegetround() == FE_UPWARD) ;
> >>> +#endif
> >>> +  r=fesetround(FE_TONEAREST);
> >>> +  if(r)
> >>> +#endif
> >>>  #ifdef FE_DIVBYZERO
> >>> 2.17.1
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200302/5dbd6dd4/attachment-0001.html>
